Prevent template errors with entities missing required attributes
My suggestion was to reduce the amount of work performed by Home Assistant to just the minimum needed to get the job done. Then you need to select only the entities that have a defined lasr_seen attribute. Petro’s post shows how to do that with the selectattr filter and defined test.
For another example, you can refer to this one that rejects entities having a particular attribute defined:
