I have i different model of this camera A9_wificam_20211124 with open SSID named BATA014453OVOJI
This is some pictures of the board. I identified UART pins on the bottom.
This an UART log while starting and connecting to my test wifi setup.
I also captured packets while changing configuration and watching live from the mobile app, but for now reverse engineered this part is out of my scope.
May be someone will have better knowledge of Thread Operating System.
<0xfc>
- RT - Thread Operating System
/ | \ 3.1.0 build Nov 5 2022
2006 - 2018 Copyright by rt-thread team
OSK Rev: R-3.0.22
SDK Rev: 3.0.33
mac:C8 47 8C A6 69 9A
[FUNC]rwnxl_init
IP Rev: W4-3.0.33-P0
[bk]tx_txdesc_flush
[FUNC]calibration_main
rfcali_mode:0
tssi:b-137, g-120
Manual cal wrong rate:127
lpf_i & q in flash is:128, 128
xtal in flash is:25
xtal_cali:25
[FUNC]ps_init
[FUNC]func_init_extended OVER!!!
start_type:3
lwIP-2.0.2 initialized!
beken wlan hw init
drv_pm_init
<0x1b>[32;22m[I/FAL] RT-Thread Flash Abstraction Layer (V0.4.0) initialize success.<0x1b>[0m
msh />cmd 1:3
size:400 total_block:3aa000
<0x1b>[32;22m[I/FAL] The FAL MTD NOR device (download) created successfully<0x1b>[0m
LFS Filesystem initialized! download ==> /flash0*[ilnkp2p\src\IpcDevSys.c][3437],IpcSysInit:gStartType=3,gDcOrBattery=0
[ilnkp2p\src\IpcDevCfg.c][ 239],initStaticParam:use serverseq=2,svr=SWPNPDPFLVAOLNSXPHSQPIEOPAIDENLXHXEHIFLKPGLRHUARSTLQEEEPSU<break>
cVersion=2_4_2_50
cVersion=2_4_2_50
[ilnkp2p\src\IpcDevCfg.c][ 526],IpcCfgInit:2:616-->get from ezConfig BATA014453OVOJI:TBVRRF:
[ilnkp2p\libp2p\Xq_p2pUtils.c][1907],XqP2pIdCheck:get pre: BATA,sec OVOJI sn 14453
[ilnkp2p\libp2p\Xq_p2pUtils.c][1914],XqP2pIdCheck:to chk new p2pid-->PYF:BATA014453OVOJI:TBVRRF
[ilnkp2p\libp2p\Xq_p2pUtils.c][1935],XqP2pIdCheck:ok!!- compare sec=OVOJI,sec1=OUOII, _p2pSecCode2=OVOJI[TBVRRF]
[ilnkp2p\src\IpcDevCfg.c][ 547],IpcCfgInit:0-->get from ezConfig BATA014453OVOJI:TBVRRF:
[ilnkp2p\src\IpcDevCfg.c][ 596],IpcCfgInit:0--> get from config BATA014453OVOJI:TBVRRF:
[ilnkp2p\src\IpcDevCfg.c][ 634],IpcCfgInit:sTm=1514765167,cTm=1514765167[Mon Jan 1 00:06:07 2018
],rTm=1514765167
[ilnkp2p\src\IpcDevCfg.c][1449],IpcCfgItemGet:failed--->EC_KEY_VID_REC_EN
[ilnkp2p\src\IpcDevCfg.c][1531],IpcCfgItemGet:failed--->EC_KEY_SLEEP
[ilnkp2p\src\IpcDevCfg.c][1548],IpcCfgItemGet:failed--->EC_KEY_SLEEP
[ilnkp2p\src\IpcDevSys.c][3490],IpcSysInit:dwnType=0----->pwr=3895:3600:0
sysmode=0,t=827,ret=4,gShutdwonValue=0
no music file
