Finally I change to docker, i think it is complicate but it is very easy install and use docker.
I format sd and install new bullseye 11 version in my pi
I exec:
sudo apt-get update && sudo apt-get upgrade
sudo curl -sSL https://get.docker.com | sh
sudo groupadd docker
sudo usermod -a -G docker $USER
docker run hello-world
–if not work:
su -s ${USER}
sudo chown “$USER”:"$USER" /home/"$USER"/.docker -R
sudo chmod g+rwx “$HOME/.docker” -R
docker pull ghcr.io/home-assistant/home-assistant
docker run -d \
--name homeassistant \
--privileged \
--restart=unless-stopped \
-e TZ=Europe/Madrid \
-v /home/docker/homeassistant/config:/config \
--network=host \
ghcr.io/home-assistant/home-assistant:stable
- Change TZ to yours
- change /home/docker/homeassistant/config to your config dir.
that’s all folks
