Hi community!!
I have a X1 Boost 3.0T inverter. Iād like to share my configuration. Itās based on @schnetf config, so, Thank you!!!
Iāve added more parameters, including the consumption in Watts.
As you know, this is to retrieve parameters from cloud. Can you recommend me a good guide to rertrieve data directly from inverter, in local network?
File solax.yaml
- platform: rest
scan_interval: 60
resource: https://www.eu.solaxcloud.com:9443/proxy/api/getRealtimeInfo.do?tokenId=XXXXXXXXXXXXX&sn=YYYYYYYY
json_attributes_path: "$.result"
json_attributes:
- yieldtoday
- yieldtotal
- powerdc1
- uploadTime
- inverterStatus
- acpower
- feedinpower
- feedinenergy
- consumeenergy
value_template: "1" # dummy value; not used; avoids error
sensors:
solax_garage_today:
friendly_name: "Solax Garage today"
value_template: "{{ state_attr('sensor.solax_garage', 'yieldtoday') }}"
unit_of_measurement: "kWh"
solax_garage_total:
friendly_name: "Solax Garage total"
value_template: "{{ state_attr('sensor.solax_garage', 'yieldtotal') }}"
solax_garage_now:
friendly_name: "Solax Garage now"
value_template: "{{ state_attr('sensor.solax_garage', 'acpower') }}"
unit_of_measurement: "W"
solax_garage_pv:
friendly_name: "Solax Garage PV Power"
value_template: "{{ state_attr('sensor.solax_garage', 'powerdc1') }}"
solax_garage_pin:
friendly_name: "Solax Garage FeedIn Power"
value_template: "{{ state_attr('sensor.solax_garage', 'feedinpower') }}"
solax_garage_ein:
friendly_name: "Solax Garage FeedIn Energy"
value_template: "{{ state_attr('sensor.solax_garage', 'feedinenergy') }}"
solax_garage_econ:
friendly_name: "Solax Garage Consume Energy"
value_template: "{{ state_attr('sensor.solax_garage', 'consumeenergy') }}"
solax_garage_upload_time:
friendly_name: "Solax Garage upload time"
value_template: "{{ state_attr('sensor.solax_garage', 'uploadTime') }}"
solax_garage_status:
friendly_name: "Solax Garage status"
value_template: >
{% if state_attr('sensor.solax_garage', 'inverterStatus') == '100' %}Wait
{% elif state_attr('sensor.solax_garage', 'inverterStatus') == '101' %}Check
{% elif state_attr('sensor.solax_garage', 'inverterStatus') == '102' %}Normal
{% elif state_attr('sensor.solax_garage', 'inverterStatus') == '103' %}Fault
{% elif state_attr('sensor.solax_garage', 'inverterStatus') == '104' %}Permanent Fault
{% elif state_attr('sensor.solax_garage', 'inverterStatus') == '105' %}Update
{% elif state_attr('sensor.solax_garage', 'inverterStatus') == '106' %}EPS Check
{% elif state_attr('sensor.solax_garage', 'inverterStatus') == '107' %}EPS
{% elif state_attr('sensor.solax_garage', 'inverterStatus') == '108' %}Self-test
{% elif state_attr('sensor.solax_garage', 'inverterStatus') == '109' %}Idle
{% elif state_attr('sensor.solax_garage', 'inverterStatus') == '110' %}Standby
{% elif state_attr('sensor.solax_garage', 'inverterStatus') == '111' %}Pv Wake Up Bat
{% elif state_attr('sensor.solax_garage', 'inverterStatus') == '112' %}Gen Check
{% elif state_attr('sensor.solax_garage', 'inverterStatus') == '113' %}Gen Run
{% else %}I dont know{% endif %}
solax_now:
friendly_name: "PV now"
value_template: "{{ (states('sensor.solax_garage_now') | float) }}"
solax_today:
friendly_name: "PV today"
value_template: "{{ (states('sensor.solax_garage_today') | float) }}"
solax_total:
friendly_name: "PV total"
value_template: "{{ (states('sensor.solax_garage_total') | float) }}"
solax_pv_power:
friendly_name: "PV Power"
value_template: "{{ (states('sensor.solax_garage_pv') | float) }}"
solax_feedin_power:
friendly_name: "FeedIn Power"
value_template: "{{ (states('sensor.solax_garage_pin') | float) }}"
solax_feedin_energy:
friendly_name: "FeedIn Energy"
value_template: "{{ (states('sensor.solax_garage_ein') | float) }}"
solax_consume_energy:
friendly_name: "Consume Energy"
