Hello, I’ve had the PV solar exess optimizer running for a few days now, but it doesn’t work as expected. For example, it switches on the wallbox when there is no PV surplus and then draws power from the battery or the grid. I’ve tried a lot now, energy consumption meter minus battery consumption and vice versa. It even increases the charging current of the wallbox even though the energy comes from the battery. I also tried the combined import/export power meter and nothing changes. Does anyone have a tip for me
@LeoW4 Please provide debug logs / an excerpt from your Home Assistant logfile
Not at the moment, but you can supply a dummy switch (which sends the REST command when triggered) as appliance switch entity.
2023-12-31 14:33:52.280 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 50, 0]
2023-12-31 14:33:52.281 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (PV Power - Load Power) History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 5317, 5075]
2023-12-31 14:33:52.289 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Home battery charge is sufficient (79.0/100.0 %) OR remaining solar forecast is higher than remaining capacity of home battery. Calculated average excess power based on >> solar power - load power <<: 5075 W
2023-12-31 14:33:52.290 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Appliance is already switched on.
2023-12-31 14:33:52.291 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Average Excess Power (5075 W) is still greater than minimum excess power (-10 W) - Doing nothing.
2023-12-31 14:34:33.763 ERROR (MainThread) [homeassistant.components.forecast_solar] Unexpected error fetching forecast_solar data: Rate limit for API calls reached. (error 429)
File “/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py”, line 300, in _async_refresh
self.data = await self._async_update_data()
File “/usr/src/homeassistant/homeassistant/components/forecast_solar/coordinator.py”, line 67, in _async_update_data
return await self.forecast.estimate()
File “/usr/local/lib/python3.11/site-packages/forecast_solar/init.py”, line 156, in estimate
data = await self._request(
File “/usr/local/lib/python3.11/site-packages/forecast_solar/init.py”, line 125, in _request
raise ForecastSolarRatelimit(data[“message”])
forecast_solar.exceptions.ForecastSolarRatelimit: Rate limit for API calls reached. (error 429)
2023-12-31 14:34:33.823 ERROR (MainThread) [homeassistant.components.forecast_solar] Unexpected error fetching forecast_solar data: Rate limit for API calls reached. (error 429)
2023-12-31 14:34:33.952 ERROR (MainThread) [homeassistant.components.forecast_solar] Unexpected error fetching forecast_solar data: Rate limit for API calls reached. (error 429)
2023-12-31 14:34:52.279 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 50, 0, 68]
2023-12-31 14:34:52.279 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (PV Power - Load Power) History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 5317, 5075, 5025]
2023-12-31 14:34:52.283 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Home battery charge is sufficient (79.0/100.0 %) OR remaining solar forecast is higher than remaining capacity of home battery. Calculated average excess power based on >> solar power - load power <<: 5025 W
2023-12-31 14:34:52.287 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Appliance is already switched on.
2023-12-31 14:34:52.289 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Average Excess Power (5025 W) is still greater than minimum excess power (-10 W) - Doing nothing.
2023-12-31 14:35:52.275 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 50, 0, 68, 81]
2023-12-31 14:35:52.275 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (PV Power - Load Power) History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 5317, 5075, 5025, 4946]
2023-12-31 14:35:52.281 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Home battery charge is sufficient (79.0/100.0 %) OR remaining solar forecast is higher than remaining capacity of home battery. Calculated average excess power based on >> solar power - load power <<: 4946 W
2023-12-31 14:35:52.282 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Appliance is already switched on.
2023-12-31 14:35:52.284 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Average Excess Power (4946 W) is still greater than minimum excess power (-10 W) - Doing nothing.
