Raspberry Pi 4 Model B temperature
47ºC in the current warm weather ? The poor thing will be shivering :smile: Perhaps it needs more to do.
My R Pi 4b has ranged between 56ºC and 64ºC loafing along in the last 24 hours. I do have a fan that would cut in at 65ºC but it’s not reached that, even with a dashboard of 6 mjpeg IP cams displayed.
This part did not work for me… everything else is great.
Any idea why this would not work?
Did you install? E.g. with HACS.
Yes download zip and extract.
copy folder rpi_power over to custom_components and restart HA.
Regards,
Thanks. I did install other HACS components, but missed that one. It works now.
Thank you for your configuration!
You have this defined two times:
and
Is this:
working?
I always get the version “latest”. I don’t think that this is intended?
Yeah I made some tweaks since I first posted my config.
This is my latest configuration.yaml
#=== System Sensors
  - platform: command_line
    name: RPi CPU Temperature
    command: "cat /sys/class/thermal/thermal_zone0/temp"
    value_template: "{{ value | multiply(0.001) | round(2) }}"
  #=== Latest Sonoff Tasmota firmware version
    name: Tasmota Current Version
    command: "curl -s https://github.com/arendst/Sonoff-Tasmota/releases/latest | cut -d'\"' -f2 | rev | cut -d'/' -f1 | rev"
    scan_interval: 86400
  #=== Installed hass.io version
  - platform: version
    source: local
  #=== Latest Available HA Version
  - platform: version
    name: Latest Available Version
    beta: false
    image: raspberrypi4
    source: hassio
  #=== Raspberry Pi Power
  - platform: rpi_power
    text_state: True
  #=== Last boot time, Disk, memory & CPU usage
  - platform: systemmonitor
    resources:
      - type: last_boot
      - type: disk_use_percent
        arg: /
      - type: memory_use_percent
      - type: processor_use
  #=== CPU Temperature
    unit_of_measurement: "°C"
    value_template: '{{ value | multiply(0.001) | round(0) }}'
  #=== System Up Time
  - platform: uptime
    sensors:
      #=== Home Assistant uptime
      ha_uptime:
        friendly_name: HA Uptime
        value_template: >
          {% if states('sensor.uptime') == '0.0' %}
            Just restarted...
          {% else %}
            {% macro phrase(value, name) %}
            {%- set value = value | int %}
            {%- set end = 's' if value > 1 else '' %}
            {{- '{} {}{}'.format(value, name, end) if value | int > 0 else '' }}
            {%- endmacro %}
            {% set weeks = (states('sensor.uptime') | int / 7) | int %}
            {% set days = (states('sensor.uptime') | int) - (weeks * 7) %}
            {% set hours = (states('sensor.uptime') | float - states('sensor.uptime') | int) * 24 %}
            {% set minutes = (hours - hours | int) * 60 %}
            {{ [ phrase(weeks, 'week'), phrase(days, 'day'), phrase(hours, 'hr'), phrase(minutes, 'min') ] | select('!=','') | list | join(', ') }}
          {% endif %}
      #=== Raspberry Pi last boot date and time
      last_boot_date_time:
        friendly_name: Last Boot
        value_template: >
          {% set date = as_timestamp(states('sensor.last_boot')) | timestamp_custom('%d') %}
          {% set date = '{:01}'.format(date | int) %}
          {% if date in ('1', '21', '31') %}
            {% set date = date ~ 'st' %}
          {% elif date in ('2', '22') %}
            {% set date = date ~ 'nd' %}
          {% elif date in ('3', '23') %}
            {% set date = date ~ 'rd' %}
          {% else %}
            {% set date = date ~ 'th' %}
          {% endif %}
          {{ as_timestamp(states('sensor.last_boot')) | timestamp_custom('%H:%M on %a') }} {{ date }} {{ as_timestamp(states('sensor.last_boot')) | timestamp_custom('%b %Y') }}
      #=== Raspberry Pi Up Time
      rpi_uptime:
        friendly_name: RPi Uptime
        entity_id: sensor.time
        value_template: >
          {% set up_time = as_timestamp(now()) - as_timestamp(states('sensor.last_boot')) %}
          {% set minutes = (up_time // 60) | int %}
          {% set hours = (minutes // 60) %}
          {% set days = (hours // 24) %}
          {% set weeks = (days // 7) %}
          {% set minutes = (minutes % 60) %}
          {% set hours =  (hours % 24) %}
          {% set days = (days % 7) %}
                    {%- set value = value %}
          {%- endmacro %}
          {% set text = [ phrase(weeks, 'week'), phrase(days, 'day'), phrase(hours, 'hr'), phrase(minutes, 'min') ] | select('!=','') | list | join(', ') %}
          {% set last_comma = text.rfind(',') %}
          {% if last_comma != -1 %}
            {% set text = text[:last_comma] + ' and' + text[last_comma + 1:] %}
          {% endif %}
          {{ text }}
As far as I am aware the Tasmota sensor is working as intended.