value_template: "{{ (states('sensor.solax_garage_econ') | float) }}"
solax_consume_power:
friendly_name: "Consume Power"
value_template: "{{ (states('sensor.solax_garage_now') | float) - (states('sensor.solax_garage_pin') | float) }}"
File pv_sensors.yaml:
- sensor:
- name: PV yield (Now)
state: "{{ states('sensor.solax_now') | float }}"
state_class: total_increasing
device_class: power
attributes:
last_reset: '1970-01-01T00:00:00+00:00'
- sensor:
- name: PV yield (Today)
state: "{{ states('sensor.solax_today') | float }}"
device_class: energy
attributes:
- sensor:
- name: PV yield (Total)
state: "{{ states('sensor.solax_total') | float }}"
attributes:
- sensor:
attributes:
- sensor:
- name: FeedIn Energy
state: "{{ states('sensor.solax_feedin_energy') | float }}"
attributes:
- sensor:
- name: FeedIn Power
state: "{{ states('sensor.solax_feedin_power') | float }}"
device_class: power
attributes:
- sensor:
- name: Consume Energy
state: "{{ states('sensor.solax_consume_energy') | float }}"
attributes:
- sensor:
- name: Consume Power
state: "{{ states('sensor.solax_consume_power') | float }}"
device_class: power
attributes:
Chudepohl
(Chris Hudepohl)
June 6, 2022, 8:49am
87
Hi, I have the following script (below) running for my Solax installation. It works fine but when I add new scripts or sensors to my configuration.ymal it doesnāt work anymore. Iām assuming I did something wrong but Iām not able to find what it is.
Do you guys have any suggestions?
# SOLAX CLOUD. #
- platform: rest
scan_interval: 120
resource: https://www.eu.solaxcloud.com:9443/proxy/api/getRealtimeInfo.do?tokenId=&sn=
value_template: '{{ ( value_json.result.yieldtotal | round(0) ) }}'
unit_of_measurement: "KWh"
- platform: rest
scan_interval: 60
resource: https://www.eu.solaxcloud.com:9443/proxy/api/getRealtimeInfo.do?tokenId=20220105163654425474254&sn=SWZPGZE2D8
value_template: '{{ ( value_json.result.acpower | round(0) ) }}'
- platform: rest
scan_interval: 120
value_template: '{{ value_json.result.yieldtoday }}'
- platform: rest
scan_interval: 120
value_template: "{{ value_json.result.uploadTime }}"
name: "Solax upload time"
- platform: rest
scan_interval: 120
value_template: '{{ ( value_json.result.powerdc1 | round(0) ) }}'
name: "Solax String 1"
- platform: rest
scan_interval: 120
value_template: '{{ ( value_json.result.powerdc2 | round(0) ) }}'
name: "Solax String 2"
- platform: rest
scan_interval: 120
value_template: >
{% if value_json.result.inverterStatus == '100' %}Wait
{% elif value_json.result.inverterStatus == '101' %}Check
{% elif value_json.result.inverterStatus == '102' %}Normal
{% elif value_json.result.inverterStatus == '103' %}Fault
{% elif value_json.result.inverterStatus == '104' %}Permanent Fault
{% elif value_json.result.inverterStatus == '105' %}Update
{% elif value_json.result.inverterStatus == '106' %}EPS Check
{% elif value_json.result.inverterStatus == '107' %}EPS
{% elif value_json.result.inverterStatus == '108' %}Self-test
{% elif value_json.result.inverterStatus == '109' %}Idle
{% elif value_json.result.inverterStatus == '110' %}Standby
{% elif value_json.result.inverterStatus == '111' %}Pv Wake Up Bat
{% elif value_json.result.inverterStatus == '112' %}Gen Check
{% elif value_json.result.inverterStatus == '113' %}Gen Run
template:
- sensor:
- name: test_energy
state: "{{ states('sensor.solax_total')}}"
attributes:
Rudi1952
(Rudi1952)
July 16, 2022, 7:59am
89
I am new on home assistant and i am trying to integrate my SOLAX system.
I canāt figure out where i have to install these files.
solax.yaml
pv_sensors.yaml
should both files be placed in the directory config ? Or in a subdirectory?
TsailunVR
(Tsailun Vr)
July 18, 2022, 3:50pm
90
Hi and thanks!!! after do it⦠how I can create a dashboard with all information? or where I have the information? I dont have anything in Energy area⦠thanks!
