Perhaps try stopping the montir service first.
sudo systemctl stop monitor.service
How do you guys deal with guests? I’d quite like to be able to be able to do a push notification to my phone to say “Guest 1” is on the door step. I have their BT Mac address just don’t want to do full tracking of in/out. Looking for ideas I guess and experiences.
Also…unrelated…has anyone else found to their surprise one Pi Zero W covers their entire house?! I was really surprised by this. My house is narrow but very tall. Four floors. Well, I think it’s a lot of floors. Anyway. One Pi placed on any floor seems to cope just fine with…the lot!
Hey All,
I grabbed myself some cheap bluetooth ‘Track & Find’ devices from modernhome (https://www.therange.co.uk/electricals-and-technology/gadgets/modern-home-track-and-find-two-pack/) which are detected fine (and named) if I use sudo hciscan lescan
in terminal and I can add into presence but the MQTT output seen in MQTT.fx is giving me invalid device:
{"confidence":"0","name":"Invalid device: No such device","scan_duration_ms":"5023","timestamp":"Wed Aug 29 2018 17:34:43 GMT+0100 (BST)"}
Any ideas?
I added monitor, and it is running publishing to my mqtt broker. The iphones seems to work 100%, but our Apple watches stays on a confidence of 0.
“retained”: “false”,
“version”: “0.1.482”,
“confidence”: “0”,
“name”: "ekke’s iWatch ",
“timestamp”: “Wed Aug 29 2018 20:09:23 GMT+0200 (SAST)”,
“manufacturer”: “Apple, Inc.”,
“type”: “Known Static MAC”
I also added the -b switch to monitor, but it doesn’t seem to pick up my Tile devices, however when running hcitool lescan from the command line they do show up.
Any suggestions?
Working on non-iBeacon devices now. I appreciate everyone’s patience with the slowing development pace of this project!
Hey guys, for those that use AppDaemon and this project, you can check out my project I just shared on how to easily integrate this project into HA Home Presence Appdaemon App.
Regards
Sorry Andrew is that also in relation to my post?
I feel either stupid or I have missed some docs somewhere. How do i get the debug and log going? And where do I specify the beacon mac address? I have no file named known_static_devices or something like that. Is there documentation about this? All I see is the readme and the first post here and there is nothing there about this?
Step 11 in the readme:
Once you cd into the presence dir (step 10) you can create the required files.
Hope this helps.
Thanks but I’ve already got that going. Do I put the beacon mac in the same place (owner)? and the -b flag after the mac?
Yes, generic bluetooth LE devices should be added in an upcoming release.
no need to specify an iBeacon mac address. If the device doesn’t conform to the iBeacon protocol, it won’t be reported (yet) by monitor.
Thats great. Whats the upgrade process when its available? just get the script again?
Awesome stuff! Reading through the thread I saw a lot of questions regarding room presence. Even though the RSSI is not a string indicator of distance, cant one use roll out multiple scanners and then use deduction by RSSI which one is closest, thus putting the device in a zone?
Oh okey, thanks.
Brand new HA user here…
I’ve been using Hassio on a RPiB+ for a week now and I’m trying to add in your solution.
I’ve configureed a new RPiZero W following your instructions on github.
8.[INSTALL MOSQUITTO] This only installs a client right?
10.[CONFIGURE PRESENCE]
I haven’t installed a broker yet.
Do you recommend running the broker on the RPiZero, on the hassio server via the add-on, or even a third RPi(I have several, Pine64 too)?
Are you saying they can’t run at the same time or be installed on the same pi?
I’ve installed them both on the same pi and, if I open two putty sessions, they both seem to run fine.
Does monitor run at startup or does it only run when executed at the command line?
Won’t they get in each other’s way by tying up the hardware alternately? Meaning you may get the same result eventually but it may take longer? I’m just speculating.
my questions was more of a “can’t” vs “shouldn’t” question.
I went through the entire thread and had already installed it.
I must have missed any suggestion that the monitor run separately until I hit his comment.
