Running 50.2 on an AIO RPi3. Getting the same errors on my amcrest IPM-HX1W. Running camera component with ffmpeg and rtsp. I still get the following errors even though it works 100% of the time.
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/haffmpeg/core.py", line 114, in open
stderr=stderr
File "/usr/lib/python3.4/asyncio/subprocess.py", line 226, in create_subprocess_exec
stderr=stderr, **kwds)
File "/usr/lib/python3.4/asyncio/base_events.py", line 866, in subprocess_exec
bufsize, **kwargs)
File "/usr/lib/python3.4/asyncio/unix_events.py", line 174, in _make_subprocess_transport
yield from transp._post_init()
File "/usr/lib/python3.4/asyncio/base_subprocess.py", line 106, in _post_init
proc.stdin)
File "/usr/lib/python3.4/asyncio/base_events.py", line 797, in connect_write_pipe
yield from waiter
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
concurrent.futures._base.CancelledError
2017-08-07 12:01:03 ERROR (MainThread) [aiohttp.server] Error handling request
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/aiohttp/web_protocol.py", line 422, in start
resp = yield from self._request_handler(request)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/aiohttp/web.py", line 306, in _handle
resp = yield from handler(request)
File "/usr/lib/python3.4/asyncio/coroutines.py", line 143, in coro
res = yield from res
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/http/ban.py", line 58, in ban_middleware_handler
return (yield from handler(request))
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/http/__init__.py", line 424, in handle
result = yield from result
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/camera/__init__.py", line 340, in get
response = yield from self.handle(request, camera)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/camera/__init__.py", line 360, in handle
image = yield from camera.async_camera_image()
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/camera/ffmpeg.py", line 60, in async_camera_image
extra_cmd=self._extra_arguments)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/haffmpeg/tools.py", line 78, in get_image
image, _ = yield from self._proc.communicate()
AttributeError: 'NoneType' object has no attribute 'communicate'
Is the ffmpeg camera component still the preferred method for Amcrest Cameras in Home Assistant (currently on build 0.84.6)?
I have 4 cameras set up in my instance and Iâm seeing Retrying errors ever few minutes in the logs. The cameras are supplying the feeds, but I havenât found a way to prevent the connection errors.
Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by âConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7f4ce4b8c198>, âConnection to 10.0.0.184 timed out. (connect timeout=3.0)â)â: /cgi-bin/storageDevice.cgi?action=getDeviceAllInfo
Iâve added an RTSP ffmpeg feed as well for testing. It works, but the quality doesnât appear to meet what I get from the Synology camera component. I havenât added 2 additional licenses, so Iâm exploring options (like Zoneminder) before committing to Synology.
I only use the RTSP ffmpeg feed for my Amcrest, what URL did you feed into ffmpeg?
I use /cam/realmonitor?channel=1&subtype=0 that is my 1080p stream into HA. For my zoneminder instance I use /cam/realmonitor?channel=1&subtype=1 which has a lower resolution but strictly for motion detection in zoneminder.
Using /cam/realmonitor?channel=1&subtype=0 as well, but since I have IP3M-HX2, I have an output of 2304x1296 selected currently.
My HA instance is in Docker on a Synology NAS. Maybe itâs a setting I havenât found yet, but it feels like like the RTSP feed is slower to update than the standard Amcrest one (despite the errors generated in my logs). and both are slower than the Surveillance Station feeds. Still trying to figure out the best way to integrate my Amcrest cameras into my setup.
Also, whatâs the proper syntax for multiple camera RTSP feeds? I have a 24-72 hour delay between reboots due to Z-wave battery powered devices, so I canât troubleshoot adding new components quickly. Should it look like this? Or can you skip the second â-platform: ffmepgâ line?
platform: ffmpeg
input: !secret rtsp_url_living_room
name: Living Room RTSP
Reboot of my HA system to add/modify config entries, like ffmpeg.
Appreciate the clarification regarding the ffmpeg feed. What should be the expected result when you click into an image? Should it then go to a live stream? Or should that be delayed as well.
