You say you āprobably wouldnāt use it to switch lights on when you enter a roomāā¦ why not? Seems like the most logical use for this. What do you use it for?
In my experience it wouldnāt respond quickly enough - you could probably bring it down to 10-15 milliseconds but I donāt know how reliable that would be and you could end up standing in the dark
Nearly everything that you use should work. But try to get something smaller than 32GB for a reasonable priceā¦ At Amazon the 16GB is more expensive than the 32GBā¦
Use what you get for a good price, Iām quite sure there is nothing on the market anymore, that would be to small.
Hi Iām wondering if anyone can help, ive got a piZero running room assistant. Every now and again the pi crashes and I need to reboot. Ive found I can use a shell integration to send a reboot command and also also creates a switch in home assistant. what I need help with is changing this switch to a press button. this is the code ive used.
