[presence] Reliable, Multi-User, Distributed Bluetooth Occupancy/Presence Detection
I use an Orbi netgear system.
Lars
I tried your new version, went from ver 4.13 to 4.26 (only copy/paste the presence.sh file and then
sudo systemctl restart presence.service
Then i get this:
VERSION=0.4.26
location/owner/kitchen/94:65:xx:xx:xx:xx {"confidence":"0","name":"Unknown","scan_duration_ms":"22","timestamp":"Fri Apr 27 2018 09:34:06 GMT+0200 (CEST)"}
location/matte_bt not_home
location/owner/kitchen/60:AF:xx:xx:xx:xx {"confidence":"0","name":"Unknown","scan_duration_ms":"23","timestamp":"Fri Apr 27 2018 09:34:06 GMT+0200 (CEST)"}
location/asa_bt not_home
Changed back to VERSION=0.4.13
location/owner/kitchen/94:65:xx:xx:xx:xx {"confidence":"100","name":"Mc3T","scan_duration_ms":"1190","timestamp":"Fri Apr 27 2018 09:34:11 GMT+0200 (CEST)"}
location/matte_bt home
location/owner/kitchen/60:AF:xx:xx:xx:xx {"confidence":"100","name":"Galaxy S6 edge","scan_duration_ms":"265","timestamp":"Fri Apr 27 2018 09:34:11 GMT+0200 (CEST)"}
location/asa_bt home
Anything ekse that needs to change?
I think you may need to update your behaviour_preferences, see above
Hi @andrewjfreyer
I now have three Zero’s running, and have adopted your script way above to keep them all up to date.
One issue to report from the current version - when a node comes up I get the following, perhaps not so useful, MQTT post -
presence& {"status":"online"}
(presence is my chosen mqtt_topicpath). Perhaps lose the & and post a hostname?
EDIT - I looked at the code and it seems that this is certainly a bug. The LWT is not working, I suspect because of it. On the upside the statuses are now retained by the broker - thanks.
If you would like a panel like this -
then (after installing CustomUI :slight_smile: ), you need to have six (assuming that you have three nodes tracking two phones) pairs of sensors like this
- platform: mqtt
  state_topic: "presence/owner/[host redacted]/[mac redacted]"
  value_template: "{{ value_json.confidence }}"
  sensors:
    upstairs_ianiphone:
      friendly_name: "Upstairs - Ian iPhone"
      value_template: >-
        {% if is_state('sensor.upstairsbt_ianiphone', '100') %}
          Seen
        {% else %}
          Not seen
        {% endif %}
plus this in your customize_glob.yaml
sensor.*phone:    # hopefully just the BT iphone sensors
  show_last_changed: true
  templates:
    icon_color: "if (state === 'Seen') return 'rgb(100, 200, 30)'; else return 'rgb(200, 100, 30)';"
and then just have a group with the 6 template sensors.
Thanks. I’ll fix this shortly.
Pardon me if this has been asked before.
Why not using fitness tracker such as Mi Band 2 as beacon? They transmit BLE signal and always on your wrist.
You may want to check out the first post in the thread …
This is exactly what I’m looking for. Do you know if this method works good with Android phones too?
@PianSom I’m getting ready to roll presence into my AppDaemon environment - have you tweaked this code significantly in the last week?
Thanks for getting me started!
Hi @eBoon
No, I haven’t. A combination of
  • other things to do,
  • waiting to see if AD MQTT gets released,
  • some concerns about bluetooth interference with lots of my IoT devices,
  • waiting for bug fixes for the presence MQTT code
  • indecision about the algorithm I was to adopt in AD
has meant that I have been rather lacking!
Look forward to seeing your code.
BTLE tokens are supported, for owner devices.
Yes, any phone from any manufacturer should work if they have successfully implemented bt4
Hello.
Looking into your solution which looks great, I read recently that iOS does MAC Address randomization for privacy reasons. How does your script circumvent that?
Thanks in advance for your help.
Couple of things:
  • Suggestion: It would be nice to be able to specify a name or alias along with the MAC, this way I can avoid seeing Unknown for devices that have not been seen. (I also sometimes see Unknown for devices that have been successfully scanned).
  • Not too major, but when called with -V, it should return the version per the Usage: blurb (I am seeing “illegal option -V”
    pi@raspberrypi:~/presence $ ./presence.sh -V
    ./presence.sh: illegal option – V
    Usage:
    presence -h show usage information
    presence -d print debug messages and mqtt messages
    presence -b binary output only; either 100 or 0 confidence
    presence -c only post confidence status changes for owners/guests
    presence -t <1,2> trigger mode; only scan in response to MQTT message posted
    to ‘presence/scan’. The payload of the message can
    include a ‘duration’ value to define how long the looping
    detection should continue. Default is 120 seconds.
    Mode 1: require a trigger for each scan
    Mode 2: require a trigger to scan only when at least
    one owner is home. When all owners are gone,
    scanning is periodic (behavior_preferences)
    presence -V print version
I am currently running 0.4.26 using mode -t2 and am triggering on all door opens - seems to be working pretty well!
Thanks again!
Randomization happens in response to a different type of request. For these name requests, the by or WiFi MAC has to be known beforehand
I must say I really appreciate the work you’ve done on this project @andrewjfreyer. Kudos! I’ve been running it on a dedicated Pi3 for a little while now with great stability. I have, however, one small thing I really appreciate getting some help on. Sometimes the trigger is a little bit slow in detecting people arriving (most important) so I would like to make some automation that triggers the scan when the door sensor is triggered. I would asume this is possible, but I’m not very familiar with MQTT and how to do this. Any help would be much appreciated.
You should be able to just use something like this to initiate a scan (assumes that you are running presence with the -t1 or -t2 option):
 service:mqtt.publish
  topic: presence/scan
Just to let you know - problem still there in 0.4.27
Which issue are you referring to?
