Currently, I have several remote ESPHome devices connected via MQTT. The entity names for those devices are prefixed with the device name and I am getting similar messages this time.
Should I change the entity name in ESPHome and update the firmware for these existing devices?
I agree that this has been handled really poorly. In the end, this wasted a lot of everyones time, but no big issues coming out of this. I hope Nabu Casa learns from this for future releases. And thanks to @petro ro for clearing stuff up.
Iām not sure what happened. Perhaps not entirely related to this change.
I installed 2023.8, noticed that my SleepAsAndroid MQTT (and HASS AGENT, I think) stopped working, so attempted to restore a backup. Which failed for whatever reason I didnāt catch.
So I decided to be patient and let them be broken for now, and went ahead installing 2023.8.1. After which I noticed the above issue, that my entire zigbee network was essentially empty from within z2m (edge branch, last updated who knows when last year).
The devices/entities for the missing z2m devices all appear within my mosquito broker with This entity is no longer being provided by the mqtt integration. and I no longer get the repair warning list containing these devices.
No idea what caused this, or if it can be quickly fixed. Restoring a backup of the add-on did not resolve the issue. I have to assume that my zigbee co-ordinator itself was wiped somehow? Rebinding, naming etc several dozen zigbee devices is going to be a nightmare.
I wonder if anyone else has experienced a similar problem.
Yeah my apologies, figured that might be the case. Posted just in case I was missing some linking cause, as updating to 2023.8 was the initiator for my problem to appear.
My Ā¢0 this topic. The HA announcement and warning itself are far from clear and MQTT docs are not updated at all. And this is the ONLY complain from me.
I run my own MQTT device with discovery, so I googled around and found this topic. It makes everything clear but only if you can ignore most of whining. It looks like only handful users actually understand the case.
For me the change is very logical and welcome. It makes device name important and part of entity name but also removes some unnecessary duplication. It is also well engineered as it doesnāt change any existing entity id (unless discovery message shows it like a new device).
I donāt understand users who call HA developers to let device developers āfixā their software beforehand. You canāt change MQTT discovery messages before HA change without big negative impact in entity names. Think about it and you can figure out yourself (or read along) what would happen in this case.
Only possible problem I see here is with users who donāt upgrade HA. After MQTT discovery message change in their devices (or running newer version of Zigbee2MQTT or other software), their entity naming for new devices will be quite bad because HA versions before 2032.8 didnāt add device name to the entity name.
Assume your device name is āDeviceā and sensor name is āSensorā. Depending on version of HA and MQTT discovery message, this is what happens:
Old MQTT, old HA: sensor.device_sensor
Old MQTT, new HA : sensor.device_device_sensor ā this is what a warning is about
New MQTT, new HA: sensor.device_sensor
New MQTT, old HA: sensor.sensor ā this is what happens when other devs change before HA
Now when you are in the last combination all your new temperature sensors will be just temperature_2, temperature_3 and so on with all called just āTemperatureā instead of kitchen_temperature or shelly_livingroom_temperature.
I think Iāve corrected all my devices that publish HA discovery messages to MQTT. After Iāve clicked ignore for the warning messages, is there a way to retrigger the check to confirm Iāve fixed them correctly?
Wel, I took action. Tried to restore full backup from before the upgrade. Didnāt work. Took me a full day to get it up and working again. Was not amused!
Iām using HASS.Agent and corrected sensor names. After which, I noticed in HA settings, duplicate sensors were created, this time with āmqtt_ā. All my original sensors, which I corrected the names for, suddenly do not work. Iām so confused by this change. Honestly, itās changes like this that make me want to not spend my hours working w/ HA any longer. Iāve been a huge supporter, use HA Cloud, etc.
If you read the main post, youād notice that you canāt do anything other than contact the upstream dev to fix their software. And click ignore on the repair.
Hi, Iāve received the error messages and spent three hours āresolvingā the reported errors i.e. making the entity_id names unique from the MQTT names AND having to change EVERY Automation and Script where each entity_id is used. Three hours of my life, which will NEVER be recovered.
I do not blame this Developer - I blame the HA Core Developer(s) who have made this necessary:
What is wrong with having the SAME entity_id name and MQTT name?
It seems sensible to use the SAME name to co-relate the entitiy_id with the MQTT name.
Having the SAME entity_id and MQTT name has been working without fault for a long time so what is the fault that has to be fixed?
Have these HA Core Developer(s) not heard the adage - āif it aināt broke, donāt fix itā?
It appears to be change for change sake or pedantry but no useful purpose - the worst sort of Development change!
Where is Change Control in the Home Assistant Core?
Where can I register a complaint about this apparently unnecessary action on the part of the HA Core Developer(s)?
As you can probably guess; the waste of three hours of my life for no genuine purpose is NOT appreciated, so please excuse me for my rant.
I hadnāt seen your post when I received and addressed the āissuesā listed in the Error messages. Had I done so, I could have just Ignored the Error messages as you advocated.
Thank you for pointing out that Name does not equate to entity_id. This highlights my error in writing this post: The Error message states āSome MQTT entities have an entity name equal to the device nameā, so I should have referred to entity name NOT entity_id.
Your last two points are appreciated - if only I had seen your Post BEFORE receiving and dealing with the Error messages.
Best regards to you for 1. Your warning Post (which I didnāt see in time), for your excellent Response Time (which is very much appreciated, and for your Informative response.