TsailunVR
(Tsailun Vr)
July 18, 2022, 3:53pm
92
Hi Miguel!! Or hola. After do it, where I can see the information? I need to create dashboard or aim going to have in energy section? Im lost in this point
colesadam
(Adam Coles)
September 5, 2022, 11:13am
93
Hi all, many thanks to those who posted their configs - I have this mostly working apart from some weird issues in the energy tab where it appears total yield values drop to 0 occasionally, leading to massive spikes on the next reading on the energy tab. E.g.
Anyone know the cause of these or how to prevent them?
Hereās my config
- platform: rest
scan_interval: 90
resource: https://www.eu.solaxcloud.com:9443/proxy/api/getRealtimeInfo.do?tokenId=XXXXXXXXXXXXXXX&sn=XXXXXXXXXXXX
json_attributes:
- yieldtoday
- yieldtotal
- acpower
- uploadTime
- inverterStatus
value_template: "1" # dummy value, not used; avoids the "State max length is 255 characters" error
sensors:
solax_yield_today:
friendly_name: "Solax yield today"
value_template: "{{ state_attr('sensor.solax', 'yieldtoday') }}"
solax_yield_total:
friendly_name: "Solax yield total"
value_template: "{{ state_attr('sensor.solax', 'yieldtotal') }}"
solax_power_now:
friendly_name: "Solax power now"
value_template: "{{ state_attr('sensor.solax', 'acpower') }}"
device_class: power
solax_yield_delta:
friendly_name: "Solax yield delta"
value_template: "{{ state_attr('sensor.solax', 'acpower') /12000 }}"
solax_upload_time:
friendly_name: "Solax update time"
value_template: "{{ state_attr('sensor.solax', 'uploadTime') }}"
solax_status:
friendly_name: "Solax status"
value_template: >
{% if state_attr('sensor.solax', 'inverterStatus') == '100' %}Wait
{% elif state_attr('sensor.solax', 'inverterStatus') == '101' %}Check
{% elif state_attr('sensor.solax', 'inverterStatus') == '102' %}Normal
{% elif state_attr('sensor.solax', 'inverterStatus') == '103' %}Fault
{% elif state_attr('sensor.solax', 'inverterStatus') == '104' %}Permanent Fault
{% elif state_attr('sensor.solax', 'inverterStatus') == '105' %}Update
{% elif state_attr('sensor.solax', 'inverterStatus') == '106' %}EPS Check
{% elif state_attr('sensor.solax', 'inverterStatus') == '107' %}EPS
{% elif state_attr('sensor.solax', 'inverterStatus') == '108' %}Self-test
{% elif state_attr('sensor.solax', 'inverterStatus') == '109' %}Idle
{% elif state_attr('sensor.solax', 'inverterStatus') == '110' %}Standby
{% elif state_attr('sensor.solax', 'inverterStatus') == '111' %}Pv Wake Up Bat
{% elif state_attr('sensor.solax', 'inverterStatus') == '112' %}Gen Check
{% elif state_attr('sensor.solax', 'inverterStatus') == '113' %}Gen Run
solax_now:
value_template: "{{ (states('sensor.solax_power_now') | float) }}"
solax_today:
value_template: "{{ (states('sensor.solax_yield_today') | float) }}"
solax_total:
value_template: "{{ (states('sensor.solax_yield_total') | float) }}"
colesadam
(Adam Coles)
September 5, 2022, 11:14am
94
hereās the total yield graph showing a drop to 0
colesadam:
- platform: rest
scan_interval: 90
resource: [...]
json_attributes:
- yieldtoday
- yieldtotal
- acpower
- uploadTime
- inverterStatus
Thanks for sharing! This is what I was looking for. Just received my Solax yesterday and needed a quick fix, before I am going to build an integration.
One thing though: you are sharing your token. Not sure if that is a security/privacy issue.
colesadam
(Adam Coles)
September 12, 2022, 8:01am
96
Thanks yes, can you delete it from yours? Itās read only of course but stillā¦
colesadam
(Adam Coles)
September 12, 2022, 8:03am
97
For anybody looking for how to eliminate those odd zero entries itās something like this
- sensor:
availability: "{{ states('sensor.solax_total') | float > 0 }}"
attributes:
Done! I kind of assumed it would happen automatically, since I referenced your post. My mistake
Does anyone know how you can increase the update time on the readings? Every 5 minutes seems too long.
Kars
(Kars de Jong)
September 21, 2022, 1:46pm
100
You canāt, if you want faster updates you have to use Modbus.