Regards,
It looks the same. The Pi temperature is still defined two times. One time at the beginning and one time a little bit later. You use this command at both entries: “cat /sys/class/thermal/thermal_zone0/temp”, so you will get the same. :slight_smile:
If I look at your picture at the beginning the entry is “latest” and not 8.3.1. That is because the curl command gives this:
<html><body>You are being <a href="https://github.com/arendst/Tasmota/releases/latest">redirected</a>.</body></html>
The URL should be Release Tasmota v13.4.0 Quinta · arendst/Tasmota · GitHub. Then you get this:
curl -s https://github.com/arendst/Tasmota/releases/latest
<html><body>You are being <a href="https://github.com/arendst/Tasmota/releases/tag/v8.3.1">redirected</a>.</body></html>
with the correct version number inside.
Thanks for the observation, updated.
For those interested in the original thread I have installed the Pi 4 B in the FLIRC case and my temperature now is averaging 45 °C
#=== System Sensors
  #=== Latest Tasmota firmware version
    command: "curl -s https://github.com/arendst/Tasmota/releases/latest | cut -d'\"' -f2 | rev | cut -d'/' -f1 | rev"
  - platform: version
    source: local
  - platform: version
    beta: false
    image: raspberrypi4
    source: hassio
    text_state: True
    resources:
      - type: last_boot
        arg: /
  #=== System Up Time
  - platform: uptime
    sensors:
      ha_uptime:
        value_template: >
            Just restarted...
          {% else %}
            {%- endmacro %}
          {% endif %}
        value_template: >
          {% else %}
          {% endif %}
      rpi_uptime:
        value_template: >
          {%- endmacro %}
          {% endif %}
          {{ text }}
Just waiting for the ability to boot the PI from SSD, fingers crossed.
Regards,
Now suddenly, the graph for the top four items are no longer showing up. I tried to reinstall the HACS custom cards, but still no luck. My configuration.yaml (actually sensors.yaml) is the same as what it was before when it was working.
Any thoughts?
I take it you have tried refresh, restart and clear cache?
my lovelace config.
cards:
  - cards:
      - entities:
          - sensor.rpi_cpu_temperature
        font_size: 75
        line_color: red
        line_width: 8
        show:
          average: true
          extrema: true
          fill: fade
          icon: true
          points: true
          state: true
        type: 'custom:mini-graph-card'
      - entities:
          - sensor.disk_use_percent
        font_size: 75
        line_color: blue
        line_width: 8
        show:
          average: true
          extrema: true
          fill: fade
          icon: true
          points: true
          state: true
    type: horizontal-stack
  - cards:
      - entities:
          - sensor.memory_use_percent
        font_size: 75
        line_color: red
        line_width: 8
        show:
          average: true
          extrema: true
          fill: fade
          icon: true
          points: true
          state: true
      - entities:
          - sensor.processor_use
        font_size: 75
        line_color: blue
        line_width: 8
        show:
          average: true
          extrema: true
          fill: fade
          icon: true
          points: true
          state: true
  - cards:
      - columns: 3
        entities:
          - sensor.ha_uptime
          - sensor.hacs
          - sensor.installed_version
          - sensor.last_boot
          - sensor.last_boot_date_time
          - sensor.latest_available_version
          - sensor.rpi_power_status
          - sensor.rpi_uptime
          - sensor.tasmota_current_version
          - binary_sensor.updater
          - sensor.uptime
        type: glance
title: SYSTEM MONITORING
type: 'custom:vertical-stack-in-card'
what is sensors.yaml?
Yes, I did the refresh and cache clear etc. Still didn’t work.
Sensor.yaml is just split out from configuration.yaml with an include statement.
group: !include groups.yaml
script: !include scripts.yaml
panel_iframe: !include panel_iframe.yaml
switch: !include switches.yaml
cover: !include cover.yaml
sensor: !include sensors.yaml
ios: !include ios.yaml
Reinstall of custom mini-graph-card via HACS, I am running v0.9.3 ?
Other than that I’m stumped, try opening an issue.
Regards,
Ok, thanks. It’s strange because it worked for a while then suddenly stopped. I have reinstalled all the HACS cards and still no graphing.
This fixed it:
Just a few days ago, HACS updated [custom-components/sensor.rpi_power](https://github.com/custom-components/sensor.rpi_power) to version 0.2.0. The breaking change was that the rpi_power sensor went from sensor: to binary_sensor:. I did the changes recommended on the Github page (changes to configuration.yaml plus change lovelace cards and automations from sensor.rpi_power_status to binary_sensor.rpi_power_status.) Unfortunately after restarting the server, I get a Notification that “Platform error binary_sensor.rpi_power - No module named 'custom_components.rpi_power.binary_sensor” and the System Monitoring Card from @MarkB1 still does not show “RPi Power Status” (little yellow triangle indicating the entity isn’t available, see below).
This is frustrating because rpi_power is in fact in the custom components directory, and I did exactly what the rpi_power GitHub told me to do. There is no binary_sensor.rpi_power in the entities list. Any ideas?
See the folllowing.
https://github.com/custom-components/sensor.rpi_power/issues/45
Just checked my own as i am not experiencing this.
I manually installed 0.1.5 and it still works fine for now, might not in future, will cross that bridge when I get to it.
Thanks. I used the process proposed by regystro:
This brought the integration to 0.2.0 and it works. So, if you want to upgrade to 0.2.0, it appears to be a working process.
Could you post the steps? seems that link gets the good ol 404 now.