2023-12-31 14:35:54.239 ERROR (MainThread) [homeassistant.components.forecast_solar] Unexpected error fetching forecast_solar data: Rate limit for API calls reached. (error 429)
2023-12-31 14:35:54.256 ERROR (MainThread) [homeassistant.components.forecast_solar] Unexpected error fetching forecast_solar data: Rate limit for API calls reached. (error 429)
2023-12-31 14:35:54.264 ERROR (MainThread) [homeassistant.components.forecast_solar] Unexpected error fetching forecast_solar data: Rate limit for API calls reached. (error 429)
2023-12-31 14:36:52.274 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 50, 0, 68, 81, 112]
2023-12-31 14:36:52.275 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (PV Power - Load Power) History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 5317, 5075, 5025, 4946, 4942]
2023-12-31 14:36:52.282 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Home battery charge is sufficient (79.0/100.0 %) OR remaining solar forecast is higher than remaining capacity of home battery. Calculated average excess power based on >> solar power - load power <<: 4942 W
2023-12-31 14:36:52.283 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Appliance is already switched on.
2023-12-31 14:36:52.286 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Average Excess Power (4942 W) is still greater than minimum excess power (-10 W) - Doing nothing.
2023-12-31 14:37:52.276 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 50, 0, 68, 81, 112, 22]
2023-12-31 14:37:52.276 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (PV Power - Load Power) History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 5317, 5075, 5025, 4946, 4942, 4769]
2023-12-31 14:37:52.282 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Home battery charge is sufficient (79.0/100.0 %) OR remaining solar forecast is higher than remaining capacity of home battery. Calculated average excess power based on >> solar power - load power <<: 4769 W
2023-12-31 14:37:52.283 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Appliance is already switched on.
2023-12-31 14:37:52.286 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Average Excess Power (4769 W) is still greater than minimum excess power (-10 W) - Doing nothing.
2023-12-31 14:38:52.278 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 50, 0, 68, 81, 112, 22, 97]
2023-12-31 14:38:52.278 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (PV Power - Load Power) History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 5317, 5075, 5025, 4946, 4942, 4769, 4564]
2023-12-31 14:38:52.287 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Home battery charge is sufficient (80.0/100.0 %) OR remaining solar forecast is higher than remaining capacity of home battery. Calculated average excess power based on >> solar power - load power <<: 4564 W
2023-12-31 14:38:52.288 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Appliance is already switched on.
2023-12-31 14:38:52.290 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Average Excess Power (4564 W) is still greater than minimum excess power (-10 W) - Doing nothing.
2023-12-31 14:39:52.286 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 50, 0, 68, 81, 112, 22, 97, 36]
2023-12-31 14:39:52.287 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (PV Power - Load Power) History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 5317, 5075, 5025, 4946, 4942, 4769, 4564, 4464]
2023-12-31 14:39:52.295 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Home battery charge is sufficient (80.0/100.0 %) OR remaining solar forecast is higher than remaining capacity of home battery. Calculated average excess power based on >> solar power - load power <<: 4464 W
2023-12-31 14:39:52.296 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Average Excess power is high enough to switch on appliance.
2023-12-31 14:39:52.297 INFO (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Switched on appliance.
2023-12-31 14:39:52.298 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Adjusting power history by -1380.0.
2023-12-31 14:39:52.298 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export history: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 50, 0, 68, 81, 112, 22, 97, 36]
2023-12-31 14:39:52.299 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Adjusted export history: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 50, 0, 68, 81, 112, 22, 97, 0]
2023-12-31 14:39:52.299 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (solar power - load power) history: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 5317, 5075, 5025, 4946, 4942, 4769, 4564, 4464]
2023-12-31 14:39:52.299 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Adjusted PV Excess (solar power - load power) history: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 5317, 5075, 5025, 4946, 4942, 4769, 4564, 3084.0]
2023-12-31 14:39:53.304 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Average Excess Power (4464 W) is still greater than minimum excess power (-10 W) - Doing nothing.
