Publish timestamp into text_sensor
Similar request, I have a reed switch on a door, I would like to know, in and via esphome, when it last changed. I can see it in HA via “last updated” but due to wifi issues it keeps resetting, so merged all of the above together and came up with:
binary_sensor:
  - platform: gpio
    pin:
      number: 23
      mode: INPUT_PULLUP
    device_class: door
    on_state:
      - component.update: systime
      - lambda:
          if (id(${device_name}_door_sensor).state) {
            id(door_last_update).publish_state("Opened - " + id(systime).state);
          } else {
            id(door_last_update).publish_state("Closed - " + id(systime).state);
text_sensor:
    internal: true
    disabled_by_default: true
    update_interval: never
    lambda: |-
      char str[25];
      time_t currTime = id(my_time).now().timestamp;
      strftime(str, sizeof(str), "%d/%m/%Y %H:%M", gmtime(&currTime));
      return (std::string) str;
    name: ${friendly_name} Door Last Changed
time:
  - platform: sntp
Thank you very much, Mike!
