how to check if I have this?
Hassbian is Raspbian based, which uses systemd.
thanks. Do I have to modify the file? Where is it?
Just run, as root (so, prefix with sudo if youâre not already root):
systemctl disable mosquitto
you mean one time only, after the next reboot will not start again?
Correct. Can I suggest a read of the manual page for systemctl (man systemctl
to see what the options are, and what they do).
if you donât have broker: in your configuration
so at least I understood.
All this is very confusing,
if you put
mqtt:
is embedded
if you put
mqtt:
broker: ipaddress
then is mosquitto ⌠go figure
Hi I had the same issue with the front end but I change my Config to:
mqtt:
username: !secret mqtt_pass
password: !secret mqtt
keepalive: 60
mqtt: # Mqtt Broker
broker: 192.168.1.XXX
port: 1883
client_id: home-assistant-1
keepalive: 60
hope this helps
