I just paired a CT100 thermostat and I’m getting some incorrect behavior. Firstly it created 2 Thermostat entities. I disabled the second one since I don’t see a reason for it.
Secondly the operating mode (idle vs cooling) isn’t getting pushed to HA. I can change the target temp and see it reflected in HA but operating status doesn’t always. I don’t think it’s an issue with the thermostat itself because I did have it working fine in Hubitat. I’m a new user so if there’s any additional troubleshooting steps I need to take please guide me.
Not sure how helpful it is but I found this in the Z-wave JS logs
2021-05-27T20:53:52.970Z CNTRLR « [Node 007] supports 1 association groups [Endpoint 1]
2021-05-27T20:53:52.971Z CNTRLR » [Node 007] querying association group #1... [Endpoint 1]
2021-05-27T20:53:53.033Z CNTRLR « [Node 007] received information for association group #1: [Endpoint 1]
maximum # of nodes: 2
currently assigned nodes: 1
2021-05-27T20:53:53.037Z CNTRLR [Node 007] Interviewing Thermostat Mode... [Endpoint 2]
2021-05-27T20:53:53.037Z CNTRLR » [Node 007] querying supported thermostat modes... [Endpoint 2]
2021-05-27T20:53:53.085Z CNTRLR « [Node 007] received supported thermostat modes: [Endpoint 2]
· Off
· Heat
· Cool
· Auto
2021-05-27T20:53:53.086Z CNTRLR » [Node 007] querying current thermostat mode... [Endpoint 2]
2021-05-27T20:53:53.234Z CNTRLR « [Node 007] received current thermostat mode: Cool [Endpoint 2]
2021-05-27T20:53:53.236Z CNTRLR [Node 007] Interviewing Thermostat Setpoint... [Endpoint 2]
2021-05-27T20:53:53.236Z CNTRLR » [Node 007] retrieving supported setpoint types... [Endpoint 2]
2021-05-27T20:53:53.284Z CNTRLR [Node 007] Thermostat Setpoint bitmap interpretation is unknown, [Endpoint 2]
assuming B for now
2021-05-27T20:53:53.285Z CNTRLR » [Node 007] querying current value of setpoint Heating... [Endpoint 2]
2021-05-27T20:53:53.413Z CNTRLR « [Node 007] received current value of setpoint Heating: 70 °F [Endpoint 2]
2021-05-27T20:53:53.414Z CNTRLR » [Node 007] querying current value of setpoint Cooling... [Endpoint 2]
2021-05-27T20:53:53.520Z CNTRLR « [Node 007] received current value of setpoint Cooling: 75 °F [Endpoint 2]
2021-05-27T20:53:53.524Z CNTRLR [Node 007] Interviewing Multilevel Sensor... [Endpoint 2]
2021-05-27T20:53:53.525Z CNTRLR » [Node 007] querying current sensor reading... [Endpoint 2]
2021-05-27T20:53:53.613Z CNTRLR « [Node 007] received current sensor reading: [Endpoint 2]
sensor type: Humidity
value: 54 %
2021-05-27T20:53:53.624Z CNTRLR [Node 007] Interviewing Association... [Endpoint 2]
2021-05-27T20:53:53.625Z CNTRLR » [Node 007] querying number of association groups... [Endpoint 2]
2021-05-27T20:53:53.680Z CNTRLR « [Node 007] supports 1 association groups [Endpoint 2]
2021-05-27T20:53:53.681Z CNTRLR » [Node 007] querying association group #1... [Endpoint 2]
2021-05-27T20:53:53.727Z CNTRLR « [Node 007] received information for association group #1: [Endpoint 2]
2021-05-27T20:53:53.729Z CNTRLR [Node 007] Interviewing Thermostat Mode...
2021-05-27T20:53:53.729Z CNTRLR » [Node 007] querying supported thermostat modes...
2021-05-27T20:53:53.774Z CNTRLR « [Node 007] received supported thermostat modes:
· Off
· Heat
· Cool
· Auto
2021-05-27T20:53:53.775Z CNTRLR » [Node 007] querying current thermostat mode...
2021-05-27T20:53:53.934Z CNTRLR « [Node 007] received current thermostat mode: Cool
2021-05-27T20:53:53.935Z CNTRLR [Node 007] Interviewing Thermostat Setpoint...
2021-05-27T20:53:53.936Z CNTRLR » [Node 007] retrieving supported setpoint types...