I had a feeling that was the case, unfortunately Modbus isnāt an option for me.
Qua
September 23, 2022, 1:19pm
102
Iāve adopted parts of this thread. Among other sensors Iāve the solax_total_yield which shows the total kwh yield of my solar panels all-time. None of these sensors can be used in the Energy dashboards though. So I took the above snippet:
template:
- sensor:
- name: test_energy
state: "{{ states('sensor.solax_total_yield') }}"
availability: "{{ states('sensor.solax_total_yield') | float > 0 }}"
attributes:
last_reset: "1970-01-01T00:00:00+00:00"
The sensor works. Itās slowly counting the kwh throughout the day. I can add it to the energy dashboard just fine, but the dashboard never shows any solar panel activity.
What have I done wrong?
Hi, my second day venturing down the home assistant rabbit hole because I wanted to have some automation based on Solax X1 Hybrid G4 outputs.
I have managed to get the information from the cloud and did some slight customization to get the information I want for automation like total PV power and House consumption.
Next step Modbus.
One thing I have learnt/misunderstood. The serial number is the dongle serial number not the inverter for the API query
Thanks to all who have done the hard work to make this happen
Below is what the UI looks like.
PS I hope that I have posted the code correctly
- platform: rest
scan_interval: 60
resource: https://www.solaxcloud.com/proxyApp/proxy/api/getRealtimeInfo.do?tokenId=xxxxxxxxxxxxxxx&sn=SVTxxxxx
json_attributes:
- yieldtoday
- yieldtotal
- powerdc1
- powerdc2
- uploadTime
- inverterStatus
- acpower
- feedinpower
- feedinenergy
- soc
- consumeenergy
- batPower
sensors:
solax_garage_today:
solax_garage_total:
solax_garage_now:
solax_garage_pv1:
friendly_name: "Solax Garage PV Power1"
solax_garage_pv2:
friendly_name: "Solax Garage PV Power2"
value_template: "{{ state_attr('sensor.solax_garage', 'powerdc2') }}"
icon_template: mdi:solar-panel
solax_garage_pin:
solax_garage_ein:
solax_garage_soc:
friendly_name: "Solax Garage Battery Charge level"
value_template: "{{ state_attr('sensor.solax_garage', 'soc') }}"
unit_of_measurement: "%"
solax_garage_econ:
icon_template: mdi:alarm-check
solax_garage_bat_power:
friendly_name: "Solax Battery Power"
value_template: "{{ state_attr('sensor.solax_garage', 'batPower') }}"
value_template: >
solax_now:
friendly_name: "Inverter Power"
icon_template: mdi:lightning-bolt-circle
solax_today:
solax_total:
solax_pv_power1:
friendly_name: "PV Power1"
value_template: "{{ (states('sensor.solax_garage_pv1') | float) }}"
icon_template: mdi:solar-power-variant-outline
solax_pv_power2:
friendly_name: "PV Power2"
value_template: "{{ (states('sensor.solax_garage_pv2') | float) }}"
solax_pv_power_total:
friendly_name: "PV Power Total"
value_template: "{{ (states('sensor.solax_garage_pv2') | float) + (states('sensor.solax_garage_pv1') | float) }}"
solax_house_cons:
friendly_name: "House Power"
icon_template: mdi:home-lightning-bolt-outline
solax_feedin_power:
friendly_name: "Grid Power"
icon_template: mdi:transmission-tower
solax_soc_level:
friendly_name: "Battery Charge level"
value_template: "{{ (states('sensor.solax_garage_soc') | float) }}"
icon_template: mdi:home-battery
solax_batt_power:
friendly_name: "Battery Power"
value_template: "{{ (states('sensor.solax_garage_bat_power') | float) }}"
icon_template: mdi:battery
Did you find a Solution?
Same problem here.
jamie543
(Jamie543)
November 5, 2022, 6:43pm
105
little confused on how this works can someone help knew to home assitant and not sure if im doing this right. Can somone explain how i create the sensor as i get a UndefinedError: āvalue_jsonā is undefined error message
lukasberan
(LukasBeran)
November 9, 2022, 12:49pm
106
Hi.
I have a Solax X3 Hybrid 10.0 D and used your yaml. The problem is that I cannot select it for the energy dashboard - the sensors are simply not visible. What do I need to do to make it available for the energy dashboard? I can use the sensors on my own dashboards, but it is not available in the dropdown menu for the energy dashboard.
