Problem with TP-Link HS200 switch
This is being worked on.
Reverting to an older version is the only way for now:
0.34.3 for HS100/110
0.30.2 for HS200
hi kirichkov, no mean to rush but to check any idea when the fix will probably be in? unfortunately i can’t go down to any version below 0.35 as that will cease the support for broadlink component :frowning:
Preparing it, some minor issues to iron out on the underlying library.
cool. thanks for the update :slight_smile:
The most up to date code has been merged in HASS dev so it should make it for the next release - 0.36. HS200 switches working AND updates the UI when interacting manually with the plug or via the app!
Keep in mind that because this component relies on polling, updates to the UI won’t be instantaneous! Worst case scenario with default configuration is 30 seconds. This has always been the case!
@kirichkov, this is working perfectly now. Thank you so much for your work on this.