2021-05-27T20:53:53.979Z CNTRLR [Node 007] Thermostat Setpoint bitmap interpretation is unknown, assuming B fo
r now
2021-05-27T20:53:53.980Z CNTRLR » [Node 007] querying current value of setpoint Heating...
2021-05-27T20:53:54.151Z CNTRLR « [Node 007] received current value of setpoint Heating: 70 °F
2021-05-27T20:53:54.153Z CNTRLR » [Node 007] querying current value of setpoint Cooling...
2021-05-27T20:53:54.308Z CNTRLR « [Node 007] received current value of setpoint Cooling: 75 °F
2021-05-27T20:53:54.326Z CNTRLR [Node 007] Interviewing Clock...
2021-05-27T20:53:54.328Z CNTRLR » [Node 007] requesting current clock setting...
2021-05-27T20:53:54.606Z CNTRLR « [Node 007] received current clock setting: Friday, 16:45
2021-05-27T20:53:54.619Z CNTRLR [Node 007] Interviewing Multilevel Sensor...
2021-05-27T20:53:54.620Z CNTRLR » [Node 007] querying current sensor reading...
2021-05-27T20:53:54.717Z CNTRLR « [Node 007] received current sensor reading:
sensor type: Air temperature
value: 72 °F
2021-05-27T20:53:54.720Z CNTRLR [Node 007] Interviewing Thermostat Operating State...
2021-05-27T20:53:54.722Z CNTRLR » [Node 007] querying thermostat operating state...
2021-05-27T20:53:54.839Z CNTRLR [Node 007] Interviewing Thermostat Fan Mode...
2021-05-27T20:53:54.840Z CNTRLR » [Node 007] querying supported thermostat fan modes...
2021-05-27T20:53:54.883Z CNTRLR « [Node 007] received supported thermostat fan modes:
· Auto low
· Low
2021-05-27T20:53:54.884Z CNTRLR » [Node 007] querying current thermostat fan mode...
2021-05-27T20:53:55.016Z CNTRLR « [Node 007] received current thermostat fan mode: Auto low
2021-05-27T20:53:55.027Z CNTRLR [Node 007] Interviewing Thermostat Fan State...
2021-05-27T20:53:55.028Z CNTRLR » [Node 007] querying current thermostat fan state...
2021-05-27T20:53:55.127Z CNTRLR [Node 007] Interviewing Configuration...
2021-05-27T20:53:55.128Z CNTRLR [Node 007] ConfigurationCC: skipping interview because CC version is < 3 and t
here is no config file
2021-05-27T20:53:55.132Z CNTRLR [Node 007] Interview stage completed: CommandClasses
2021-05-27T20:53:55.135Z CNTRLR [Node 007] Interview stage completed: OverwriteConfig
2021-05-27T20:53:55.136Z CNTRLR » [Node 007] requesting node neighbors...
2021-05-27T20:53:55.155Z CNTRLR « [Node 007] node neighbors received: 1, 5, 6
2021-05-27T20:53:55.156Z CNTRLR [Node 007] Interview stage completed: Neighbors
2021-05-27T20:53:55.157Z CNTRLR [Node 007] Interview completed
2021-05-27T20:53:55.158Z CNTRLR [Node 007] The node is ready to be used
2021-05-27T20:55:44.417Z CNTRLR [Node 007] Mapping unsolicited report from root device to first supporting end
point #1
2021-05-27T20:55:44.442Z CNTRLR [Node 007] Mapping unsolicited report from root device to first supporting end
point #1
2021-05-27T20:55:45.189Z CNTRLR [Node 007] Mapping unsolicited report from root device to first supporting end
point #1
2021-05-27T20:55:45.212Z CNTRLR [Node 007] Mapping unsolicited report from root device to first supporting end
point #1
2021-05-27T20:55:51.642Z CNTRLR [Node 007] Mapping unsolicited report from root device to first supporting end
point #1
2021-05-27T20:55:51.667Z CNTRLR [Node 007] Mapping unsolicited report from root device to first supporting end
point #1
2021-05-27T20:55:58.205Z CNTRLR [Node 007] Mapping unsolicited report from root device to first supporting end
point #1
2021-05-27T20:55:58.230Z CNTRLR [Node 007] Mapping unsolicited report from root device to first supporting end
point #1
2021-05-27T21:05:25.208Z CNTRLR [Node 007] Mapping unsolicited report from root device to first supporting end
point #1
2021-05-27T21:05:25.232Z CNTRLR [Node 007] Mapping unsolicited report from root device to first supporting end
point #1
