What a nice surprise. Will be installing it asap, as I still have some interference. I’ll be sure to share on my experiences.
If you pushed it, then i already have it, since i made a script that checks for new versions and restarts the service.
Not particularly about this versions but I had some problems, already reported by many other, like the wi-fi interference (which made me make the “restart script”, but know my most commum problem is reporting of “name”: “unknown”, which happens about 7 times out of 10 and makes me get a lot of in/out of the house HA task running.
I also have a device (IOS 11.3.x) that takes about 16min to get the out of the house, which not sure if this is connected is my 1st device on the owner file, the rest is almost instantaneous.
I also notice that the devices that are further on the house, so far I have two instances, so less used is mare unresponsive and “loses” the connection more often that the one where we are connected most of the time.
To end and also Its a requisite so Please disregard if you have no interest in it, but I was wondering if it would be possible for the script to have a “scan” feature, this is because I have a company that cleans my house, most of the times they send the same people, but some times, they send others, and I notice that some clean very well and others…not so well, and I would like to “know” who is/was in the house so that I can specific that I dont want “this, this and that” and want, “this, this and that”
PS: I also connected my pie3 to the network to try to avoid the wifi interference.
Hi @jpm - The script I reference above is different from the presence
script that is the subject of this thread. The monitor
script is currently in alpha.
No, it is not possible to scan for arbitrary devices and know who owns those devices. You will either have to know the Bluetooth MAC address of each housekeeper’s device
hii,
i am trying to get this working ,
but i have an errors
pi@raspberrypi:~/presence $ sudo systemctl status presence.service ● presence.service - Presence service Loaded: loaded (/etc/systemd/system/presence.service; enabled; vendor preset: enabled) Active: active (running) since Fri 2018-07-06 14:53:30 UTC; 4min 16s ago Main PID: 6454 (bash) CGroup: /system.slice/presence.service ├─6454 /bin/bash /home/pi/presence/presence.sh & └─6838 sleep 6 Jul 06 14:56:44 raspberrypi bash[6454]: Connection Refused: not authorised. Jul 06 14:56:44 raspberrypi bash[6454]: Error: The connection was refused.
Looks like a broker authentication issue. Have you verified your username and password?
yes
i have also tried to do pub with commend and it worked,
my broker is in different raspberry
i have changed the file permission to root and now i have different error
pi@raspberrypi:~ $ sudo systemctl status presence.service
Active: activating (auto-restart) (Result: exit-code) since Fri 2018-07-06 15:25:36 UTC; 2s ago
Process: 4904 ExecStart=/bin/bash /home/pi/presence/presence.sh & (code=exited, status=1/FAILURE)
Main PID: 4904 (code=exited, status=1/FAILURE)
Jul 06 15:25:36 raspberrypi systemd[1]: presence.service: Failed with result ‘exit-code’.
I’d suggest running manually with the debugging flag on to see what’s happening.
this is the result
pi@raspberrypi:~/presence $ bash presence.sh -d
presence 0.4.28 - Started. Performance predictions based on current settings:
Est. to verify all (1) owners as ‘away’ from all ‘home’: 30 seconds to 120 seconds.
Est. to verify one owner is ‘away’: 30 to 120 seconds.
Est. to recognize one owner is ‘home’: 0.15 seconds to 11 seconds.
DEBUG MSG: Scan result:
/owner/raspberrypi_zero/C1:0D:24:84:D5:FB { confidence : 0, name : Unknown, scan_duration_ms: 5059, timestamp : Fri Jul 06 2018 21:03:13 GMT+0000 (UTC)}
DEBUG MSG: Scanning for 0 guest devices between owner scans (no owner device is present).
DEBUG MSG: Remainder of delay before next owner scan: 6
Nice! i just got it working . Needed to install BC and Bluez_hcidump, before autostart got working (so tried manual start with -d). Now it seems to work like a charm. Will monitor coming days to see if interference is lower. Thanks again Andrew
Thanks. I know it’s probably a pain to get up and running since I haven’t written any docs for that yet. Appreciate the testing!
Make sure to run the script as root. That’s needed for a number of bluetooth services.
For those wanting to get ‘presence’ to fully integrate into HA so you have device_tracker.xxx, here is what I did to get the UI shown below in both native and lovelace.
N.B All of my ‘presence’ items are in one ‘package’ which keeps it real tidy.
- alias: Pete Occupancy
hide_entity: true
- platform: numeric_state
entity_id: sensor.pete_home_occupancy_confidence
above: 10
- service: homeassistant.turn_on
entity_id: input_boolean.pete_occupancy
- service: mqtt.publish
topic: 'location/pete'
payload: 'home'
- alias: Pete Away
hide_entity: true
below: 10
- service: homeassistant.turn_off
payload: 'not_home'
I have of course also defined a device_tracker below and then tweaked that device tracker in the known_devices.yaml
adding a name and picture.
device_tracker:
- platform: mqtt
devices:
pete_mia1_pizero: 'location/pete'
i did all the installation again in raspberry pi zero and it doesn’t work ,
i am sure it is the mosquito broker, but when pub\sub to the broker manually it is o.k.
do you have any idea for solve this issue?
Sorry, no time to test it. Maybe later this week.
I was thinking, is it a possibility that my (bluetooth) smart watch connection is interfering?
I use an Asus smartwatch and experience no interference.
Do you seen any output when you subscribe to “#” to receive all messages from your broker?
yes,
when send it manually it received at the broker
So, does that mean you don’t see any output from the script? Sounds like there’s probably a typo in your mqtt_preferences file
i have check the mqtt file and it look o.k,
this is the error from my broker when the script trying to connect:
1530944870: New connection from 192.168.31.106 on port 1883.
1530944870: Socket error on client , disconnecting.
I have installed this on four RPI’S sometimes some get stuck and the confidence level does not change, I suspect it’s power supply issues which I am trying to address. The major issue I have is latency, when I drive to my driveway, I have to wait for about 5 minutes before the Bluetooth picks me up, my Bluetooth is always on, the automation to open the garage above occupancy of 10 works, how can I increase the speed of detection and disconnection, is that dependent on the wifi speed or on settings I can impose on the sketch?
