PSA How to configure Proxmox for lower power usage
my i5-9500 also scales when needed.
Hey, I’m quite new to Proxmox and just wanted to ask if someone can give me a more detailed guide on how to do this. I don’t know what a node nor I know what a shell is. Hope someone can help me, thanks
Click on the Node which is your server hosting the virtual machines and then click on Shell to open up a command shell where you can type in the commands to change to the powersave governor.
This video may help you Proxmox VE Full Course: Class 12 - The Command-Line Interface - YouTube
This is high. Maybe check in BIOS of C-states are enabed?
I have two of these, and it can idle at 10 W. Personally, I’ve went from 36 W average to 19 W average after switching to powersave.
Optiplex 3050
i5-6500
1x M2 SSD
2x RAM stick
1x enterprise Toshiba HDD
2x USB adapters
~3-4 VMs running
Thanks for posting this. I was able to cut ~10-12 w by simply switching to ondemand. Granted my system is above a lot of what is posted but the Proxmox server (14 core w/ 128 GB of RAM) is running my firewall (with 2 - 10Gbps interfaces), a TrueNAS server with 16 TB of storage, frigate for 3 HD cameras, etc. Idle load is about 50w. Operational used to be slightly over 100w and now it is sitting at 90w. I’ll take a 10% improvement for flipping a few settings. Thanks!!!
The config change was a bit after noon on 15 Nov. Initially I did powersave but the average from ondemand is nearly the same so seems like the better choice for my system.
Golden tip! Thanks!
How are monitor the power consumption using HA? Proxmox integration?
I am using an external power meter like https://a.co/d/eBqGuxJ
I`m running Z4G4 HP Workstation with W-2145
The difference between performance and power safe is 20W
echo “powersave” | tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor
echo “performance” | tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor
