PSA How to configure Proxmox for lower power usage
in configuration.xml you can add the current gov as a sensor in order to verify the current cov used.
There is also a switch defined which lets you toggle gov from performance to powersave.
  - platform: command_line
    command: "cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor"
switch:
    switches:
      cpu_governor_performance:
        friendly_name: CPU Governor (performance)
        command_on: "echo \"performance\" | tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor"
        command_off: "echo \"powersave\" | tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor"
