No problems with the UI and updated since the last update none of them are working home assistant is not finding anything at this moment in time playing up currently since the latest update I’ve tried for an on GitHub but no one is helpful who assistance isn’t working
Your description is inadequate for anyone to help. Try reading this How to help us help you - or How to ask a good question
Do you see any errors in the log page? Can you reach the log page? Which version did you have? Which version did you update to? Can you post a link to your config? Have you read all the breaking changes for all updates between your version and the new version? Do you use any of those things mentioned in the breaking changes?
2020-07-08 08:36:29 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=4 from 2020-07-08 07:32:22.042443)
2020-07-08 08:36:39 ERROR (SyncWorker_4) [hass_nabucasa.acme] Can’t order a new ACME challenge: urn:ietf:params:acme:error:rateLimited :: There were too many requests of a given type :: Error creating new order :: too many certificates already issued for exact set of domains: vks3w8i23q1ji87jp13722bqzeix8a4q.ui.nabu.casa: see https://letsencrypt.org/docs/rate-limits/
2020-07-08 08:36:40 WARNING (MainThread) [slixmpp.stringprep] Using slower stringprep, consider compiling the faster cython/libidn one.
2020-07-08 08:36:44 WARNING (MainThread) [homeassistant.components.mobile_app.notify] Found duplicate device name iPhone
2020-07-08 08:36:44 WARNING (MainThread) [slixmpp.basexmpp] Legacy XMPP 0.9 protocol detected.
2020-07-08 08:36:45 WARNING (MainThread) [slixmpp.basexmpp] Legacy XMPP 0.9 protocol detected.
2020-07-08 08:36:50 ERROR (MainThread) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2020-07-08 08:40:47 WARNING (MainThread) [homeassistant.components.ring] Error fetching Ring device data: (‘Connection aborted.’, RemoteDisconnected(‘Remote end closed connection without response’))
2020-07-08 08:45:49 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.140655464949648] Error handling message: expected str for dictionary value @ data[‘service’]. Got None
2020-07-08 08:46:51 WARNING (MainThread) [homeassistant.components.ring] Error fetching Ring device data: (‘Connection aborted.’, RemoteDisconnected(‘Remote end closed connection without response’))
2020-07-08 08:46:51 WARNING (SyncWorker_0) [homeassistant.components.ring] Error fetching Ring health data for device 3881d733cc46: (‘Connection aborted.’, RemoteDisconnected(‘Remote end closed connection without response’))
2020-07-08 08:47:27 ERROR (SyncWorker_1) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2020-07-08 08:48:53 WARNING (SyncWorker_1) [homeassistant.components.ring] Error fetching Ring health data for device 3881d733cc46: (‘Connection aborted.’, RemoteDisconnected(‘Remote end closed connection without response’))
2020-07-08 08:49:54 WARNING (SyncWorker_1) [homeassistant.components.ring] Error fetching Ring health data for device 3881d733cc46: (‘Connection aborted.’, RemoteDisconnected(‘Remote end closed connection without response’))
Seriously, this barely makes any sense. If you want help, take a little more time to compose a readable question. We don’t need perfect English, but just try to read that back to yourself.
Frits asked you several relevant questions, and you didn’t answer any of them but just posted a section of log that’s no use at all.
Take a deep breath, explain your exact problem clearly using punctuation and sentences, and you’ll find people willing to help here if you’re willing to put the work in to ask a coherent question.
