Raspberry Pi 5
From the two or three decades ago? Did you build that one yourself and messed up the power manangement? :stuck_out_tongue_winking_eye:
Our last HA Server with a CPU now almost 10 years old actually had a lower power consumption than a Raspberry while still having a better performance. The thing was even smaller than a PI and doesn’t rely on a sd card for storage and was conveniently powered via microUSB and
This thing like most x86/x64 often have a better power management than SBC’s. For example a Raspberry Pi 4 is idling with almost 3W while our device was happy with just 1W :warning: :zap:
Correct, and the Raspberry Pi 4 was/is quite bad in this scenario! Worst than a random Intel CPU from the last decade :scream:
Correct, people buying a Raspberry thinking it is low power and ending up with a energy bill 3 times higher than if they would have used a old device from the drawer :man_facepalming:
Think of the following: Demanding task coming in your Pi 4 is blocked for couple of seconds/minutes because of 100% cpu usage. Another device (maybe 10 years old) with a 7x higher performance doesn’t need the 100% usage and allows to use the HA web ui all the time while your Raspberry craps out and is unresponsive :put_litter_in_its_place:
Specification comparison:
Processor Intel Atom Z3735F Broadcom BCM2711
Market (main) Notebook Single-board computer
ISA x86-64 (64 bit) ARMv8-A (64-bit)
Release date Q1 2014 Q2 2019
Lithography 22 nm 28 nm
Cores 4 4
Threads 4 4
High performance cores 4 Cores 4 Threads @ 1.33 / 1.83 GHz 4x ARM Cortex-A72 @ 1.5 GHz
TDP 2 W 8 W
(Multi-core / watt performance) Performance / watt ratio 938 pts / W 128 pts / W
As mentioned it is not the same device :see_no_evil:
No? Other than a SBC the thing is complete and works out of the box as unlike berries it comes with case, cooling, flash, rtc, psu :bulb:
If you are REALLY interested in saving power you wouldn’t have bought/used a Raspberry Pi 4 in the very beginning :wink:
Benchmarks indeed are the opposite of real life scenarios. Little more than just a grain of salt necessary :wink:
Well, it does to some extended. As higher the performance per Watt is as lower is the power consumption. Why is that? Because the device with a higher performance/Watt ratio is more efficient :warning:
See the table above? This 10 year cheap atom CPU has a TDP of 2W compared to 8W for the Raspberry SOC. Bottom line the raspberry still performs worse while producing 4 times the heat which is just wasted energy :fire:
If i’ve read correctly NUC will be Asus in the future. Things was, i think, sold to Asus (or merged…).
Correct.
Even if the trademark “nuc” died with Intel, there will continue to be many using the basic form factor.
Nuc-luke pcs aren’t going away anytime soon.
I’m seeing a measured power usage on my RPi4 of 0.11 kWh a day. That’s an average usage number… calculated from over a year of usage. Measured with an uncertified power meter. (Zigbee powerplug.) Not seeing blocked UI on HA… So that’s interesting. :slight_smile:
I like your elaborate answer. Taking notes here. That 50 power usage might be a crap power supply… that’s a good one.
Why are you looking at TDP? That’s just a measure of radiated heat when under load? The key being “under load” I’m mostly interested at energy consumption under low load conditions.
Very wishful “measurements” you got there :joy:
Just checking the first 3 results I get for idle power of a RPi4 :point_down:
Raspberry Pi 4 B
Pi State Power Consumption
Idle 540 mA (2.7 W)
ab -n 100 -c 10 (uncached) 1010 mA (5.1 W)
400% CPU load (stress --cpu 4) 1280 mA (6.4 W)
Power Consumption Benchmarks | Raspberry Pi Dramble
Raspberry Pi 4 Power Consumption
The power consumption of the Raspberry Pi 4 varies – when idle it tends to consume around 3 to 4 watts, with an increase of 0.5 watts for each core that is then busy, up to a maximum of 6 watts when all four cores are working.
Raspberry Pi Power Consumption Guide (2024)
Model IDLE LXDE loaded 1080 resolution video 400% CPU loaded
Raspberry Pi 4B 575 mA 885 mA 600 mA 1280 mA
[…] on the IDLE state of the Raspberry Pi 4, the power is 2.875 Watt which means the Raspberry Pi is consuming moreover when the load is increased on the Raspberry Pi.