2023-12-31 14:39:53.313 ERROR (MainThread) [homeassistant.core] Error executing service: <ServiceCall number.set_value (c:01HK01MDAFMEBHWNY24750CKDS): entity_id=[‘number.go_echarger_241534_amp’], value=2.0>
File “/usr/src/homeassistant/homeassistant/core.py”, line 2083, in _run_service_call_catch_exceptions
await coro_or_task
File “/usr/src/homeassistant/homeassistant/core.py”, line 2104, in _execute_service
return await target(service_call)
File “/usr/src/homeassistant/homeassistant/helpers/entity_component.py”, line 272, in handle_service
return await service.entity_service_call(
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 878, in entity_service_call
single_response = await _handle_entity_call(
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 948, in _handle_entity_call
result = await task
File “/usr/src/homeassistant/homeassistant/components/number/init.py”, line 96, in async_set_value
raise ValueError(
ValueError: Value 2.0 for number.go_echarger_241534_amp is outside valid range 6 - 32
2023-12-31 14:40:52.282 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 50, 0, 68, 81, 112, 22, 97, 0, 4]
2023-12-31 14:40:52.282 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (PV Power - Load Power) History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 5317, 5075, 5025, 4946, 4942, 4769, 4564, 3084.0, 2676]
2023-12-31 14:40:52.292 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Home battery charge is sufficient (79.0/100.0 %) OR remaining solar forecast is higher than remaining capacity of home battery. Calculated average excess power based on >> solar power - load power <<: 2676 W
2023-12-31 14:40:52.292 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Appliance is already switched on.
2023-12-31 14:40:52.295 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Average Excess Power (2676 W) is still greater than minimum excess power (-10 W) - Doing nothing.
2023-12-31 14:41:52.283 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 50, 0, 68, 81, 112, 22, 97, 0, 4, 21]
2023-12-31 14:41:52.285 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (PV Power - Load Power) History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 5317, 5075, 5025, 4946, 4942, 4769, 4564, 3084.0, 2676, 4394]
2023-12-31 14:41:52.291 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Home battery charge is sufficient (80.0/100.0 %) OR remaining solar forecast is higher than remaining capacity of home battery. Calculated average excess power based on >> solar power - load power <<: 4394 W
2023-12-31 14:41:52.292 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Appliance is already switched on.
2023-12-31 14:41:52.294 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Average Excess Power (4394 W) is still greater than minimum excess power (-10 W) - Doing nothing.
2023-12-31 14:42:52.281 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 50, 0, 68, 81, 112, 22, 97, 0, 4, 21, 0]
2023-12-31 14:42:52.281 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (PV Power - Load Power) History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 5317, 5075, 5025, 4946, 4942, 4769, 4564, 3084.0, 2676, 4394, 4306]
2023-12-31 14:42:52.287 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Home battery charge is sufficient (80.0/100.0 %) OR remaining solar forecast is higher than remaining capacity of home battery. Calculated average excess power based on >> solar power - load power <<: 4306 W
2023-12-31 14:42:52.288 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Appliance is already switched on.
2023-12-31 14:42:52.291 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Average Excess Power (4306 W) is still greater than minimum excess power (-10 W) - Doing nothing.
2023-12-31 14:43:52.285 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 50, 0, 68, 81, 112, 22, 97, 0, 4, 21, 0, 26]
2023-12-31 14:43:52.285 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (PV Power - Load Power) History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 5317, 5075, 5025, 4946, 4942, 4769, 4564, 3084.0, 2676, 4394, 4306, 4446]
2023-12-31 14:43:52.291 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Home battery charge is sufficient (80.0/100.0 %) OR remaining solar forecast is higher than remaining capacity of home battery. Calculated average excess power based on >> solar power - load power <<: 4446 W
2023-12-31 14:43:52.292 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Appliance is already switched on.
2023-12-31 14:43:52.296 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Average Excess Power (4446 W) is still greater than minimum excess power (-10 W) - Doing nothing.
2023-12-31 14:44:52.283 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 50, 0, 68, 81, 112, 22, 97, 0, 4, 21, 0, 26, 221]
2023-12-31 14:44:52.286 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (PV Power - Load Power) History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 5317, 5075, 5025, 4946, 4942, 4769, 4564, 3084.0, 2676, 4394, 4306, 4446, 4644]
2023-12-31 14:44:52.293 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Home battery charge is sufficient (80.0/100.0 %) OR remaining solar forecast is higher than remaining capacity of home battery. Calculated average excess power based on >> solar power - load power <<: 4644 W
2023-12-31 14:44:52.294 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Appliance is already switched on.
