Radiation detector platform
would you mind posting the two solutioning elements you mentioned here?
I am evaluating the µRAD here as well and came across this posting (link and core content cited) - please be aware this addresses the uRADMonitor Radon but, radiation sensors might be treated the same way:
JSON output:
http://192.168.1.202/j
{"data": {"id":"1D000XXX","type":"1D","temperature":18.66,"humidity":57.38,"pressure":101355,"radon":84,"uptime":128050} }
SENSORS to create in HASSio:
  - platform: rest
    resource: http://192.168.1.202/j
    json_attributes:
      - data
    value_template: "OK"
    sensors:
      urad_temperature:
        value_template: "{{ state_attr('sensor.urad_sensors', 'data')['temperature'] }}"
        device_class: temperature
        unit_of_measurement: "°C"
      urad_humidity:
        value_template: "{{ state_attr('sensor.urad_sensors', 'data')['humidity'] }}"
        device_class: humidity
        unit_of_measurement: "%"
      urad_pressure:
        value_template: "{{ state_attr('sensor.urad_sensors', 'data')['pressure'] }}"
        device_class: pressure
        unit_of_measurement: "P"
      urad_radon:
        value_template: "{{ state_attr('sensor.urad_sensors', 'data')['radon'] }}"
        unit_of_measurement: "Bq/m3"
 urad_XXXXXX:
        value_template: "{{ state_attr('sensor.urad_sensors', 'data')['XXXXXX'] }}"
        device_class: XXXX # not mandatory, you can comment this line entirely
        unit_of_measurement: "XXX"
I have a station on https://www.uradmonitor.com/ It has a radiation detector and has been active for several years. My station is in Little Rock, AR, USA, but there are many stations around the world. I would love to have an interface for my data to be visible on Home Assistant.
There is an API for uradmonitor.com, so you should be able to; unfortunately it looks like you have to login to get to the API, so I can help you with that; but…some of the uradmonitor devices do have local API support, if yours is one then you can pull it all in locally. If you search the forum, there is another discussion on the local API for uradmonitors and that should get you what you need.
Edit: here is your API: URad API. Since you have the only one in Arkansas, you have a model A.
Update and keep alive heartbeat:
As you know, starting from version 2023.12.0, ESPHome has new requirements for Pin Reuse Validation of configuration files. These changes have also covered our GitHub repositories. We have already made the necessary changes to the examples for ESP8266, ESP32, Raspberry Pico W for ESPHome firmware. More details are available here:
BR, Oleksii
Hi all,
I wanted to integration radiation information in my dashboard. I do not have my own geiger machine.
Therefore I have to rely on publicly available information from the nearest data source.
In my case that was a weather station in De Bilt - The Netherlands.
I managed to get readings using home assistant rest configuration.
Thought I would share the used code.
Key was to know which station id to use and the knowledge that there are two values (and therefore two stations id’s). Namely AB (Alpha and Beta radiation), but the more important one was Gamma.
Here is my rest code:
# Radiation Values De Bilt NL1280 Gamma Value
- resource: "https://remap.jrc.ec.europa.eu/api/maps/point?id=NL1280"
  scan_interval: 1800 # check every 30 minutes
  headers:
      Content-Type: application/json
  - name: Radiation Utrecht Gamma Avg
    icon: mdi:radioactive-circle
    unit_of_measurement: nSv/h
    value_template: >
      {% if value_json.avg == 0 %}
        {{ sensor.radiation_utrecht_gamma_avg }}
      {% else %}
        {{ value_json.avg }}
      {% endif %}
  - name: Radiation Utrecht Gamma Min
    value_template: >
      {% if value_json.min == 0 %}
        {{ sensor.radiation_utrecht_gamma_min }}
      {% else %}
        {{ value_json.min }}
      {% endif %}
  - name: Radiation Utrecht Gamma Max
    value_template: >
      {% if value_json.max == 0 %}
        {{ sensor.radiation_utrecht_gamma_max }}
      {% else %}
        {{ value_json.max }}
      {% endif %}
# Radiation Values De Bilt NL0998 AB Value
- resource: "https://remap.jrc.ec.europa.eu/api/maps/point?id=NL0998"
  headers:
  - name: Radiation Utrecht AB Avg
    value_template: >
        {{ sensor.radiation_utrecht_ab_avg }}
      {% else %}
      {% endif %}
  - name: Radiation Utrecht AB Min
    value_template: >
        {{ sensor.radiation_utrecht_ab_min }}
      {% else %}
      {% endif %}
  - name: Radiation Utrecht AB Max
    value_template: >
        {{ sensor.radiation_utrecht_ab_max }}
      {% else %}
      {% endif %}
[update: I noticed that last week the rest API reported values of 0 as the API interface was under maintenance. Added this condition and only adding new values if they are not 0 - otherwise use the last known good value]
Happy Coding
Thank you for sharing this example with the community.
Best regards,
Oleksii
They have change something again, i get 0 value from every station from 7th of May.
Can anyone find out the new solution to scrapping this values? (I have no succes)
Same Problem here.
About 15Days no change…
Resonse from Site:
0
Service is under maintenance, try later
0
0
for a short time it back online but nothing again
anyone has idea how to scrap thoose datas?
So, played with it for a bit using postman.
Seems to intermittently work using a larger timeout with the REST call.
I am using now: timeout: 80
Will monitor how the content behaves over time.
Thank you Robert
This was the solution, all work again
:beers:
I have to correct myself
It can download data but it is always the same. All datas are constant so no change in values.
It looks like they are playing with provided datas but i do not know why and how can we get real valuse.
In case anyone is interested I’ve created a native climate guard radsens external component for esphome ( GitHub - krbaker/esphome-radsens ) since the only other option seems to be a custom component which is going to go away.
Did you ever get this to work properly again?
Does your sensor still work as intended?
Unfortunately not working as intended at this moment. I will play around again and update this topic if I find a solution.
TY for your reply.
-Mine is gone as well (And i have not had the time to look properly into alternative solutions) REMon has discontinued their simple map, which i used to extract data from.
Please post if you find alternative ways to get the data.
Hey Everyone!
I found this page which returns values for Germany:
https://strahlenschutz.api.bund.dev
But I am not able to formulate a query for the RESTful API for HA.
Can anyone help??
No, and have not find any other source
The API call (in my experience) is not a permanent solution for anything, often cancel or modify the API source so I’am looking for a scrap type solution as before
If no one of us find something soon i belive they do not want to inform us aboute correct radiation datas over europe
No one around to formulate a query for the RESTful API???
