I got this suggestion on reddit:
Good stuff
I found some good info on a uptime sensor
I added this to my sensors
- platform: uptime
name: "HA runtime in minutes"
unit_of_measurement: minutes
Then added this to automations that were having issues
condition:
- condition: numeric_state
entity_id: sensor.ha_runtime_in_minutes
above: 1
I also did a lot of changes to move more of my arrival/departure automation to be based on input selects, which can save the states using the recorder item in the configuration.yaml
# Record events
recorder:
purge_interval: 1
purge_keep_days: 5
I have this as well. Works pretty good so far.
I tried to do the same but inside the bayesian sensor, but it doesnāt seem to work for some reason?
binary_sensor:
- platform: bayesian
prior: 0.75
probability_threshold: 0.95
observations:
- entity_id: 'device_tracker.ping_fezsiphone7'
prob_given_true: 1
prob_given_false: 0.4
platform: 'state'
to_state: 'home'
- entity_id: 'device_tracker.nmap_fezsiphone7'
prob_given_true: 1
prob_given_false: 0.3
platform: 'state'
to_state: 'home'
- entity_id: 'device_tracker.icloud_fezsiphone7'
prob_given_true: 0.4
platform: 'state'
to_state: 'home'
- entity_id: 'sensor.home_assistant_uptime'
prob_given_true: 1
prob_given_false: 0
platform: 'numeric_state'
below: 3
couple of things. Iām not an expert so I could be wrong.
I donāt believe you can give a value of 1. 1 means 100% accurate all the time. If that was the case, then you would not need multiple. Try .9
The uptime was not meant to be used for the bayesian sensor, but as a condition in automations that trigger when you restart. Maybe it could work here, interesting concept, but I think it would not work well.
Also just on a personal level. I found ping to be useless for the iphone. It only reports true when Iām actually up and looking at my phone, soon after it reports off. Makes it pretty useless to me unless your phone is up and screen unlocked 100% of the time.
I recommend starting off with one or two sensors, get it to work and then add a couple more, then play with the true and false values until it works like you need it to.
Yes you can use 1, in my case it means that when the uptime is below 3 minutes this is going to be 100% accurate.
About ping, I recently added it as a fallback to nmap and it helped to make the sensor more reliable.
Good to know about the value of 1.
So does the sensor work without the uptime sensor added?
To me the syntax looks correct, so if it were me, Iād remove one sensor and see if it works, if so, then figure out what is āwrongā with the logic there.
As far as ping, totally a matter of choice. Like I said, for me on an iPhone, I realized that it only shows as ON when the phone is actively being used. If thatās a useful sensor, then use it. Of course it took me a while to realize that because I used my phone much of the time I was looking at presence, etc. It was not until I looked at states and state history on my computer that I realized that how it was working. I definitely agree that if it was on I was home, but that total ON time might only be 5 minutes here, 15 minutes, there, then off for hours.
I mean, the sensor works just fine, but it doesnāt mark me as home on restart of Hass, probably Iām doing something wrong, or the other sensors combined are still stronger than the uptime sensorā¦ probably I just have to reduce the prob_given_false
of them? Iāll try
Ahh that makes sense. I understand what your goal is now. I suspect that it still will not work, as it takes time to get the states from the other sensors, so even after a restart it might be off for a bit before switching to on. Not 100% sure though, so if you are able to get that working as intended, that would be pretty cool. I could see that having other uses as well.
For me I only have 4-5 automatons that were having issues, and adding the condition of uptime to those automatons solved my issue 100%. With the added bonus of not having to come back later and change anything if I made other changes.
condition:
entity_id: sensor.home_assistant_uptime
above: 1
So, I removed the uptime sensor from the bayesian and edited the presence sensor instead:
sensors:
fez_presence:
friendly_name: "Fez presence"
device_class: presence
value_template: >-
{% if states('sensor.home_assistant_uptime')|float > 3 %}
{{ is_state('binary_sensor.fez_presence_bayesian', 'on') }}
{% else %}
{{ True }}
{% endif %}
This seems to work fine!
You could simplify that a bit:
sensors:
fez_presence:
value_template: >-
{{ states('sensor.home_assistant_uptime')|float < 3 or
right, thanks
If I wanted to display a sensor in the UI that included zone, what would you recommend. I would probably be happy with just using the standard HA tracker that has the zone as a state. I can show it as a device tracker, but would like to show it as a sensor with an image, if possible I swear I had that going on a while back, but cannot seem to get it to show anymore.
Think you can use a template sensor and set the device class as a device tracker and use the entity_picture_template to change your pic dynamically.
So what I have which is not bad it this (AC is a zone). Also how do I get āhomeā to be captilized, Itās capital as a zone name.
That is based on this in my sensors.yaml
sensors:
paul_status:
value_template: '{{ states.device_tracker.pauls_iphone.state }}'
friendly_name: 'Paul'
tracy_status:
value_template: '{{ states.device_tracker.tracys_iphone.state }}'
friendly_name: 'Tracy'
What Iād ultimately like would be just a Pic of each of us in the circle, and in the zone below. I can get HOME, and AWAY if I use a binary sensor with a device class, but it will not show the zone. can I add
to a template in a sensors.yaml? the examples Iāve seen in the forums mostly focus on binary sensors
Easy, if you want it completely capitalized (i.e., not just the first letter.) Also, you might want to use the states() function to avoid errors if the entity doesnāt exist for some reason (e.g., during startup. Probably not necessary, but I think a good habit to get into. ) So:
value_template: "{{ states('device_tracker.pauls_iphone')|upper }}"
According to the docs, you can add device_class to a template sensor, but it doesnāt support presence as an option:
Thanks, good info. All caps will probably work for now, but what is weird is that all my zones (other than Home), show proper capitalization. Home is capitalized in my configuration.yaml (where my zones are). Would prefer just to have it as āHomeā, so that I dont have to captilize everything like āSCHOOLā, etc.
Again, no biggie. As far as showing the zone info below the pic, Iāll keep reading,
Yeah, for Device Tracker entities, home
and not_home
(all lower case) are special state values. Itās the frontend that shows them as Home
and Away
I believe. But if you want, you could do something like:
value_template: >
{% set loc = states('device_tracker.pauls_iphone') %}
{{ 'Home' if loc == 'home' else 'Away' if loc == 'not_home' else loc }}
If youāre currently in a zone (other than home) it should show the zone name as you defined it.
Thanks for the great tips. I will definitely use this elsewhere in my system, I swore when I first started messing with HA, before I really knew what I was doing, I had all my sensors showing up in my default view, and I swore I had a sensor like this for presence. I photo shopped the ZONE in this image
I mean I feel very confident that I remember zone names in the orange oval. Now of course Iām changed my device trackers, etc. But I feel like Iām just missing something simple. Is there any sort of device, sensor, etc that can display the zone in that area. If I could do that, then I could put an image vs text for the circle.
I know I could do home and away like that with a binary sensor.
So maybe Iām not following, but the basic device_tracker, as shown in the frontend, as-is, I think already does that. E.g., here I am:
The name of the zone Iām currently in is WorkPB, which is shown in the oval (albeit completely capitalized) because itās also the device_trackerās state:
The picture, and the friendly name, come from my customize.yaml.