2023-12-31 14:44:52.296 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Average Excess Power (4644 W) is still greater than minimum excess power (-10 W) - Doing nothing.
2023-12-31 14:45:52.285 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 50, 0, 68, 81, 112, 22, 97, 0, 4, 21, 0, 26, 221, 7]
2023-12-31 14:45:52.287 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (PV Power - Load Power) History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 5317, 5075, 5025, 4946, 4942, 4769, 4564, 3084.0, 2676, 4394, 4306, 4446, 4644, 4584]
2023-12-31 14:45:52.290 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Home battery charge is sufficient (80.0/100.0 %) OR remaining solar forecast is higher than remaining capacity of home battery. Calculated average excess power based on >> solar power - load power <<: 4584 W
2023-12-31 14:45:52.291 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Appliance is already switched on.
2023-12-31 14:45:52.294 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Average Excess Power (4584 W) is still greater than minimum excess power (-10 W) - Doing nothing.
2023-12-31 14:46:52.281 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 50, 0, 68, 81, 112, 22, 97, 0, 4, 21, 0, 26, 221, 7, 118]
2023-12-31 14:46:52.281 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (PV Power - Load Power) History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 5317, 5075, 5025, 4946, 4942, 4769, 4564, 3084.0, 2676, 4394, 4306, 4446, 4644, 4584, 4578]
2023-12-31 14:46:52.289 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Home battery charge is sufficient (80.0/100.0 %) OR remaining solar forecast is higher than remaining capacity of home battery. Calculated average excess power based on >> solar power - load power <<: 4578 W
2023-12-31 14:46:52.290 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Appliance is already switched on.
2023-12-31 14:46:52.292 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Average Excess Power (4578 W) is still greater than minimum excess power (-10 W) - Doing nothing.
2023-12-31 14:47:52.283 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 50, 0, 68, 81, 112, 22, 97, 0, 4, 21, 0, 26, 221, 7, 118, 94]
2023-12-31 14:47:52.285 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (PV Power - Load Power) History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 5317, 5075, 5025, 4946, 4942, 4769, 4564, 3084.0, 2676, 4394, 4306, 4446, 4644, 4584, 4578, 4631]
2023-12-31 14:47:52.289 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Home battery charge is sufficient (80.0/100.0 %) OR remaining solar forecast is higher than remaining capacity of home battery. Calculated average excess power based on >> solar power - load power <<: 4631 W
2023-12-31 14:47:52.290 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Appliance is already switched on.
2023-12-31 14:47:52.293 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.goecharger (Prio 1)] Average Excess Power (4631 W) is still greater than minimum excess power (-10 W) - Doing nothing.
2023-12-31 14:48:52.284 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 50, 0, 68, 81, 112, 22, 97, 0, 4, 21, 0, 26, 221, 7, 118, 94, 79]
2023-12-31 14:48:52.287 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (PV Power - Load Power) History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 5317, 5075, 5025, 4946, 4942, 4769, 4564, 3084.0, 2676, 4394, 4306, 4446, 4644, 4584, 4578, 4631, 4360]
2023-12-31 14:48:52.291 DEBUG (MainThread)
@LeoW4 as you can see from the logs, PV Power minus Load Power is positive in your case.
PV Power is the currently generated solar power. So if you generate no solar power, the sensors value must be zero.
Load Power is the current Load Power of the complete house. So if you charge your car with 5000W, your Load Power has to be 5000W (+ Load of other electrical devices in the house).
One of the two entities - Load Power and PV Power - has wrong values. Probably the Load Power has negative values instead of positive ones.
Thanks, I’ll have to look at that again, the wallbox is only activated when, as in my case, 4000W min charging power is required or earlier?
Amazing stuff!
Looks like this could help me keep the total house current consumption below my 3 x 25A main fuses!
With heating / AC / Wallbox / induction cooking / oven etc. Etc. And a 4kwh solar peak + 15kwh home battery hybrid converter.
Can I define appliances per phase in order to keep all three phases below 25A?
