<!-- Thanks for reporting a problem for this project. READ THIS FIRST:
This i…ssue template is meant to REPORT Tasmota software PROBLEMS ONLY
Please DO NOT OPEN AN ISSUE:
- If your Tasmota version is not the latest from the development branch, please update your device before submitting your issue. Your problem might already be solved. The latest precompiled binaries of Tasmota can be downloaded from http://thehackbox.org/tasmota/
- If you have an issue when flashing was done via Tuya Convert, please address it to Tuya Convert Team
- If your issue is a flashing issue, please address it to the [Tasmota Support Chat](https://discord.gg/Ks2Kzd4)
- If your issue is compilation problem, please address it to the [Tasmota Support Chat](https://discord.gg/Ks2Kzd4)
- If your issue has been addressed before (i.e., duplicated issue), please ask in the original issue
- If your issue is a Wi-Fi problem or MQTT problem, please try the steps provided in the [FAQ](https://tasmota.github.io/docs/#/help/FAQ) and [Troubleshooting](https://tasmota.github.io/docs/#/help/Troubleshooting)
Please take a few minutes to complete the requested information below. Our ability to provide assistance is greatly hampered without it. The details requested potentially affect which options to pursue. The small amount of time you spend completing the template will also help the volunteers providing the assistance to you to reduce the time required to help you.
DO NOT DELETE ANY TEXT from this template! Otherwise the issue will be auto-closed.
### PROBLEM DESCRIPTION
Sonoff devices with Tasmota firmware refuse to reconnect after power cycling them. As evident by serial output the devices just says "fails to connect to AP".
The only remedy is to reboot router, then all my tasmota devices that are stuck in a loop will connect instantly.
### REQUESTED INFORMATION
_Make sure your have performed every step and checked the applicable boxes before submitting your issue. Thank you!_
- [x] Read the [Contributing Guide and Policy](https://github.com/arendst/Tasmota/blob/development/CONTRIBUTING.md) and [the Code of Conduct](https://github.com/arendst/Tasmota/blob/development/CODE_OF_CONDUCT.md)
- [x] Searched the problem in [issues](https://github.com/arendst/Tasmota/issues)
- [x] Searched the problem in the [docs](https://tasmota.github.io/docs/#/help/FAQ)
- [x] Searched the problem in the [forum](https://groups.google.com/d/forum/sonoffusers)
- [x] Searched the problem in the [chat](https://discord.gg/Ks2Kzd4)
- [x] Device used (e.g., Sonoff Basic): Sonoff S55/T1/Mini
- [x] Tasmota binary firmware version number used: 8.1.0
- [x] Pre-compiled
- [ ] Self-compiled
- [ ] IDE / Compiler used: _____
- [x] Flashing tools used: Tasmotizer
- [x] Provide the output of command: `Backlog Template; Module; GPIO 255`:
Configuration output here:
07:55:11 MQT: OfficeCeilingLamp/stat/RESULT = {"NAME":"Sonoff T1 1CH","GPIO":[17,255,255,255,0,0,0,0,21,56,0,0,0],"FLAG":0,"BASE":28}
07:55:11 MQT: OfficeCeilingLamp/stat/RESULT = {"Module":{"0":"Sonoff T1 1CH"}}
07:55:11 MQT: OfficeCeilingLamp/stat/RESULT = {"GPIO0":{"17":"Button1"},"GPIO1":{"0":"None"},"GPIO2":{"0":"None"},"GPIO3":{"0":"None"},"GPIO4":{"0":"None"},"GPIO5":{"0":"None"},"GPIO9":{"0":"None"},"GPIO10":{"0":"None"},"GPIO12":{"21":"Relay1"},"GPIO13":{"56":"Led1i"},"GPIO14":{"0":"None"},"GPIO15":{"0":"None"},"GPIO16":{"0":"None"}}
- [ ] If using rules, provide the output of this command: `Backlog Rule1; Rule2; Rule3`:
