Raising temperature by one degree - Climate device
I didn’t do it with the editor, but following this article.
Well the template editor is a debugging tool. It is designed to help with such problems, so give it a try.
After a few attempts I solved it, all I had to do was put the double quotes. For a stupid thing, I wasted a lot of time.
temperature: "{{ state_attr('climate.split_salone' , 'current_temperature') | float | round(0) + 1 }}"
Thanks anyway.
I’m trying this right now, but getting stuck. This is what I have:
service: climate.set_temperature
  entity_id: climate.trv_arbeitszimmer
  temperature: >-
    {{ (state_attr('climate.trv_arbeitszimmer', 'temperature') | round(0)) - 1
Saves without issues but doesn’t work. Triggering it manually doesn’t give an error popup or anything, but checking the execution trace, I see this error for the according step:
must contain at least one of temperature, target_temp_high, target_temp_low.
But temperature is right there in the yaml… I also tried changing data to data_template as seen in the other posts here but honestly I have no idea what that would mean or do.
Surely target_temperature is what you want?
You mean in the state_attr expression or the yaml key?
I basically just followed the instructions from the post I quoted, i.e. create the action via GUI and then just change the numeric value, so the temprerature key was already there. I interpreted the error message as telling me that the only valid keys there would be temperature, target_temp_high and target_temp_low. I tried all three and the error stayed the same. Now I also tried target_temperature but that results in exactly the same behavior.
As for the expression, I tested it in the template editor, and state_attr('climate.trv_arbeitszimmer', 'temperature') gives me the current setting, so that seems to be correct at least.
Yes sorry it is temperature.
Well, that was a big facepalm when I solved it. In the GUI, I apparently didn’t click “select device” but “select entity”. In both cases you can select the TRV and everything looks like it should work, except that it doesn’t. Even setting a fixed temperature leads to the same failure, so this doesn’t have anything to do with templates or anything. So you want a device_id as target, not an entity_id.
I think the formatting and commands changed just again - I tried for long time and for me it only works with using entity, not with using device for increasing/decreasing temperatur. If I set absolute temperature then it works for both so this is pretty confusing.
I think the main problem is that now there is no more service but it’s directly action: climate.set_temperature
My working script to increase temperature:
alias: Temperature Up
sequence:
  - action: climate.set_temperature
    metadata: {}
      temperature: >-
        {{ state_attr('climate.midea_ac_153931628704054' ,
      entity_id: climate.midea_ac_153931628704054
mode: single
icon: mdi:arrow-up
description: ""
