Problem with ESP32 and WIFI
I doubt you can resolve brownouts with any reset.
Afaik it’s hardware issue, operating voltage going too low.
I expect you didn’t play with wifi output_power setting.
I don’t know. I’ve tried so much that I don’t know anymore!:face_with_hand_over_mouth::flushed::confused: Can I fix that?
Just upload base configuration and observe logs if it’s giving brownouts…
I would try to add a new device in esphome, connect the esp32 to your pc and upload the stub via usb.
upload the stub??
When you add a new device the firmware that is created is minimal. It prepares for later update via OTA.
I have done it several times! But no improvement!!
I’m running out of ideas, sorry. May be it is damaged.
Sounds like time for the bin. These things are cheap enough. (I hate the throw away society, if you have a recycling service, use that bin)
