Right I see.
Will check when I get back to the machine
Great development!
Right I see.
Great development!
cool:
theyâre also all still in config/custom_components/powercalc/data
should I delete that?
maybe except for the 2 json files manufacturer_device_types.json
and model_schema.json
, or are those no longer used either
i am not seeing the shelly plus plug s data file in the storage folder, though I am using that too⌠and the data model exists in the former data folder:
makes me want to check them all, wont be for tonight though. A quick look also makes me realize I dont see the Fibaro data files. Could be I excluded those because of their self metering option.
yep thats what I have in the config:
# Fibaro FGWP102 are self metering # so no device sensors are required/created
really odd, as the plus plug as is not added, Icve restarted it a few times without the yaml config I had before
# Shelly:
- entity_id: switch.toaster_keuken
# <<: &shelly
# standby_power: 0.5
# fixed:
# power: 0.8
- entity_id: switch.plus_plug_s
# <<: *shelly
- entity_id: switch.dorm_studenten
- entity_id: switch.garage_deur
- entity_id: switch.tv_garage
- entity_id: switch.symfonisk_dining
- entity_id: switch.tester
- entity_id: switch.slaapkamer_stopcontact
standby_power: 0.5
fixed:
power: 0.8
as you can see I had them as fixed power configs, but commented that now. And still this is showing as before
the slaapkamer stopcontact is a Plus 1 PM
for which no data model exists yet apparently either
as experiment, I deleted the shelly folder in the former data folder, and restarted once more: still no additional plus plug s in the powercalc_profiles folderâŚ
@Mariusthvdb I have checked the release and there was a mistake with beta.4. I accidentily created that from master branch. Which means it didnât contain any remote loading code as it should. All previous betaâs did.
I have corrected this with beta.5 now.
data folder is also removed there.
Could you try again?
ofc I had to find thatâŚ
wel glad I did and you could fix it:
before, b4:
after, b5:
folder in /custom_components/powercalc
disappeared
I do believe I found different power measurements myself:
standby_power: 0.5
fixed:
power: 0.8
Oh great you got it working.
For which did you have these measurements Plug s or Plus Plug S?
I see for the measurements AWM Fitzdirect was used: homeassistant-powercalc/profile_library/shelly/shelly plus plug s/model.json at 973005c3d5a1d1b43604117af179721f3c132e7c ¡ bramstroker/homeassistant-powercalc ¡ GitHub
Which power meter did you use? When yours is more accurate we can update the measurements in the library.
for the Plus Plug s, and non scientific⌠I used another Shelly. those readings were consistent over various devices though, and also consistent with the Plug s readings in the library. Those are seen here too, so I figured the Plus Plug s measurement to be correct too.
But⌠it might depend on other settings in the device as the Plus Plug S is also a Bt extender. depending on the configuration that could make a difference:
but I dont think we can set that in the config as its not an option we can âreadâ
As said, I also have this reading for the Shelly Plus 1PM, which isnt yet in the library
I donât have one myself, so canât do some testing or verify. Maybe I will purchase one.
I have a Zhurui PR10 meter which is very accurate also on low power levels, so than I also can do some verifications.
Hi All,
Can someone explain how to use the âCalculation enabled conditionâ?
I am trying to get a fixed energy value when my climate device (climate.living_ac) is running.
Any experience with this?
Having some issues with the new beta, shall I raise an issue in github?
This error originated from a custom integration.
Logger: custom_components.powercalc.power_profile.loader.remote
Source: custom_components/powercalc/power_profile/loader/remote.py:51
integration: Powercalc (documentation, issues)
First occurred: 4:32:20 PM (1 occurrences)
Last logged: 4:32:20 PM
Failed to download library.json from github, falling back to local copy
Logger: homeassistant.setup
Source: setup.py:398
Error during setup of component powercalc
File "/usr/src/homeassistant/homeassistant/setup.py", line 398, in _async_setup_component
result = await task
File "/config/custom_components/powercalc/__init__.py", line 238, in async_setup
await discovery_manager.start_discovery()
File "/config/custom_components/powercalc/discovery.py", line 123, in start_discovery
power_profile = await self.get_power_profile(
File "/config/custom_components/powercalc/discovery.py", line 144, in get_power_profile
self.power_profiles[entity_id] = await get_power_profile(
File "/config/custom_components/powercalc/power_profile/factory.py", line 39, in get_power_profile
library = await ProfileLibrary.factory(hass)
File "/config/custom_components/powercalc/power_profile/library.py", line 64, in factory
await library.initialize()
File "/config/custom_components/powercalc/power_profile/library.py", line 35, in initialize
await self._loader.initialize()
File "/config/custom_components/powercalc/power_profile/loader/composite.py", line 14, in initialize
[await loader.initialize() for loader in self.loaders] # type: ignore[func-returns-value]
File "/config/custom_components/powercalc/power_profile/loader/remote.py", line 31, in initialize
self.library_contents = await self.load_library_json()
File "/config/custom_components/powercalc/power_profile/loader/remote.py", line 52, in load_library_json
with open(get_library_json_path()) as f:
FileNotFoundError: [Errno 2] No such file or directory: '/config/custom_components/powercalc/../../profile_library/library.json'
There is already issue made on github:
What is the state of your climate sensor when you want the power meter to give a reading?
Hi Branski,
The data is coming in as a digital via MQTT, so either 1 or 0.
Iâm pretty sure a climate entity is not behaving like a binary sensor in HA.
Possible states of a climate entity are:
You can check in developer tools what state and attributes the entity has when you turn it on or off via MQTT.
You can use the states power option to map a certain state or attribute to a given power value.
Yes, I can get those via the climate entity. But the more reliable is the digital that I can getting directly from MQTT.
At the moment I am doing alot of âjiggery pockeryâ to map the MQTT to the HA Climate entitiesâŚ
But thatâs a different entity you are talking about than? Not the climate.living_ac
entity?
Not sure what you mean by But the more reliable is the digital that I can getting directly from MQTT.
. Youâll need that data in an entity to make it part of HA state machine and let powercalc bind to it.
Just wanted to let you all know I have worked on a new GUI for the library listing.
Where you can easily search for a given model to see if it is supported by powercalc.
Happy to hear any feedback.
Available here: https://powercalc.lauwbier.nl
Is there any way I can create a sensor that can tell me what is the power consumption of my lights(smart lights) when they are off (powered but off)?
Have a look at standby_power
This is not what I wanted. I need to rephrase a bit.
I want the total energy spent in KWh (in a year/month/week etc) while the light was off/standby.
I own smart switches like this one:
https://www.aliexpress.com/item/1005006313858972.html
I know what is power consumption for each bulb I use. Itâs specified by bulb manufacturer or I am able to measure it and power consumption is constant - bulb is not smart and itâs connected to socket switch, so we donât need to measure/guess power consumption, itâs known and never changes.
Can I provide exact power consumption in your integration settings to make it calculating using that value?
