Random rgb_color in scene
You’re such a bad ass! Thank you so much, couldn’t have spotted that in a hundred years!
Edit: This is a workaround for setting an effect on Tasmota Magic Home LED. By change you know how to let this loop for about a minute, it only changes once now… Cant seem to find any guides, saw another post of yours but not really apliccable in my case.
You want it to change colour every few seconds for a minute? If so, how random do you want it to be? Like does it always go red, yellow, blue, green, purple but just the start color is different each time? Or is the first colour based on something? Or do you just want a completely random colour every time?
Well it really doesnt matter, id like to use it in my alarm setup to draw attention so it just has to switch fast until the state of the alarm is disarmed, or as lomg as its triggered.
I tried the snippit from above followed by turn off an then copied that like 100 times, didnt work and ofcourse a nasty workaround.
Thanks for your help!
Ezra
maybe my party lights script helps:
  lights_partying_on:
    alias: Lights partying on
    sequence:
      service: light.turn_on
      data_template:
        entity_id: light.{{['dining_corner','cabinet','kist','home_theater']|random}}
        rgb_color: ['{{ (range(0, 255)|random) }}',
                    '{{ (range(0, 255)|random) }}']
        brightness: '{{ (range(50, 250)|random) }}'
        transition: '{{ (range(1, 3)|random) }}'
call this with the following automation each 4 seconds:
automation:
  - alias: 'Lights partying'
    id: 'Lights partying'
    initial_state: 'off'
      platform: time
      seconds: '/4'   # {{ "/" ~ ((range(2, 5) | random) | int) }}
    condition:
      condition: template
      value_template: >
        {{is_state('automation.sense_lights_change','off') }}
      service: script.lights_partying_on
and this input_boolean for setting the mode:
  - alias: 'Lights Party Mode'
    id: 'Lights Party Mode'
    initial_state: 'on'
      platform: state
      entity_id: input_boolean.home_mode_party
      service_template: >
        script.lights_mode_party_{{ trigger.to_state.state }}
OK, off the top of my head I would probably do it like this:
automation:
  - alias: Police
      - platform: state
        entity_id: alarm_control_panel.house
        to: 'triggered'
      - service: script.light_cycle
      - delay: '00:01:00'
      - service: homeassistant.turn_off
        entity_id:
          - script.light_cycle
          - script.loop_lights
script:
  light_cycle:
    sequence:
      - service: homeassistant.turn_on
        entity_id: group.all_lights
        data_template:
          brightness: 250
          color_name: >
            {% set colors = ['red', 'yellow' , 'blue', 'green' , 'purple'] %}
            {{ colors|random }}
      - service: script.loop_lights
  loop_lights:
    sequence:
      - delay: '00:00:02'
Fairly simple, but does the business.
cool this loop. you’re a magician!
—> Cookbook this goes.
Super!! thanks mate!
is there a way to use mili seconds instead of seconds? To have it change the color faster perhaphs?
Thanks again!
Edit: got the miliseconds now, but it still doesnt loop, it turns on and does not change just once.
- alias: "[Alarm] Police on"
    - platform: state
      to: 'triggered'
- alias: "[Alarm] Police off"
    - platform: state
      to: 'disarmed'
      entity_id:
  light_cycle:
    sequence:
        data_template:
          brightness: 100
          color_name: >
            {{ colors|random }}
  loop_lights:
    sequence:
      - delay:
          milliseconds: 10
Ok i got it down to about 3 changes right now with this config:
scripts.yaml:
  light_cycle:
    sequence:
      - service: light.turn_on
        data_template:
          brightness: 250
          color_name: >
            {{ colors|random }}
  loop_lights:
    sequence:
      - delay:
          milliseconds: 5
automations.yaml:
    - platform: state
      to: 'triggered'
    - service: light.turn_off
    - platform: state
      to: 'disarmed'
      entity_id:
Any advice?
The problem is that when you’re looping, if the first script is still running when the second one tries to start it again then everything stops. So by bringing the time down to milliseconds, your lights are probably still changing colour from the last go, so the script is still running, so it stops.
I suppose you could try stopping the first script before restarting it.
Good one, it loops alright now. but not as fast as i want. Could also be that it are mqtt lights?
  light_cycle:
sequence:
    entity_id: script.loop_lights
    data_template:
      brightness: 250
      color_name: >
        {{ colors|random }}
  loop_lights:
    sequence:
        entity_id: script.light_cycle
      - delay:
          milliseconds: 5
Yeah, it’s tempting to want the lights to strobe like you’re trying to induce a seizure, but unless they’re specifically designed as an anti-epileptic device lights normally don’t react that quickly so you have to have a bit of a delay.
In fairness, I bet if you stand over the road in the dark and trigger this it will still be pretty eye-catching :slight_smile:
Haha, nice one. Yeah indeed, I’ll tinker on for a bit to tweak it. I’m glad it works so far with your help. Thanks a bunch my friend!