[ilnkp2p\src\IpcDevSys.c][3854],_StartupWiFiInfChk:no wifi.ini file
[ilnkp2p\src\IpcDevSys.c][4149],_StartupFctChk:failed _StartupWiFiInfChk---->[-1]
[ilnkp2p\src\IpcDevSys.c][3538],IpcSysInit:_StartupFctChk--->-1,gFctChkOn=0
[ilnkp2p\src\IpcDevSys.c][ 384],IpcFuncSwitch:enter-------->
[ilnkp2p\src\IpcDevWlan.c][ 443],IpcWifiStop:mode=2,gWifiConnected=0
sending broadcast_deauth failed vif_entry == NULL
[ilnkp2p\src\IpcDevSys.c][ 459],IpcFuncSwitch:exit-------->0
[ilnkp2p\src\IpcDevSys.c][3550],IpcSysInit:_StartupFctChk--->-1,gFctChkOn=0
[ilnkp2p\src\IpcDevSys.c][3330],normalRun:normalRun--->0,gFctChkOn=0
sysmode=1,t=886
[ilnkp2p\src\IpcDevWlan.c][ 414],IpcWifiStart:
mode=2,ssid=BATA014453OVOJI,psk=12345678
[ilnkp2p\src\IpcDevWlan.c][ 130],ap_setup:chann=2,mac=c8:47:8c:a6:69:4d
[ilnkp2p\src\IpcDevWlan.c][ 152],ap_setup:set ip info: 192.168.1.1,255.255.255.0,192.168.1.1,c8:47:8c:a6:69:4d
[ilnkp2p\src\IpcDevWlan.c][ 154],ap_setup:ssid:BATA014453OVOJI key:
Soft_AP_start
[saap]MM_RESET_REQ
[bk]tx_txdesc_flush
[saap]ME_CONFIG_REQ
[saap]ME_CHAN_CONFIG_REQ
[saap]MM_START_REQ
[csa]csa_in_progress[0:0]-clear
mm_add_if_req_handler:0
hapd_intf_add_vif,type:3, s:0, id:0
apm start with vif:0
------beacon_int_set:100 TU
set_active param 0
[msg]APM_STOP_CFM
update_ongoing_1_bcn_update
mm_set_vif_state_req_handler
vif_idx:0, ch_idx:0, bcmc_idx:2
uap_ip_start
configuring interface uap (with Static IP)
using static ip...
please use rtthread dncp start server
[DHCP] dhcpd_start: ap
[DHCP] ip_start: [192.168.1.100]
[DHCP] ip_end: [192.168.1.254]
[DHCP] dhcp_server_start(): starting new DHCP server
[DHCP] dhcp_server_start(): starting DHCP server
def netif is no ap's netif, sending boardcast or no-subnet ip packets may failed
[ilnkp2p\src\IpcDevWlan.c][ 434],IpcWifiStart:IpcWifiStart=208
[ilnkp2p\src\IpcDevSys.c][1669],sdPlugChk:sd-cd value=0,gSdPlugIn=-1
[ilnkp2p\src\IpcDevSys.c][3388],normalRun:IpcSysInit=0,t=1012
start watch dog
rt_hw_wdg_start time=10000 threshold=500
ble start no ble name
ble name:BK7231BT-01, c9:47:8c:a6:69:9a
EM_BLE_END:0xe10
-----rw_main task init----
cmd---->202518556
h4tl_init
h4tl_read_start
BLE Rev: B4-3.0.33-P0
-----rw_main start----
gapm_cmp_evt_handler operation = 0x1, status = 0x0
gapm_cmp_evt_handler operation = 0x3, status = 0x0
STACK INIT OK
ble create new db
ble_env->start_hdl = 0xa
prf_task_id:120, state:1
BLE_CREATE_DB_OK
gapm_cmp_evt_handler operation = 0x1b, status = 0x0
appm start advertising
2----open I2C2
chNmb=8,sensor=0,gUsedCam=abc03,allNmb=8
