Problem getin Alexa work with intents
yes still 405 not allowed
Sorry I am out of ideas hereā€¦there must be something that I am not thinking of right nowā€¦just donā€™t know what. Just double check all your settings in the amazon development consoleā€¦maybe even try starting from scratch with a new skill on alexa?
Sorry for not being of much help.
~Cheers
is there a way to lacily test if hass Alexa component is working correct? Like for lights or media player where i can add a json object for testing.
Maybe you have an unsupported Key in your API-Password. I had the same Problem, with a # in my Password. Changing my Password to contain only Letters and Numbers solved it.
Head over hear for more information:
the api password is the same i use to login to hass Gui correct?
Yes, you also provide it in the Link on the Amazon Developer Console.
ok got it now, the response came after i made port redirect from 443 to hass port. So problem was that the url uses a port. Thats a problem because i also have other website on the same server that want to use https and not only hass.
Any idea how to use url like https://my.url.com:8123/api/alex?api_password=XXXXXXX
He,
this is not possible. Amazon only allow using Port 443.
Just as documented here in the Requirments Section:
https://developer.amazon.com/public/solutions/alexa/alexa-skills-kit/docs/developing-an-alexa-skill-as-a-web-service#requirements-for-your-web-service
I donā€™t think this is possible with amazon. But you should be able to use a reverse proxy like nginx to map different locations.
~Cheers
ok thanks for the help, extra thanks to @PhyberApex :slight_smile:
I will try with that at the moment
Completely OT, but @PhyberApex - TIL that English was your second language. Never would have guessed. Iā€™m so disappointed with my country; it seems like everyone I meet outside it speaks multiple languages and most Americans canā€™t even speak their own language well enough.
@rpitera You are now officially known as OT-King. But thank you for your kind words. My English skills probably originate from the amount of anime I watched as a kid (and still do) and the fact that I watch all movies (and tv shows) in their original audio if possible (I donā€™t even have my tv plugged into cable at this point). Also I am a software engineer so English is a must.
~Cheers
Iā€™m sorry. I should have PMā€™d you but I wanted to complement you in the clear. :wink:
Iā€™m having the same issue, but only with certain intents. Simple ones, like this:
SpeakIntent:
  speech:
    type: plaintext
    text: This is magic
ā€¦work fine and get a ā€œgoodā€ response back from Amazon:
  "version": "1.0",
  "response": {
    "outputSpeech": {
      "type": "PlainText",
      "text": "This is magic"
    "speechletResponse": {
      "outputSpeech": {
      "shouldEndSession": true
  "sessionAttributes": {}
However, more difficult ones ā€“ like situations where long-running scenes are in play ā€“ will ā€œworkā€ (in that they do the correct action in our home), but Amazon will give me an error. For example, this intent:
ActivateSceneIntent:
    service: scene.turn_on
    data_template:
      entity_id: scene.{{ Scene | replace(" ", "_") }}
  speech:
    type: plaintext
    text: !include alexa-confirmations.yaml
ā€¦has the aforementioned wonky behavior when I run my ā€œGood Nightā€ scene:
entities:
  alarm_control_panel.simplisafe:
    state: armed_home
  cover.garage_door:
    state: closed
  lock.front_door_locked:
    state: locked
  lock.garage_door_locked:
    state: locked
  group.living_room_lights:
    state: off
  group.living_room_tv:
    state: off
ā€¦which returns this Amazon response:
The remote endpoint could not be called, or the response it returned was invalid.
My gut tells me that since the ā€œeasierā€ one works, thereā€™s some sort of timeout going on.
Do other scenes work? Do any of your scenes work? How about a simple scene where a single light is turned on?
This may help rule some things out.
Great question ā€“ yes, other scenes work (i.e., the action is performed and Amazon returns the correct response). For instance, this scene works as expected:
scene:
  entities:
    switch.media_center:
      state: on
    remote.watch_roku:
      state: on
    script.switch_roku_to_plex:
      state: on
switch:
  platform: wake_on_lan
  mac_address: "4C:AE:6A:1234: :90:D4"
  host: "media-center.lan"
remote:
  platform: harmony
  host: harmony-hub.phil.lan
  activity: 22580034
script:
  sequence:
    - service: 'media_player.select_source'
        entity_id: 'media_player.roku_yp005n794105'
        source: 'Plex'
Iā€™m kinda stumped then - your code looks fine to me. Iā€™m guessing it is more in the config of the connection somehow.
What do you mean by ā€œI made port redirect from 443 to hass portā€?
What all did you change?
Did you change the url to amazon to be https://myurl.com:443ā€¦ , then foward 443 to 8123 in your router?
or did you leave the url as httpsL//my.url.com:8123ā€¦ and forward 443 to 8123 in your router?
Iā€™m having a very similar issue I think.
Hey, @Paul_Kline. Did you ever get your issue figured out? I have the same issue.
