I have a capilar thermostatic switch which turns on Grundfos Alpha2 circulating pump in heating circuit. I need to get info if this pump has power. Maybe it will be better to buy flow meter and measure water flow…
A word of warning - even if the pump is powered, it might be stalled, displaying two dashes on the LCD. I recently experienced this situation when the room temperature was decreasing because of the stalled pump.
Better use a flow meter or optical sensor attached to the LCD. Grundfos has a product called “ALPHA Reader” but I think it works with ALPHA3 only.
Hi stevemann,
can you share scheme and coding how you’ve done it using nodemcu? I would like to identify current for safety critical consumers such as oven, heating table etc for alarming if it is ON without human attendance in the kitchen.