Rules output here:
- [x] Provide the output of this command: `Status 0`:
STATUS 0 output here:
07:56:15 MQT: OfficeCeilingLamp/stat/STATUS = {"Status":{"Module":0,"FriendlyName":["SonoffT1-01"],"Topic":"OfficeCeilingLamp","ButtonTopic":"0","Power":1,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":0,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0}}
07:56:15 MQT: OfficeCeilingLamp/stat/STATUS1 = {"StatusPRM":{"Baudrate":115200,"GroupTopic":"tasmotas","OtaUrl":"http://thehackbox.org/tasmota/release/tasmota.bin","RestartReason":"Software/System restart","Uptime":"7T00:51:52","StartupUTC":"2020-02-15T06:04:23","Sleep":50,"CfgHolder":4617,"BootCount":10,"SaveCount":169,"SaveAddress":"FB000"}}
07:56:15 MQT: OfficeCeilingLamp/stat/STATUS2 = {"StatusFWR":{"Version":"8.1.0(tasmota)","BuildDateTime":"2019-12-25T12:33:25","Boot":31,"Core":"2_6_1","SDK":"2.2.2-dev(38a443e)","Hardware":"ESP8285","CR":"364/699"}}
07:56:15 MQT: OfficeCeilingLamp/stat/STATUS3 = {"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["<RemovedForPrivacy>",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["000A8008","2805C8000100060000005A00000000000000","00000200","00000000"]}}
07:56:15 MQT: OfficeCeilingLamp/stat/STATUS4 = {"StatusMEM":{"ProgramSize":566,"Free":436,"Heap":24,"ProgramFlashSize":1024,"FlashSize":1024,"FlashChipId":"144051","FlashMode":3,"Features":["00000809","8FDAE397","043683A0","22B617CD","01001BC0","00007881"],"Drivers":"1,2,3,4,5,6,7,8,9,10,12,16,18,19,20,21,22,24,26,29","Sensors":"1,2,3,4,5,6,7,8,9,10,14,15,17,18,20,22,26,34"}}
07:56:15 MQT: OfficeCeilingLamp/stat/STATUS5 = {"StatusNET":{"Hostname":"SonoffT1-01","IPAddress":"<RemovedForPrivacy>","Gateway":"<RemovedForPrivacy>","Subnetmask":"255.255.255.0","DNSServer":"<RemovedForPrivacy>","Mac":"<RemovedForPrivacy>","Webserver":2,"WifiConfig":4}}
07:56:15 MQT: OfficeCeilingLamp/stat/STATUS6 = {"StatusMQT":{"MqttHost":"<RemovedForPrivacy>","MqttPort":<RemovedForPrivacy>,"MqttClientMask":"DVES_%06X","MqttClient":"DVES_BDA845","MqttUser":"<RemovedForPrivacy>","MqttCount":7,"MAX_PACKET_SIZE":1000,"KEEPALIVE":30}}
07:56:15 MQT: OfficeCeilingLamp/stat/STATUS7 = {"StatusTIM":{"UTC":"Sat Feb 22 06:56:15 2020","Local":"Sat Feb 22 07:56:15 2020","StartDST":"Sun Mar 29 02:00:00 2020","EndDST":"Sun Oct 25 03:00:00 2020","Timezone":"+01:00","Sunrise":"07:46","Sunset":"18:21"}}
07:56:15 MQT: OfficeCeilingLamp/stat/STATUS10 = {"StatusSNS":{"Time":"2020-02-22T07:56:15"}}
07:56:15 MQT: OfficeCeilingLamp/stat/STATUS11 = {"StatusSTS":{"Time":"2020-02-22T07:56:15","Uptime":"7T00:51:52","UptimeSec":607912,"Heap":23,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":7,"POWER":"ON","Wifi":{"AP":1,"SSId":"<RemovedForPrivacy>","BSSId":"<RemovedForPrivacy>","Channel":11,"RSSI":48,"Signal":-76,"LinkCount":6,"Downtime":"0T05:33:55"}}}
- [ ] Provide the output of the Console log output when you experience your issue; if applicable:
_(Please use_ `weblog 4` _for more debug information)_
Console output here:
### TO REPRODUCE
Power cycle any connected device
### EXPECTED BEHAVIOUR
I expect the device to reconnect to my network after a powercycle, without having to reboot my router.
### SCREENSHOTS
_If applicable, add screenshots to help explain your problem._
### ADDITIONAL CONTEXT
Router: ASUS RT-AC2900
Stock firmware: 3.0.0.4.384_81351
Theese issues are never a problem when I flash ESP devices with my own custom firmware
**(Please, remember to close the issue when the problem has been addressed)**