How Much Power Does Raspberry Pi Consume While Operating
So all others idle around 2.7 - 4W but you manage with less than half a Watt? Congrats I would say - or - junk of a power meter you have :wink:
4.5 watts if my maths work…
0.11 * 1000 / 24 is what I’m supposed to do right?
I don’t get why need to tell me I have a junk power meter. Could very well be. That’s why I took a longer duration measurement and calculated daily usage off of that.
That depends on Intel.
I got the understanding that they would stop producing the chip series too.
There are plenty of nuc form factor pc’s based on AMD chips and alternate Intel chipsets. The nuc chips have generally just been minor variations of laptop chips. Laptop chipsets will still be around.
Low cost, small form factor, low power pcs are not in danger of disappearing.
Your math works :wink: Had somehow s(h)aved a power of 1.1w in my head and not the energy kWh you posted :see_no_evil:
Our (now old) HA server based on that 10 year old atom was happy with just 1W idling around - something a Raspbbery Pi 4 did never achieve :man_shrugging: The thing was even capable running of 5V 1A PSU (5W max output without the additional losses in the cable!) - only downside was it never never reached it’s turbo frequence - still was it was running stable. :muscle:
I’ll be excited and ready to purchase when the CM5 is eventually developed and released. Would also be exciting if it could support connectivity to a CM4 based development board. Could upgrade my Home Assistant Yellow PoE in that instance.
Using a 1TB nVME SSD with my HA Yellow using the CM4 Lite.
Yes, that math makes sense to me as well.
So, here in the USA, with the average cost of power being about $0.125 /kWh, this works out to be something like
4.5W/h * 24h/day * 365day/year / 1000W/kW = 39.42kWh used per year * $0.125 = $4.93 per year.
Power usage might not be much of a deciding factor purely from a financial perspective, at least in the USA. Obviously, in other parts of the world, electricity costs are much, much higher. This could affect one’s decision on the choice of platform. Or, if one was trying to run their household off of solar or wind, every little bit helps.
I agree. I too hope the HA Yellow will eventually be able to enjoy a higher performing CPU upgrade via the CM4 module interface. One concern, however, would be whether or not the HA Yellow board would be capable of providing enough power for the RPi 5’s beefier CPU. My HA Yellow is running off of PoE, and I do not know what the max power output the Yellow’s onboard circuitry is capable of.
When CM4 was announced, part of the spin on the new design was that future revisions could use the same connectors in a plaga and play manner.
I hate mini-HDMI !
All my Pi’s are headless servers.
I’m connecting one basic screen when I really really really need one, when SSH is broken and when I have to, I’d like to connect the first HDMI cable that I’m picking without an adapter.
Time to move to something else.
Ever since the 1B+, I’ve faithfully tracked the Pi’s evolution, but this is where I draw the line.
Lets hope Nabu Casa will supply an upgrade kit to the Yellow with CM5 Compute module and a new heatsink if the old cannot be used and also just a new heatsink and the CM5 can be bought by our selves.
Lets keep in mind that the heat aspect has to be considered, maybe the Yellow casing cannot handle an CM5.
I wouldn’t bet on it. My guess is Yellow development is over.
So, will the current version of Home Assistant even work on the Rasperry Pi 5 (without a Docker container)? If not, is there an expected availability date? In other words, is there any point in buying a Pi 5 now?
Lets hope not! Any comments from Paulus or Frenck (not @ atttach you to the conservation as I was told was not allowed from an earlier post)?
A good question. Anytime I’m tempted to jump on The Next Big Thing, I ask myself: “What problem am I trying to solve?” If this is the solution, great! But more often it’s just something new and shiny. It’s hard sometimes to recognize when I’ve got what amounts to a solution in search of a problem.
Along those lines, if the RPi 4 (and 3) are still available, and they run HA just fine, I’d see no rush to support the 5 natively with HAOS. Anyone who wants to can always run HA in a container. That probably makes more sense anyway. That way you can run other things on what’s really a pretty robust device.
That said, developers are known for always wanting the latest and greatest hardware. Wouldn’t surprise me at all if plans are already in the works.
No rush, but I doubt it will take long.