[ilnkp2p\avServer\iLnkAvServer.c][ 428],vidBitrateSet:sNo=5120,bLH=[7168:0],vBuf=18432:49152:32768:-559038737
[ilnkp2p\avServer\iLnkAvServer.c][ 459],vidBitrateSet:sNo=5120,bLH=[7168:0],vBuf=18432:49152:32768:-559038737
[ilnkp2p\src\IpcCustomAV.c][1445],_VidFrameGetTh:gSnsDir=0
[ilnkp2p\src\IpcDevSys.c][ 974],keyBtnHandler:btn00405444_event_val=0
[ilnkp2p\src\IpcDevSys.c][ 978],keyBtnHandler:key_btn press down
[ilnkp2p\src\IpcDevWlan.c][ 321],IpcWifiStatusGet:bk_wlan_ap_is_up:wifiMode=2,ret=1
[ilnkp2p\src\InkP2pModule.c][ 101],IpcP2pStart:p2p starte,bP2pStarted=[0]
[ilnkp2p\libipc\IpcDevAPI.c][ 47],_IpcInit:info[688]:
p2pID=BATA014453OVOJI:SWPNPDPFLVAOLNSXPHSQPIEOPAIDENLXHXEHIFLKPGLRHUARS<break>
[ilnkp2p\libipc\IpcDevAPI.c][ 50],_IpcInit:info---P2pInit()
[ilnkp2p\libipc\IpcDevP2P.c][ 426],P2pInit:sNmb=2
cNmb=6
cBuf=32
sStr=SWPNPDPFLVAOLNSXPHSQPIEOPAIDENLXHXEHIFLKPGLR<break>
[ilnkp2p\libp2p\XQP2P_API.c][ 41],XQP2P_InitializeExt:sNmb=2
cNmb=6
cBuf=32
sStr=SWPNPDPFLVAOLNSXPHSQPIEOPAIDENLXHXEH<break>
[ilnkp2p\libp2p\Xq_p2pEntry.c][1472],P2P_Init:MaxNmbOfSession=2
MaxNmbOfChannel=6
MaxSizeOfChannel=32
1032
1072
20
<break>
[ilnkp2p\libp2p\OsEncryptBase.c][ 643],XqCodeTableInit:codeTable=1352
[ilnkp2p\libp2p\Xq_p2pEntry.c][ 144],GlobalParamInit:
NodeName=TBVRRF
[ilnkp2p\libp2p\Xq_p2pEntry.c][ 158],GlobalParamInit:
_g_params:
sessionNmb=2
channelNmb=6
bufferSize=32
svrStr=SWPNPDPFLVAOL<break>
[ilnkp2p\libp2p\Xq_p2pEntry.c][1487],P2P_Init:GlobalParams_Init=0,st_globalParams=420,_g_pVerifyParam=524
[ilnkp2p\libp2p\Xq_p2pEntry.c][1508],P2P_Init:mpSize=64----P2PPktPool_Get
closesocket: invalid s=0
[ilnkp2p\libp2p\Xq_p2pEntry.c][1641],[ilnkp2p\libp2p\Xq_p2pEntry.c][ 664],BCstListenProc:error[-1]-BrdCstSktFDPut
PCstListenProc:error[-1]-BrdCstSktFDPut
<break>
n==16
[ilnkp2p\libipc\IpcDevP2P.c][ 435],P2pInit:info!!! P2pInit=0
[ilnkp2p\libipc\IpcDevAPI.c][ 59],_IpcInit:info---IpcSession_Init()
[ilnkp2p\libipc\IpcDevCallback.c][ 77],cb_CallRegist:cmd nmb=8
[ilnkp2p\libipc\IpcDevAPI.c][ 173],IpcLibStart:info---Using external ringbuf,check CB ifexisted
[ilnkp2p\libipc\IpcDevSession.c][ 997],LstnThStart:bInet[0]-->_ListenThread
[ilnkp2p\src\Ink[ilnkp2p\libipc\IpcDevSession.c][ 671],_ListenThread:_ListenThread-----start
[ilnkp2p\libipc\IpcDevSession.c][ 689],_ListenThread:bInet=0-->listening by id:BATA014453OVOJI,devName=TBVRRF
[ilnkp2p\libp2p\XQP2P_API.c][ 86],XQP[ilnkp2p\libipc\IpcDevSession.c][ 856],CmdRecvTh:CmdRecvThread start...
PpcDevSession.c][ 856],CmdRecvTh:CmdRecvThread start...
