Raspberry Pi as a CHAPTER 5 voice assistant
Just doing another fresh install, and come across a problem … so i will update my original post to use the correct branch of HinTak’s reSpeaker driver for the current kernel version.
The current (at time of writing) RasPi OS Bookworm (dated March 15th 2024) uses the v6.6 kernel.
Raspberry Pi OS with desktop
    Release date: March 15th 2024
    System: 32-bit
    Kernel version: 6.6
    Debian version: 12 (bookworm)
However it seems that the reSpeaker driver install currently defaults to the v6.1 kernel - which is correct for the older RasPi OS, now referred to as “Legacy” or “Bullseye”
Fortunately this is easy to fix.
On your Raspberry Pi use the “uname -r” command to find out which kernel version is currently running on your RasPi. The first two numbers are the kernel version. If it starts “6.1.” then the default branch is for you; but my newly updated RasPi 4 replied uname -r with “6.6.31+rpt-rpi-v8” so I have kernel v6.6
pi@raspi4:~ $ uname -r
6.6.31+rpt-rpi-v8
HinTak has provided branches in his gitbub repository named with the kernel versions, so it is simple to add the “–branch < version >” option to the git clone command:
git clone --branch v6.6 https://github.com/HinTak/seeed-voicecard.git
or to add a “git checkout < version >” command before running the install script:
git clone https://github.com/HinTak/seeed-voicecard
cd seeed-voicecard
git checkout v6.6
sudo ./install.sh