Need to read up a lot ![]()
Does anyone have an idea how to get the Load and Export Power as individual entities from the SolarEdge Modbus integration?
These templates should help:
modbus_load:
friendly_name: "Load"
device_class: power
unit_of_measurement: W
value_template: "{{ (states('sensor.solaredge_i1_ac_power')|int(0)
- states('sensor.solaredge_m1_ac_power')|int(0))}}"
modbus_generation:
friendly_name: "Production"
device_class: power
value_template: "{{ (states('sensor.solaredge_i1_ac_power')|int(0) }}"
modbus_export:
friendly_name: "Export"
device_class: power
value_template: "{{ max(0,states('sensor.solaredge_m1_ac_power')|int(0)) }}"
modbus_import:
friendly_name: "Import"
device_class: power
value_template: "{{ min(0,states('sensor.solaredge_m1_ac_power')|int(0))|abs }}"
Thanks Mark!
Ok so I have set this automation up to turn a dehumidifier on and off. It will not turn it on even though the conditions are perfect for it today (was feeding 15kWh into the grid at the time). This is from my logs when I manually run the automation/blueprint. Any ideas where I have gone wrong?
2024-01-09 13:49:54.178 INFO (MainThread) [homeassistant.components.automation.excess_solar_dehumidifier] Excess Solar - Dehumidifier: Running automation actions
2024-01-09 13:49:54.178 INFO (MainThread) [homeassistant.components.automation.excess_solar_dehumidifier] Excess Solar - Dehumidifier: Executing step call service
2024-01-09 13:49:54.180 INFO (MainThread) [custom_components.pyscript.file.pv_excess_control.pv_excess_control] [switch.dehumidifier_power (Prio 1)] Registered appliance.
And the blueprint:
alias: Excess Solar - Dehumidifier
description: ""
use_blueprint:
path: pv_excess_control.yaml
input:
automation_id: excess_pv_control_dehumidifier
grid_voltage: 240
pv_power: sensor.modbus_generation
load_power: sensor.modbus_load
export_power: sensor.modbus_export
appliance_switch: switch.dehumidifier_power
defined_current: 2
actual_power: sensor.dehumidifier_smartplug_power
And step details from the Trace Log
Executed: 9 January 2024 at 13:49:54
Result:
params:
domain: pyscript
service: pv_excess_control
service_data:
appliance_priority: 1
home_battery_level: null
min_home_battery_level: 100
dynamic_current_appliance: false
appliance_phases: 1
min_current: 6
max_current: 16
appliance_switch_interval: 5
appliance_current_set_entity: null
defined_current: 2
appliance_on_only: false
grid_voltage: 240
import_export_power: null
home_battery_capacity: 0
solar_production_forecast: null
appliance_once_only: false
target: {}
running_script: false
@BeastHouse you need to paste an excerpt from your home assistant logfile after enabling debug logging according to the first post.
The first block in my post was from the log file - that’s all that pops up in there when I fire the automation, and that’s with DEBUG enabled as per the docs.
Am I missing something?
the home-assistant.log should rather look like:
2024-01-13 11:03:51.274 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
2024-01-13 11:03:51.275 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (PV Power - Load Power) History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, -159]
2024-01-13 11:03:51.283 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Force battery charge necessary: capacity=6 kWh|remaining_capacity=5.4 kWh|remaining_forecast=6.2958 kWh| kwh_offset=1 kWh
2024-01-13 11:03:51.285 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.shelly_plug_14_switch_0 (Prio 1)] Cannot switch off appliance, because appliance switch interval is not reached (0/5).
2024-01-13 11:03:51.287 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.shelly_plug_11 (Prio 2)] Cannot switch off appliance, because appliance switch interval is not reached (1/5).
2024-01-13 11:03:51.287 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.shelly_plug_11 (Prio 2)] Home battery charge is not sufficient (10.0/100.0 %), OR remaining solar forecast is lower than remaining capacity of home battery. Calculated average excess power based on >> export power <<: 0 W
2024-01-13 11:03:51.289 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.shelly_plug_11 (Prio 2)] Average Excess power not high enough to switch on appliance.
