Problem with new Zoneminder component
I don’t known wich path it does not create, but the ZM api is working with other app. So in my opinion the problem is on HA side.
also facing same problems .
HA version 0.56.0
Ubuntu server 16.04
Zoneminder v1.30.4
My HA config :
zoneminder:
  host: 192.1.2.3
camera:
  - platform: zoneminder
For now i just use an “pane_iframe” :
panel_iframe:
  zoneminder:
    title: 'ZoneMinder'
    url: 'http://192.1.2.3/zm/'
It works OK .
hmm working fine here, with the lastet version of all, instead of Installing ZM directly on Ubuntu i use docker:
Ubuntu 17.04 with docker
HASS 0.56.2
ZM 1.31.1
https://forums.zoneminder.com/viewtopic.php?f=37&t=26596
my settings in konfiguration.yaml:
zoneminder:
  host: 192.168.1.4:8000
  path_zms: /cgi-bin/nph-zms
camera:
groups.yaml:
default_view:
  view: true
  icon: mdi:home
  entities:
  - group.Zoneminder
and
Zoneminder:
  view: true
  entities:
  - camera.east_terasse
  - camera.indk0rsel
the only problem i have, is the event in the logbook is not using the event when clicked on but instead i see a “now live feed”
did you solve_
I can see the cameras but no devices (no sensor)
Changing the path from
/zm/
to
worked for me.
i’m running zoneminder on debian.
Thanks!!!
Hello
I’ve just added zoneminder component to HA, and I’ve get the states, and names of cameras, access tokens, but when I add the camara to GUI there is no picture but only: image not available.
Here is my configuration.yaml
zoneminder:
host: 192.168.1.229:8082
path: /zm/
username: admin
password: *********
camera:
  • platform: zoneminder
Why is this happening?
I was having the same issue as you @Woj , then I set my config to this and got it to work:
zoneminder:
  host: 192.168.1.***
  username: admin
  password: ********
camera:
