PSA: 2024.7 recorder problems
If one of the above PRs doesn’t fix your system, it will be a different solution from the PRs / issue reports posted above. In this case, the developer who looks into the problem will need a copy of an affected database since it presents a problem that has yet to be seen. If you can share your database, please open a fresh GitHub issue.
