I’ve recreated the QNAP integration and moved it to Config Flow… waiting to be accepted but you can use my repo for HACS in the meantime…
Hi.
I use your repo.
At the beginning of. Good job.
I don’t know if it’s a bug, but after adding the integration (my NAS is TS-453A) I only have part of the active entities. The others are inactive.
In particular, there is no information about disks. Their condition, free space, etc.
EDIT:
Yo. Problem solved Invisible entities were disabled. Turning them on manually helped.
SOLVED:
No where did I read my sensor was going to be “teamed” with my NAS name…
If this helps someone:
sensor.YourNasName_cpu_usage
Hi all,
HA newbie but reading and learning.learning.
I had errors in my log connecting to my TS-653D. SOLVED with Configuration file.
[At least I have no erros therefore I assume sensor is working]
The info is setup as sensors. Nice. OK.
Now, How do I read the sensor in a Card ? I read (!) the sensor doc but not with much success…
Someone has an example ? Any help is appreciated.
Just to confirm, this still requires an admin account without MFA, right? It’s just changed to the HASS config flow?
Yes, I created a “Hass” user, added to admin group. Then, in HASS configuration.yaml, copied the qnap example, added credentials. Reboot and voilà!
Hope this helps.