<break>
Co[ilnkp2p\src\InkP2pModule.c][ 173],IpcP2pStart:IpcP2pStart=0
[ilnkp2p\src\IpcDevSys.c][2992],_mon500chk:1--Mode=1,wlan=1:1,IDR=0,sd=1,conn=0,keep=0:-1:0,[0:1]wla2chk:1--Mode=1,wlan=1:1,IDR=0,sd=1,conn=0,keep=0:[ilnkp2p\libp2p\Xq_p2pEntry.c][ 554],BrdCstSktGet:error[XqSckIfValid=-1],pSession->sktFd=4
[ilnkp2p\libp2p\Xq_p2pEntry.c][1155],SessionGet:session id is BATA-014453-OVOJI
gParam.bFlagServen=2,run=0,gSdTh=0,rec=0,t=<break>
[ilnkp2p\src\IpcDevSys.c][2654],IpcSysSchChk:ret=2,bValid=3,schItem=1
[ilnkp2p\record\IpcRecMgrEx.c][1329],IpcRecSwitch:bOnOff=1 && pParam->recType==2,record_md.record_type==0
[ilnkp2p\record\IpcRecrcRecMgrEx[ilnkp2p\libp2p\Xq_p2pSession.c][ 387],pSessionStart:sock=5,localAddr is 0.0.0.0:62510,udpPort4=62510
Mession.c][ 387],pSessionStart:sock=5,localAddr is 0.0.0.0:62510,udpPort4=62510
<break>
ecord_type==0
[ilnkp2p\record\IpcRecMgrEx.c][1103],_RecWrtThStart:audio=1: write=0 && recType=[2,0],duration=300
[ilnkp2p\src\IpcDevSys.c][2[ilnkp2p\record\IpcRecMgrEx.c][ 905],_RecWrtTh:audio=1: write=0 && recType=[2,0],duration=300
659],IpcFuncSwitch:exit-------->0
<break>
<break>
1,gVidCounter=0
close on th=0
[ilnkp2p\src\IpcCustomAV.c][1467],_VidFrameGetTh:0-->1:1 0:3856:1110:1413,vCho=[abc03:0:18432],s=-1,fps=0,diff=1514765167
[ilnkp2p\record\IpcRecMgrEx.c][1179],IpcRecAviOpen:open recording time=1514765168,DurationSec=300
[ilnkp2p\record\IpcRecMgrEx.c][ 446],create_avi_file_and_dir:use default SD_DETECT_BIT 0
[ilnkp2p\record\Xq_aviLib.c][1544],AVI_Init_fd_1:trace broken----->
[ilnkp2p\record\Xq_aviLib.c][1557],AVI_Init_fd_1:trace broken----->
[ilnkp2p\src\IpcDevSys.c][ 974],keyBtnHandler:btn00405444_event_val=1
[ilnkp2p\src\IpcDevSys.c][ 985],keyBtnHandler:key_btn press up --> -1
[ilnkp2p\src\IpcDevSys.c][1011],keyBtnHandler:<0xbf><0xec><0xb0><0xb4> --> 1464:0:0
[ilnkp2p\record\Xq_aviLib.c][1579],AVI_Init_fd_1:trace broken----->
[ilnkp2p\record\Xq_aviLib.c][1588],AVI_Init_fd_1:trace broken----->
[ilnkp2p\record\Xq_aviLib.c][1598],AVI_Init_fd_1:trace broken----->
[ilnkp2p\record\Xq_aviLib.c][1279],AVI_init_file_header:tracer----->2048
[ilnkp2p\record\Xq_aviLib.c][1383],AVI_init_file_header:tracer----->2
[ilnkp2p\record\Xq_aviLib.c][1442],AVI_init_file_header:tracer----->1712
[ilnkp2p\record\Xq_aviLib.c][1467],AVI_init_file_header:tracer----->2048,AVI->fdes=7,AVI->pos=2048
[ilnkp2p\record\Xq_aviLib.c][1480],AVI_init_file_header:tracer----->0[errno=0]
[ilnkp2p\record\Xq_aviLib.c][1492],AVI_init_file_header:tracer----->2048[errno=0]
[ilnkp2p\record\Xq_aviLib.c][1517],AVI_init_file_header:tracer----->2048
[ilnkp2p\record\Xq_aviLib.c][1527],AVI_init_file_header:tracer----->2048
[ilnkp2p\record\Xq_aviLib.c][1607],AVI_Init_fd_1:trace broken----->
[ilnkp2p\record\Xq_aviLib.c][1621],AVI_Init_fd_1:trace broken----->
[ilnkp2p\record\IpcRecMgrEx.c][ 523],create_avi_file_and_dir:Create /sd/record/20180101/0_1514765168_300_2_0.a tmLen=300!
