That is the solution! Perfect!!!
Another way would be to insert a Template Condition at the beginning of the sequence. The template would confirm the length of lights_off
is greater than zero. If not, the template evaluates to false
and execution is halted.
Something like this:
alias: example 1
variables:
lights_off: >
{{ expand('group.living') | selectattr('state','eq','off')
| map(attribute='entity_id') | list | join(', ') }}
sequence:
- condition: template
value_template: "{{ lights_off | length > 0 }}"
- service: light.turn_on
entity_id: "{{ lights_off }}"
- delay: '00:03:00'
- service: light.turn_off
mode: single
Ok, I have checked the template solution. It worked also perfectly!
using the exact, well almost, code myself here:
sequence:
entity_id: >
{% set lights_on =
expand('group.all_inside_lights')|selectattr('state','eq','on')
|map(attribute='entity_id')|list %}
{{lights_on|join(', ') if lights_on|length > 0 else 'none'}}
I was seeking to find a reason the new variables:
technique would be the preferred option. So rewrote my own automation like you suggest here. Which looks very clean. Still, I canât help wondering why we would need to set a second variable in the variable itself. Wouldnât that be more complex inside the HA internals? Maybe fractional, but still, as an academic discussion?
My understanding is itâs a template like any other template. For a more detailed analysis, someone from the development team is better qualified to answer the question.
You arenât setting a second variable⊠Youâre setting a variable in the automation. And youâre setting a variable inside the template. 2 very different things.
No, its a temporary memory address. And garbage collection will delete it after some time. It adds nothing to the computation time, it just makes your ram go up a smidge (bytes) until garbage collection removes it. Youâre definitely overthinking this.
Thanks for the help @petro!
Using the âAll lights off?â condition as a trigger works great. My only problem is that Iâm too inexperienced to add a duration to my âAll lights off? triggerâ. In other words: I would like to set up a âIf all lights have been turned off for 30:00 min, then do xâ trigger.
Any suggestion on how to solve this is highly appreciated!
just asking if this the appropriate or efficient way to handle the shutdown of both lights and switches in 1 script
all_off:
alias: all lights and switches off
mode: single
variables:
lights_on: >
{{ expand('group.all_light') | selectattr('state','eq','on')
switches_on: >
{{ expand('group.all_sockets') | selectattr('state','eq','on')
sequence:
value_template: "{{ lights_on | length > 0 }}"
entity_id: "{{ lights_on }}"
- delay: '00:15:00'
value_template: "{{ switches_on | length > 0 }}"
- service: switch.turn_off
entity_id: "{{ switches_on }}"
You could consolidate the two groups and then use homeassistant.turn_off
to turn off both lights and switches.
{{ expand('group.all_light', 'group.all_sockets') | etc ..
The script can be simplified to:
all_off:
sequence:
- service: homeassistant.turn_off
entity_id:
{% set x = (expand('group.all_light', 'group.all_sockets') | selectattr('state','eq','on')
| map(attribute='entity_id') | list | join(', ') %}
{{ x if x | length > 0 else 'none' }}
However, if you must have a delay between turning off lights and switches then use your version.
Hate to bother you guys again but in yet another automation I need to add âHave all lights been off for 15 minutes?â as a condition. I tried the following
condition:
value_template: >
{% set domain = 'light' %}
{% set state = 'off' %}
{{ states[domain] | count == states[domain] | selectattr('state','eq', state) | list | count }}
for: '00:15:00'
But that only returns the following error message: âMessage malformed: extra keys not allowed @ data[âconditionâ][0][âforâ]â, which is because of the fact that template conditions donât accept for variables as far as my understanding goesâŠ
Again: Thanks in advance for any suggestions!
Can anyone tell me how to update the following to filter the list of entity_id
name that contain certain string?
Thanks in advance
value_template: >
{% set domain = 'switch' %}
{% set is_on = states[domain] | selectattr('state','eq', state) | list | count > 0 %}
{% set state = 'off' if is_on else 'on' %}
{{ states[domain] | selectattr('state','eq',state) | map(attribute='entity_id') | list | join(', ') }}
That condition⊠is very odd. It provides a list of entities. Conditions require templates that return true/false. This seems like a copy/paste error. Not sure what itâs end goal for that was.
Anyways, to filter a list with containsâŠ
{% set contains = 'some_string' %}
{% set ns = namespace(entities = []) %}
{% for s in states[domain] | selectattr('state','eq', state) %}
{% if contains in s.entity_id %}
{% set ns.entities = ns.entities + [ s ] %}
{% endif %}
{% endfor %}
{{ ns.entities | map(attribute='entity_id') | list | join(', ') }}
entity_id: all
Can someone please help me understand how to make this ONLY turn on lights (as it says it will) and not switches? Feels like basic functionality that should be avaible easily without appdaemon and whatnot
thatâs all it does, this will only turn on lights, not switches.
Hm, interesting. Perhaps I should file a bugreport then
Youâre using light.turn_on and itâs turning on switches? Iâd be willing to bet youâre using the light switch integration which turns switches into lights.
This is an example of a switch that turns on.
It is from this integration:
I see now however that:
Switches are devices like power plugs and sirens.
Note that devices in the switch platform identify as lights, so there is a manually curated list that defines which âlightsâ are switches.
I have no idea what âso there is a manually curated list that defines which âlightsâ are switchesâ mean however
Seems like a limitation of deCONZ⊠time to switch to ZHA. Unless Iâm wrong, but I did find ZHA much better that deCONZ.
