Been trying for days to get a mqtt connection with an arduino MKR Wifi 1010 with a MKR ETH shield.
I have HA running on a Linux virtual machine.
I use the mosquitto mqtt broker. The diagnostics show:
"integration_manifest": {
"domain": "mqtt",
"name": "MQTT",
"codeowners": [
"@emontnemery",
"@jbouwh"
"config_flow": true,
"dependencies": [
"file_upload",
"http"
"documentation": "https://www.home-assistant.io/integrations/mqtt",
"iot_class": "local_push",
"quality_scale": "gold",
"requirements": [
"paho-mqtt==1.6.1"
"is_built_in": true
"data": {
"connected": true,
"mqtt_config": {
"broker": "core-mosquitto",
"port": 1883,
"username": "**REDACTED**",
"password": "**REDACTED**",
"keepalive": 60,
"tls_insecure": false,
"protocol": "3.1.1",
"transport": "tcp",
"discovery": true,
"discovery_prefix": "homeassistant",
"birth_message": {
"topic": "homeassistant/status",
"payload": "online",
"qos": 0,
"retain": false
"will_message": {
"payload": "offline",
"qos": 0,
"retain": false
"devices": [],
"mqtt_debug_info": {
"entities": [
"entity_id": "sensor.mkr_humidity",
"subscriptions": [
"topic": "MKR1010_1/humidity",
"messages": []
"discovery_data": {
"topic": "",
"payload": ""
"transmitted": []
"entity_id": "sensor.mkr_temperature",
"subscriptions": [
"topic": "MKR1010_1/temperature",
"messages": []
"discovery_data": {
"topic": "",
"payload": ""
"transmitted": []
"triggers": []
My arduino code:
#include <SPI.h>
#include <Ethernet.h>
#include <DHT.h>
#include <PubSubClient.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 69, 10);
IPAddress gateway(192, 168, 69, 1);
IPAddress subnet(225, 225, 225, 0);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
#define mqtt_server "196.168.69.203" // Home Assistant IP address
#define mqtt_user "HAmqtt" // Home assistant user name
#define mqtt_password "saxopraan2.0" // Home Assistant password
#define DEVICE_ID "MKR1010_1" // give a unique name to your device
//MQTT topics: humidity and temperature
String humidity_topic;
String temperature_topic;
#define LED 2 // Send data led pin
#define READ_DELAY_MS 60000 // 1 mn between reads (in milliseconds)
#define DHTPIN 6 //Pin of your DHT sensor
#define DHTTYPE DHT11
DHT dht(DHTPIN,DHTTYPE,30);
int ledState = 0;
EthernetClient ethClient;
PubSubClient client(ethClient);
void setup() {
pinMode(LED,OUTPUT);
Serial.begin(19200);
delay(5000);
Serial.println("debug 1");
humidity_topic = String(DEVICE_ID) + "/humidity";
temperature_topic = String(DEVICE_ID) + "/temperature";
setup_eth();
client.setClient(ethClient);
client.setServer(mqtt_server, 1883);
delay(200);
void setup_eth() {
delay(10);
Serial.println("debug 2");
ledToggle();
Serial.println("debug 3");
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip, gateway, subnet);
// Check for Ethernet hardware present
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
while (true) {
delay(1); // do nothing, no point running without Ethernet hardware
if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable is not connected.");
// start the server
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
ledToggle();
void reconnect() {
int mqttFailuresNumber = 0;
ledToggle();
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect(DEVICE_ID, mqtt_user, mqtt_password)) {
Serial.println("connected");
} else {
if (mqttFailuresNumber==3) {
//reset wifi if too many mqtt failures
//re-initialize the Wifi connection, whatever happened
//client.stop();//WiFi.end();
Ethernet.begin(mac, ip);//status = WiFi.begin(ssid,pass);
} else {
mqttFailuresNumber++;
Serial.println(mqttFailuresNumber);
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
ledToggle();
long lastMsg = 0;
float temp = 0.0;
float hum = 0.0;
float diff = 1.0;
void loop() {
if (!client.connected()) {
reconnect();
client.loop();
long now = millis();
if (now - lastMsg > READ_DELAY_MS) {
ledToggle();
lastMsg = now;
float newTemp = dht.readTemperature();
float newHum = dht.readHumidity();
if(!isnan(newTemp)) {
temp = newTemp;
Serial.print("Temperature:");
Serial.println(String(temp).c_str());
client.publish(temperature_topic.c_str(), String(temp).c_str(), true);
if(!isnan(newHum)) {
hum = newHum;
Serial.print("Humidity:");
Serial.println(String(hum).c_str());
client.publish(humidity_topic.c_str(), String(hum).c_str(), true);
ledToggle();
// change the wifi connetcion led status
void ledToggle(){
if (ledState == 0){
digitalWrite(LED,HIGH);
delay(10);
ledState = 1;
} else {
digitalWrite(LED,LOW);
delay(10);
ledState = 0;
The ethernet connection is OK. I can ping it.
The serial moniotor shows:
debug 1
debug 2
debug 3
server is at 192.168.69.10
Attempting MQTT connection...1
failed, rc=-2 try again in 5 seconds
Attempting MQTT connection...2
Attempting MQTT connection...3
Attempting MQTT connection...failed, rc=-2 try again in 5 seconds
The Mosquitto broker log returns:
2023-05-07 21:50:07: New connection from 172.30.32.2:38188 on port 1883.
2023-05-07 21:50:07: Client closed its connection.
I have no idee where this IP commes from as I defined my arduino as 192.168.69.10. I can ping both.
Thanks in advance for any help debugging this.
P.S. I know a MKR Wifi 1010 is overkill for the application, but it’s a test setup for a bigger project to read data from a Finder energy meter that currently publishes to Arduino iot Cloud.
