Pyscript - new integration for easy and powerful Python scripting
Nope! I suspect pyscript takes care of that itself. You should be good just calling it normally.
Understood. Something is not right then. See error above.
I am most certain that the timer is running and expiring otherwise this code would not be executed. The issue is that it is giving that error instead of firing the event. Seems like what you provided is close to working as intended but does not.
from datetime import datetime
@service
def schedule_event_at_time(event_name: str, event_data: dict = {}, target_time: str = ""):
    # Parse the target time from the input string
    target_time = datetime.strptime(target_time, "%Y-%m-%d %H:%M:%S")
    # Get the current time
    now = datetime.now()
    # If the target time is in the past, log an error and return
    if target_time < now:
        log.error(f"Target time {target_time} is in the past. Event not scheduled.")
        return
    # Calculate the sleep duration
    sleep_duration = (target_time - now).total_seconds()
    # Wait until the target time
    task.sleep(sleep_duration)
    # Fire the event
    event.fire(event_name, **event_data)
    log.warning(f"Event '{event_name}' fired at {target_time}")
I spent a bunch of time troubleshooting and writing and then decided to see if GPT could help. Got me here with a few hand edits based on what I learned from the links @Slalamander supplied.
This works great but…for some unknown reason the service call gets made but does not return until the timer completes. This is problematic as I am trying this to voice so:
Me: ā€œSet a timer for 30 secondsā€
Thirty seconds pass
Assist: ā€œTimer set for 30 secondsā€
Shouldn’t this be running the service in the background?
EDIT Got this going with a bit of help in HA Discord:
def timerwait(duration, event_name, event_data, target_time):
    task.sleep (duration)
    # Fire the event
@service
    task.create(timerwait, sleep_duration, event_name, event_data, target_time)
Ah, thanks for sharing! I wasn’t aware pyscript had its own asyncio wrapper.
Does that mean the timers work now? :smiley:
Yes! Finally have it working and the beginnings of a very big missing piece for voice. I know that there is a timer implementation for voice but it is limited to only ESPHome satellites whereas this is much more universal.
Thank you for your continued help and patience.
No problem! It helps me learn too, and you’ve always been clear in your questions, as well as polite and very appreciative in your answers. On multiple occasions I’ve found myself wanting to give a short answer, only to fall into a rabbit hole because I want to give one that is actually complete :joy:
hello, I need some advice. for a python script that reads out my energymeter information folliwing packages / modules are required:
import requests
import time
import json
import datetime
import logging      #from loggerdate import loggerdate
from pprint import pprint
import paho.mqtt.client as mqtt
import sys
is there a change to get it running with the pyscript addon and a requirements.txt?
I think so, most libraries should already be available from the Home Assistant installation. I think paho and pprint should be in requirements however.
I think the major problem could lie in using the paho library, as from looking at that you will need to implement the external event loop example in it.
I’m not too well acquainted with mqtt, but I think it would function better to configure the client in Home Assistant’s MQTT integration, and forward the gotten data to a pyscript defined service.
thanks for your replay … I rather think of writing a custom component for this. not that I still know how but seems to be for longterm a better solution.
Anyone seeing errors loading Pyscript using HA 2024.10? I’m getting this:
Logger: homeassistant.config_entries
Source: config_entries.py:594
First occurred: 6:58:54 PM (1 occurrences)
Last logged: 6:58:54 PM
Error setting up entry pyscript for pyscript
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 594, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/config/custom_components/pyscript/__init__.py", line 280, in async_setup_entry
    await install_requirements(hass, config_entry, pyscript_folder)
  File "/config/custom_components/pyscript/requirements.py", line 297, in install_requirements
    await async_process_requirements(
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 65, in async_process_requirements
    await _async_get_manager(hass).async_process_requirements(name, requirements)
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 264, in async_process_requirements
    self._raise_for_failed_requirements(name, missing)
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 292, in _raise_for_failed_requirements
    raise RequirementsNotFound(integration, [req])
homeassistant.requirements.RequirementsNotFound: Requirements for pyscript not found: ['PyDictionary'].
