Thanx!
When writing 00:{{ range(1,10) | random | int }}:00'
in templates I get ex 00:8:00 that home assistant dont like. It should be in hh:mm:ss. What changes should i do?
"00:{{ '{:02}'.format(range(1,10) | random | int) }}:00"
After adding that i get this error in my log
2018-11-28 21:24:54 ERROR (SyncWorker_0) [homeassistant.util.yaml] while parsing a block mapping
in "/config/automations/test.yaml", line 7, column 5
expected <block end>, but found '{'
in "/config/automations/test.yaml", line 7, column 20
2018-11-28 21:24:54 ERROR (MainThread) [homeassistant.bootstrap] Error loading /config/configuration.yaml: while parsing a block mapping
gotta post your whole config, canât tell what the error is
This works fine for me:
- delay: '00:{{ (range(1, 59)|random|int) }}:{{ (range(1, 59)|random|int) }}'
I donât personally use delays so Iâm not certian if the numbers need to have leading zeros when under 10. If that works, then that is what @Henrik1986 should use.
Sorry. This is the config that gave me the errors. And yes home assistant will have this format HH:MM:SS or HH:MM
alias: TEST
platform: state
entity_id: input_boolean.trigger
to: 'on'
- delay '00:{{ '{:02}'.format(range(1,10) | random | int) }}:00'
- service: homeassistant.toggle
data_template:
entity_id: '{{ states.group.away_lights.attributes.entity_id | random }}'
Home assistant will have two numbers in minutes also.
Your issue is because you have quotes inside quotes. You cannot encapsolate single quotes inside single quotes. You need to use double quotes for the entire template and single quotes inside the template. Also, you are missing the colon after the word delay. Remember, yaml is space and punctuation driven, without that, yaml doesnât know how to parse properly.
alias: TEST
platform: state
to: 'on'
- delay: "00:{{ '{:02}'.format(range(1,10) | random | int) }}:00"
data_template:
Thanks for the lesson. Learned a lot today. Thank you
Here is the code cleaned up⌠note conditions are by default AND so that part wasnât needed.
## Turn on/off indoor lights randomly while night and armed away
- alias: Random Away Lights
initial_state: True
hide_entity: False
- platform: time
minutes: '/20'
seconds: 00
condition:
- condition: state
entity_id: alarm_control_panel.ha_alarm
state: 'armed_away'
- condition: sun
after: sunset
- delay: '00:{{ range(1,19) | random | int }}:00'
data_template:
entity_id: "{{ state_attr('group.indoor_random_away_lights','entity_id') | random }}"
It did, but there is change that it wonât work because home assistant will have the time delay in this two formats.
HH:MM:SS or HH:MM
So if the random delay is 8 min home assistant will not fire the action.
So I made some changes after some days. Itâs pretty annoying that lights is turn off or on when i come home because the random delay. So i did a script with the conditions that itâs only execute when the alarmpanel is disarmed after that a random lamp is turned off or on.
But one question. Is it possible to send brightness level in the action section in the scripts. when the lamp is turned of and then turned on is comes back on 100 %.
alias: Belysning - inte hemma
platform: time
minutes: '/45'
seconds: 00
condition:
condition: and
conditions:
- condition: state
state: 'armed_away'
- condition: sun
after: sunset
- delay: "00:{{ '{:02}'.format(range(1,30) | random | int) }}:00"
- service: script.turn_on
entity_id: script.away
Script
away:
alias: Away lights
sequence:
- condition: state
state: 'armed_away'
data_template:
Youâd have to turn the group into a light group if you want to pass brightness to the lights in the group. Also, theyâll all have to be lights.
Thanks for asking this question as itâs given me inspiration to set this up myself!
For those interested here is my complete ârandom lightâ code.
It also includes automations for sunrise and alarm disarm to turn off the lights itâs randomly turned on.
As always suggestions and improvements welcome! I learn so much from this community â it truly is fantastic.
## Random lights on while sunset and armed away
initial_state: True
hide_entity: False
- platform: time
minutes: '/30'
seconds: 00
condition:
- condition: state
state: 'armed_away'
- condition: sun
after: sunset
- delay: "00:{{ '{:02}'.format(range(1, 29) | random | int) }}:00"
- condition: state
state: 'armed_away'
data_template:
## Sunrise Random Lights Off
- alias: Random Lights Off Sunrise
initial_state: True
hide_entity: False
- platform: sun
event: sunrise
condition:
- condition: state
state: 'armed_away'
- service: homeassistant.turn_off
entity_id: group.indoor_random_away_lights
## Alarm Disarmed Random lights Off
- alias: Random Lights Off Disarmed
initial_state: True
hide_entity: False
- platform: state
to: 'disarmed'
Does this work? I thought you needed to ensure that hh, mm and ss were always two digits.
I do this:
- delay: "00:{{ '{:02}'.format(range(5, 11) | random | int) }}:00"
Apparently thatâs up for debate because many people claim they are using it without the leading zero.
Maybe their random number has never been one digit long
murphyâs law right there!