No worries :+1:
I like the concept of these party light animations. But I cant trace the linkages between the input_boolean, the script and the automation? (their seems to be missing scripts?)
Do you have a link to your package yaml?
sure, here you go. Please note the input_boolean.home_mode_party isn’t in here, because it is triggering some other things too, its in a another package, but nothing fancy, just:
# Package Home Modes
# @Mariusthvdb
homeassistant:
  customize:
    input_boolean.home_mode_party:
      templates:
        icon: >
          if (state === 'on') return 'mdi:cake-layered';
          return 'mdi:hotel';
        icon_color: >
          if (state === 'on') return 'rgb(251, 210, 41)';
          return 'rgb(54, 95, 140)';
# Inputs
input_boolean:
  home_mode_party:
    initial: off
# Sensors
# scripts
script:
  home_mode_party:
    alias: Home mode party
    sequence:
        entity_id: input_boolean.motion_detection
# automation
automation:
  - alias: 'Home mode Party'
    id: 'Home mode Party'
    initial_state: 'on'
      platform: state
      to: 'on'
      service: script.home_mode_party
# Small package Partymode
# @Mariusthvdb  02102018
#homeassistant:
#  customize:
#    switch.mode_party:
#      templates:
#        icon: >
#          if (state === 'on') return 'mdi:cake-layered';
#          return 'mdi:hotel';
#        icon_color: >
#          if (state === 'on') return 'rgb(251, 210, 41)';
#          return 'rgb(54, 95, 140)';
# Switch
#switch:
#  - platform: template
#    switches:
#      mode_party:
#        friendly_name: Party mode switch
#        value_template: >
#          {{ is_state('automation.lights_partying', 'on') }}
#        turn_on:
#          - service: script.home_mode_party #(turn off motion sensors, package home_mode)
#          - service: script.lights_mode_party_on #(turn off sense lights automation, on party Lights
#        turn_off:
#          - service: script.lights_mode_party_off
# Scripts
script:
  lights_mode_party_on:
    alias: Party on
    sequence:
        entity_id: automation.sense_lights_change
      - delay:
          seconds: 5
        entity_id: automation.lights_partying
  lights_mode_party_off:
    alias: Party off
    sequence:
      - service: automation.turn_off
      - delay:
          seconds: 2
      - service: script.lights_partying_reset
      - delay:
          seconds: 2
      - service: script.lights_partying_off
      - delay:
          seconds: 10
  lights_partying_on:
    sequence:
      data_template:
  lights_partying_reset:
    alias: Lights partying reset
    sequence:
        entity_id:
          - light.dining_corner
          - light.cabinet
          - light.kist
          - light.home_theater
        profile: relax
  lights_partying_off:
    alias: Lights partying off
    sequence:
      entity_id:
        - light.cabinet
        - light.kist
# Automations
automation:
      platform: time
    condition:
      condition: template
      value_template: >
    initial_state: 'on'
      platform: state
      service_template: >
I love this concept… Thanks for sharing
I 'm trying to modify it to only flicker red and blue lights in order to simulate police lights.
This kind of flickers the red and blue but it is mixed in with gentle transitions of yellow green blue red and purple.
  alias: Police
  description: ''
  - entity_id: alarm_control_panel.home_alarm
    platform: state
    to: 'triggered'
  condition: []
  - data: {}
  - data: {}
  mode: single
light_cycle:
  alias: Light Cycle
  #mode: single
  sequence:
    entity_id: switch.office_on_off
    data_template:
      brightness: 255
      color_name: >
        {% set colors = ['red', 'blue'] %}
#        {{ colors|random }}
loop_lights:
  alias: Loop Lights
  #mode: single
  sequence:
    - delay:
        milliseconds: 5
    entity_id: light.{{['hue_color_lamp_1','hue_color_lamp_2'] | random }}
      brightness: 250
      color_name: >
        {% set colors = ['red', 'yellow' , 'blue', 'green' , 'purple'] %} {{
        colors|random }}
mode: single
HI Team
I get the error - not a valid value for dictionary value @ data[‘action’][0][‘entity_id’]
I can see in the sample before a data_template is used, but can I do what I’m trying in an automation - so selecting randomly between a few ligths…
/Joern
think you need to change it to:
entity_id: >
or use quotes:
entity_id: "light.{{['hue_color_lamp_1','hue_color_lamp_2'] | random }}"
not sure about the latter though, I use the former (now)… this is an old post
  lights_partying_on:
    mode: restart
    sequence:
        entity_id: >
          light.{{['frontdoor','dining_corner',
                   'lounge_chair_long','home_theater','world_map']|random}}
        rgb_color: >
          {{[range(0,255)|random,range(0,255)|random,range(0,255)|random]}}
        brightness: >
          {{range(50,250)|random}}
        transition: >
          {{range(1,3)|random}}
thank you.
Works perfectly.
/Joern
