Hi
Running latest hass.io on rpi3b, problems startad like two weeks ago when I started over and flashed my SD-card and tried to add z-wave like I always do.
zwave:
usb_path: /dev/ttyACM0
Cant get it to work, is there anyone that can connect to my Mac using TeamViewer and see if you can find the problem.
I just bought a new Z-stick and the problem is the same.
LOG:
2018-11-22 22:35:14.909 Always, OpenZwave Version 1.4.3254 Starting Up
2018-11-22 22:35:15.766 Info, Setting Up Provided Network Key for Secure Communications
2018-11-22 22:35:15.766 Warning, Failed - Network Key Not Set
2018-11-22 22:35:15.766 Info, mgr, Added driver for controller /dev/ttyAMA0
2018-11-22 22:35:15.767 Info, Opening controller /dev/ttyAMA0
2018-11-22 22:35:15.767 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2018-11-22 22:35:15.768 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2018-11-22 22:35:15.768 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2018-11-22 22:35:15.768 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2018-11-22 22:35:15.769 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2018-11-22 22:35:15.769 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2018-11-22 22:35:15.769 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2018-11-22 22:35:15.769 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2018-11-22 22:35:15.769 Detail, contrlr, Notification: DriverFailed
