{% set x = states('input_number.lastricosolare_duratairrigazionepostazioneidroponica13') | int + states('input_number.lastricosolare_duratairrigazionepostazioneidroponica13') | int%}
{% set ns = namespace(n_min=[]) %}
{% for h in range(0,24) if h >= now().hour%}
{% for m in range(0, 56, 5) -%}
{%- set mod0 = ((h*60) + m) % x -%}
{%- set dt = today_at(h|string~':'~ (m|string if m < 10 else '0'~m|string)) %}
{%- set ns.n_min = (ns.n_min + [dt]) if (mod0 == 0 and dt >= now()) else ns.n_min %}
{% endfor %}{% endfor %}
{{ (ns.n_min) | reject('<=', states('sensor.sun_rising') | as_datetime)
| reject('>', states('sensor.sun_setting') | as_datetime + timedelta(hours=1)) | map("string") | list }}
Getting your error now. I should be able to find the error.
Test this
try replacing sensor.sun_setting
with sensor.sun_next_setting
sensor.sun_setting is not a legit attribute
| reject('>', states('sensor.sun_next_setting') | as_datetime + timedelta(hours=1)) | map("string") | list }}
Does the code that’s working for me work for you?
{% set x = states('input_number.lastricosolare_duratairrigazionepostazioneidroponica13') | int + states('input_number.lastricosolare_duratairrigazionepostazioneidroponica13') | int %}
{{ (ns.n_min) | reject('<=', states('sensor.sun_next_rising') | as_datetime)
Boh!
We should have started there
This was the second issue
You have changed also:
Didn’t catch that, but you are 100% correct.
Anyway… no data output in my configuration
Did you switch back to the input_select and input_number entities?
No. Using your code above
Same if:
{% set x = states('input_select.lastricosolare_sceltaintervalloirrigazionidiurnepostazioneidroponica13') | int + states('input_number.lastricosolare_duratairrigazionepostazioneidroponica13') | int %}
{% for h in range(0,24) if h >= now().hour %}
Do you get results with this?
{% set x = states('input_select.choicedaywateringinterval') | int + states('input_number.irrigationduration') | int %}
I edited the previous post before your response in the sense you now requested
Why have your devices changed from the original post?
input_select.choicedaytimewateringinterval
vs input_select.lastricosolare_sceltaintervalloirrigazionidiurnepostazioneidroponica13'
Yes
in the original post I translated the name of the device into English for your better understanding.
The tests are done with the right device name
means the formula is now working. I’ll have to test the math tomorrow. In the US and its late for me.
I can only thank you for the time you dedicated to me.
Have a nice rest