2024-01-13 11:03:51.293 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Force battery charge necessary: capacity=6 kWh|remaining_capacity=5.4 kWh|remaining_forecast=6.2958 kWh| kwh_offset=1 kWh
2024-01-13 11:03:51.294 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.shelly_plug_14_switch_0 (Prio 1)] Cannot switch off appliance, because appliance switch interval is not reached (1/5).
2024-01-13 11:03:51.296 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.shelly_plug_11 (Prio 2)] Cannot switch off appliance, because appliance switch interval is not reached (1/5).
2024-01-13 11:03:51.297 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.shelly_plug_14_switch_0 (Prio 1)] Home battery charge is not sufficient (10.0/100.0 %), OR remaining solar forecast is lower than remaining capacity of home battery. Calculated average excess power based on >> export power <<: 0 W
2024-01-13 11:03:51.298 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.shelly_plug_14_switch_0 (Prio 1)] Average Excess power not high enough to switch on appliance.
2024-01-13 11:03:51.299 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.shelly_plug_14_switch_0 (Prio 1)] Appliance is already switched off.
2024-01-13 11:03:51.300 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] [switch.shelly_plug_11 (Prio 2)] Appliance is already switched off.
it took me some time to set it up correctly but reading the log carefully and create non negative sensors helpd at the end. Many thanks!!!
ok found it!
2024-01-13 21:30:27.463 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
2024-01-13 21:30:27.463 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (PV Power - Load Power) History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, -2216, -2067, -1962, -1952, -1951, -1943, -1949, -1936, -1960, -2038]
2024-01-13 21:31:27.463 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
2024-01-13 21:31:27.463 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (PV Power - Load Power) History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, -2216, -2067, -1962, -1952, -1951, -1943, -1949, -1936, -1960, -2038, -2248]
2024-01-13 21:32:27.464 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
2024-01-13 21:32:27.464 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (PV Power - Load Power) History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, -2216, -2067, -1962, -1952, -1951, -1943, -1949, -1936, -1960, -2038, -2248, -2273]
2024-01-13 21:33:27.463 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
2024-01-13 21:33:27.463 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (PV Power - Load Power) History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, -2216, -2067, -1962, -1952, -1951, -1943, -1949, -1936, -1960, -2038, -2248, -2273, -2271]
2024-01-13 21:34:27.463 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] Export History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
2024-01-13 21:34:27.463 DEBUG (MainThread) [custom_components.pyscript.file.pv_excess_control.on_time] PV Excess (PV Power - Load Power) History: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, -2216, -2067, -1962, -1952, -1951, -1943, -1949, -1936, -1960, -2038, -2248, -2273, -2271, -2281]
There is approx 5000 lines of this repeated in my logs.
Hi all,
I have victron / modbus and am stragling what to use for
Export Power
or
Combined Import/Export Power
I have seen on some screenshot that someone used helper sensor.
Which of the modbus entities should I use ?
Anyone using victron - any tip or guidance ?
thanks a lot
below my blueprint automation-call
alias: PV Excess OGKind2
description: ""
use_blueprint:
input:
automation_id: PV Excess OGKind2
appliance_priority: 2
pv_power: sensor.power_pv_current_template
export_power: sensor.active_power_outgoing
load_power: sensor.filtered_realistic_homepower
home_battery_level: sensor.scb_battery_soc
home_battery_capacity: 6
solar_production_forecast: sensor.solcast_pv_forecast_forecast_remaining_today
appliance_switch: input_boolean.pv_excess_eheating_helper
defined_current: 2.8
actual_power: sensor.shelly_plug_11_power
the priority level is missing and don#t use “_” for the ID. This are just hints as I am not the owner of the blueprint.
I created the sensors as template sensors to be shure they get not negative or unknown. the script does not like it …
As I use a hybrid inverter with battery - separate export / import sensors are needed.
as i do not have a victron I rahter cannot help you direct.
I hope someone with victron will reply what they used.
Thanks anyway