[ilnkp2p\record\IpcRecMgrEx.c][1205],IpcRecAviOpen:open recording ok =1 time=1514765168,DurationSec=300
[ilnkp2p\record\IpcRecMgrEx.c][ 932],_RecWrtTh:audio=1: write=1 && recType=[2,2],tmLen=300
adc-buf:00900cf8, adc-buf-len:5120, ch:1
set adc channel 1
set adc sample rate 8000
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=1,diffInterval=1,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=2,diffInterval=2,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=3,diffInterval=3,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=4,diffInterval=4,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=5,diffInterval=5,recordTimeLen=300
[ilnkp2p\src\IpcDevSys.c][2992],_mon500chk:1--Mode=1,wlan=1:1,IDR=0,sd=1,conn=0,keep=0:-1:0,[0:1]wlan=2,run=500,gSdTh=0,rec=1,<break>
[ilnkp2p\record\IpcRecMgrEx.c][1329],IpcRecSwitch:bOnOff=1 && pParam->recType==2,record_md.record_type==2
[ilnkp2p\src\IpcDevSys.c][2670],_sysMonRecSch:gVidGetPts=1514765173---->gVidPresPts=1514765167,gSysMode=1,gVidCounter=0
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=6,diffInterval=6,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=7,diffInterval=7,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=8,diffInterval=8,recordTimeLen=300
close on th=0
[ilnkp2p\src\IpcCustomAV.c][1467],_VidFrameGetTh:0-->1:1 0:3927:6740:10769,vCho=[abc03:0:18432],s=-1,fps=0,diff=10
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=9,diffInterval=9,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=10,diffInterval=10,recordTimeLen=300
[ilnkp2p\src\IpcDevSys.c][2992],_mon500chk:1--Mode=1,wlan=1:1,IDR=0,sd=1,conn=0,keep=0:-1:0,[0:1]wlan=2,run=1000,gSdTh=0,rec=1<break>
[ilnkp2p\src\IpcDevSys.c][2670],_sysMonRecSch:gVidGetPts=1514765178---->gVidPresPts=1514765173,gSysMode=1,gVidCounter=0
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=11,diffInterval=11,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=12,diffInterval=12,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=13,diffInterval=13,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=14,diffInterval=14,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=15,diffInterval=15,recordTimeLen=300
[ilnkp2p\src\IpcDevSys.c][2992],_mon500chk:1--Mode=1,wlan=1:1,IDR=0,sd=1,conn=0,keep=0:-1:0,[0:1]wlan=2,run=1500,gSdTh=0,rec=1<break>
[ilnkp2p\src\IpcDevSys.c][2670],_sysMonRecSch:gVidGetPts=1514765183---->gVidPresPts=1514765178,gSysMode=1,gVidCounter=0
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=16,diffInterval=16,recordTimeLen=300
hapd_intf_sta_add:1, vif:0
rc_init: station_id=0 format_mod=0 pre_type=0 short_gi=0 max_bw=0
rc_init: nss_max=0 mcs_max=255 r_idx_min=0 r_idx_max=11 no_samples=10
sta_idx:0, pm_state:0
wpa_hostapd_no_password_connected
ap_index:0
sta_id:0
send connected msg
===wlan_event_handle:10===
[WLAN_MGNT]wlan[DHCP] [dhcp_server_recv:305] ap recv 292
[DHCP] [dhcp_server_recv:367] msg_type=3
<break>
[DHCP] [dhcp_server_recv:367] msg_type=1
[DHCP] [dhcp_server_recv:305] ap recv 298
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=17,diffInterval=17,recordTimeLen=300
[DHCP] [dhcp_server_recv:305] ap recv 300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=18,diffInterval=18,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=19,diffInterval=19,recordTimeLen=300
close on th=0
[ilnkp2p\src\IpcCustomAV.c][1467],_VidFrameGetTh:0-->1:1 0:3913:16900:20699,vCho=[abc03:0:18432],s=-1,fps=0,diff=10
