Possible to change state of entity?
Once again, I need your help. As I mentioned in my first post, I have poor programming skills. I’m currently trying to change the state of an entity in an automation. The state ‘wash’ exists. The sensor changes from ‘idle’ to ‘wash’ when I manually trigger it. What is the error in this code?
  - platform: state
    entity_id:
      - input_boolean.start
    to: "on"
condition: []
      entity_id: sensor.152832116377692_progress
      state: wash
When I test this, the following error message appears: extra keys not allowed @ data[‘state’]. Got None
Thank you so far.
There is no data. update_entity tells the entity to update itself, you can’t force it to accept a state it does not have. Show how you defined sensor.152832116377692_progress
And please, format your code
I didn’t define the sensor in the code at all. And it only has ICON and Friendly_Name as attributes. Do I need to define it in the code? And if yes, as what? Thank you very much for your help.
Where does it come from ?
from my dishwasher
The integration of the washing machine only provides the option to turn it on, but there is no option to start it. When I start it manually, the sensor switches from ‘Ready’ to ‘Washing’."
Setting the sensor won’t help with that. A sensor is well, only a sensor, not a command.
So it is currently not possible to implement the start. right ?
Not the way you try it. You have to see in the integration of your dishwasher if there is a way to start it.
there is no. i will start an issue on github. maype it will help me and other.
Nevertheless, thank you very much.
Although I agree with comments above about command vs. state… if you need a solution then there is the HACS ‘entities’ script
pmazz/ps_hassio_entities: Python script to handle state and attributes of existing sensors and entities (github.com)