Hello, new to pyscript. Anyone know how to pass tuple value?
def change_light_color(entity_id):
    light.turn_on(
        entity_id = entity_id,
        brightness = 255,
        color_temp = 196,
        hs_color = [27.12, 17.875] #error on this line
The code above will throw MultipleInvalid: two or more values in the same group of exclusion 'Color descriptors' @ data[<Color descriptors>]
Any idea why?
color_temp is a way of specifying color. so is hs_color. i think you need to pick one.
I have had one successful pyscript but my second is an issue. This is the first time I have attempted to update a helper within a script and it has resulted in
state is not defined
My code is:
import colorsys
import sys
import os
import time
@service
def change_hsv_to_rgb(h,s,v, entity):
  contents, exception = task.executor(convert_hsv, h, s, v, entity)
  if exception:
      raise exception
  log.info(f"contents = {contents}")
@pyscript_compile
def convert_hsv(h, s, v, entity):
  hdecimal = round(h/100, 2)
  sdecimal = round(s/100, 2)
  vdecimal = round(v/100, 2)
  rgb_value = colorsys.hsv_to_rgb(hdecimal, sdecimal, vdecimal)
  state.set(entity, value=rgb_value)
The call I used for testing is:
convert_hsv(3,100,100,'input_text.front_bedroom_right_lamp_converted_rgb')
The full error is:
Exception in <jupyter_3> line 1:
NameError: name 'state' is not defined
I am testing via JupyterLabs but have also received the same error when attempting to run in Developer Tools. I thought ā€œstateā€ was built in Pyscript functionality?
UPDATE: MY mistake. Used the 1st script i wrote as a template. That needed compiled python for file manipulation. I put the state.set in this compiled function. Of course, it is not treated as pyscript. So have removed the compile section and merged into the service as i do not need compiled functionality. All works now
I think I am having the same problem. But I am new to HA and trying to write python for it for the first time, so I don’t know if my setup would have worked before the october update.
Is pydictionary something you wrote, or something you installed by pip, or…?
In my case I have created a pyscript_modules directory as described in the importing section of the docs, and included it in the requirements.txt (it’s the only entry at this time) and I get the same error you mention:
homeassistant.requirements.RequirementsNotFound: Requirements for pyscript not found: ['HAlocalIOutils'].
Did you ever find a solution?
I can’t remember the details but I think I just had it in the file that is used for includes. I did not write pydictionary. My solution was to remove it from the includes file as I was not still using the script I wrote that called it.
This isn’t much help to you I’m afraid. Good luck.
Did you ever come to a solution for this? I’m reading through the documents, and I can’t make heads or tails of it.
From memory (and it’s been a while) I gave up with the approach as I couldn’t install libraries I required with my HA all-in-one set-up.
Starting about a month ago, I have noticed that a lot of my @state_trigger have stopped triggering. I have tried rebooting HA and I have tried reloading pyscript.
I have:
@state_trigger(['input_select.living_temp_override',
                'input_select.master_temp_override',
                'input_select.media_temp_override',
                'input_select.office_temp_override',
                'input_select.junior_temp_override'])
def zone_override(**kwargs):
log.info(f"{kwargs['var_name']} Climate override to {kwargs['value']}")
This routine never gets called when I change any of those input_select values. Did HA do something that broke this, or is there a change to pyscript that I need to adapt to?
TIA
I started to use Pyscript for software PDHW on a standard UK S-plan heating system. During this, I came across an error message related to global variables that I don’t understand. I reduced it down to the minimum to show the issue.
This script works fine:
test_var = 1
@service
def test_f():
  log.info(f"{test_var}")
However, this one throws an error message:
test_var = 1
@service
def test_f2():
  test_var = 100
The error message is:
UnboundLocalError: local variable 'test_var' referenced before assignment
I’d like test_var to be a global variable that persists between function calls.
I’d appreciate any insights where I’m going wrong as I can’t see how an additional assignment would remove a variable from the scope.
You need to declare test_var as a global.:
@service
def test_f2():
  global test_var
  test_var = 100
