Problem accessing Github servers from Home Assistant
We also managed to restore connection to Github servers from our network.
So far I am not 100% sure what was the cause, but what we did was accessing the modem UI through Internet Explorer and deactivate the firewall there. This was the only way to access our Technicolor TC4400 admin dashboard… We also set DNS addresses inside Home Assistant but I don’t think this helped in solving the issue since our router already had proper DNS settings (tested with 1.1.1.1 and 8.8.8.8).
I’ve also seen some other users claim Githubs server issues have been solved yesterday, so this adds to the overall confusing situation…
Same problem from China since January. Cant update to the latest. At the beginning, thought it was caused by GFW. But when I tried to get access to http://ghcr.io/ and https://github.com/home-assistant/supervisor/pkgs/container/amd64-hassio-supervisor on my laptop, it’s 100% accessible.
No luck in changing dns to 1.1.1.1.
Folks, I have been seeing this problem for awhile when I attempt to manually trigger an update.
I have tried the DNS update mentioned above which resulted in no change. My understanding is that ha supervisor will automatically update which seems to be happening since I am at 2023.09.2 but when I was attempting to trigger update to 2023.10.0 (version: Supervisor Version 2023.09.2, Ha OS 2023.10.3, HA Core 2023.1.4) it times out.
From the Home Assistance:Terminal I attempt the following:
This doesn’t look like a DNS issue. Any other thoughts on this topic?
Seems an Internet related latency issue. Try another day to see if it goes away. Your location to the closest GitHub CDN has an issue. Randomly try after a few hours/days.
I’ve been getting this message for days now when trying to update. I’m also getting critical error.
I’ve tried the option on the HA page the error directs me to (Supervisor was not able to update - Home Assistant) including changing my DNS this does not help. Like others there seems to be a problem connecting to github??
Any assistance is appreciated.
Here is an excerpt from my log:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/hassio/update.py:260
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 8:57:10 PM (4 occurrences)
Last logged: 9:08:17 PM
[140579869227216] Error updating Home Assistant Supervisor: Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2023.10.0: 404 Client Error for http+docker://localhost/v1.42/images/ghcr.io/home-assistant/amd64-hassio-supervisor:2023.10.0/json: Not Found ("No such image: ghcr.io/home-assistant/amd64-hassio-supervisor:2023.10.0")
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 258, in async_install
    await async_update_supervisor(self.hass)
  File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 52, in _wrapper
    raise HassioAPIError(data["message"])
homeassistant.components.hassio.handler.HassioAPIError: Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2023.10.0: 404 Client Error for http+docker://localhost/v1.42/images/ghcr.io/home-assistant/amd64-hassio-supervisor:2023.10.0/json: Not Found ("No such image: ghcr.io/home-assistant/amd64-hassio-supervisor:2023.10.0")
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 205, in handle_call_service
    await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1965, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2005, in _execute_service
    return await cast(
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 235, in handle_service
    return await service.entity_service_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 848, in entity_service_call
    response_data = task.result()  # pop exception if have
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1192, in async_request_call
    return await coro
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 892, in _handle_entity_call
    result = await task
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 156, in async_install
    await entity.async_install_with_progress(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 414, in async_install_with_progress
    await self.async_install(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 260, in async_install
    raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Supervisor: Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2023.10.0: 404 Client Error for http+docker://localhost/v1.42/images/ghcr.io/home-assistant/amd64-hassio-supervisor:2023.10.0/json: Not Found ("No such image: ghcr.io/home-assistant/amd64-hassio-supervisor:2023.10.0")
type or paste code here
Turns out it was a storage issue. Ran out of space.
Hello, did you solve the problem? I have the same problem now
Thanks LG