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=20,diffInterval=20,recordTimeLen=300
[ilnkp2p\src\IpcDevSys.c][2992],_mon500chk:1--Mode=1,wlan=1:1,IDR=0,sd=1,conn=0,keep=0:-1:0,[0:1]wlan=2,run=2000,gSdTh=0,rec=1<break>
[ilnkp2p\src\IpcDevSys.c][2670],_sysMonRecSch:gVidGetPts=1514765188---->gVidPresPts=1514765183,gSysMode=1,gVidCounter=0
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=21,diffInterval=21,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=22,diffInterval=22,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=23,diffInterval=23,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=24,diffInterval=24,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=25,diffInterval=25,recordTimeLen=300
[ilnkp2p\src\IpcDevSys.c][2992],_mon500chk:1--Mode=1,wlan=1:1,IDR=0,sd=1,conn=0,keep=0:-1:0,[0:1]wlan=2,run=2500,gSdTh=0,rec=1<break>
[ilnkp2p\src\IpcDevSys.c][2670],_sysMonRecSch:gVidGetPts=1514765193---->gVidPresPts=1514765188,gSysMode=1,gVidCounter=0
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=26,diffInterval=26,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=27,diffInterval=27,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=28,diffInterval=28,recordTimeLen=300
close on th=0
[ilnkp2p\src\IpcCustomAV.c][1467],_VidFrameGetTh:0-->1:1 0:3895:27017:30639,vCho=[abc03:0:18432],s=-1,fps=0,diff=10
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=29,diffInterval=29,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=30,diffInterval=30,recordTimeLen=300
[ilnkp2p\src\IpcDevSys.c][2992],_mon500chk:1--Mode=1,wlan=1:1,IDR=0,sd=1,conn=0,keep=0:-1:0,[0:1]wlan=2,run=3000,gSdTh=0,rec=1<break>
[ilnkp2p\src\IpcDevSys.c][2670],_sysMonRecSch:gVidGetPts=1514765198---->gVidPresPts=1514765193,gSysMode=1,gVidCounter=0
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=31,diffInterval=31,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=32,diffInterval=32,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=33,diffInterval=33,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=34,diffInterval=34,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=35,diffInterval=35,recordTimeLen=300
[ilnkp2p\src\IpcDevSys.c][2992],_mon500chk:1--Mode=1,wlan=1:1,IDR=0,sd=1,conn=0,keep=0:-1:0,[0:1]wlan=2,run=3500,gSdTh=0,rec=1<break>
[ilnkp2p\src\IpcDevSys.c][2670],_sysMonRecSch:gVidGetPts=1514765203---->gVidPresPts=1514765198,gSysMode=1,gVidCounter=0
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=36,diffInterval=36,recordTimeLen=300
ap_handle_timer
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=37,diffInterval=37,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=38,diffInterval=38,recordTimeLen=300
close on th=0
[ilnkp2p\src\IpcCustomAV.c][1467],_VidFrameGetTh:0-->1:1 0:3880:37183:40565,vCho=[abc03:0:18432],s=-1,fps=0,diff=10
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=39,diffInterval=39,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=40,diffInterval=40,recordTimeLen=300
[ilnkp2p\src\IpcDevSys.c][2992],_mon500chk:1--Mode=1,wlan=1:1,IDR=0,sd=1,conn=0,keep=0:-1:0,[0:1]wlan=2,run=4000,gSdTh=0,rec=1<break>
[ilnkp2p\src\IpcDevSys.c][2670],_sysMonRecSch:gVidGetPts=1514765208---->gVidPresPts=1514765203,gSysMode=1,gVidCounter=0
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=41,diffInterval=41,recordTimeLen=300
[ilnkp2p\record\IpcRecMgrEx.c][1021],_RecWrtTh:fps=0,diffTime=42,diffInterval=42,recordTimeLen=300
