Raspberry Pi4 built-in BT
Hi.
Is there a way to turn off (disable) the Raspberry Pi4’s built-in Bluetooth?
Home Assistant 2022.9.7
Supervisor 2022.09.1
Operating System 8.5
for sure. I try to describe it in short.
You need to:
  1. Login to your Pi via SSH or Monitor/Keyboard (physically)
  2. Change/Add one line in the config.txt of your Host OS
SSH Access and where you can find the file is described here.
Which parameter should I change?
I prefer not to use the ssh method. If I put the Raspberry SD card in a windows pc, do I have access to the config.txt file?
yes you do, as it is located in the boot partition. add the following section to the bottom of the config.txt file
[all]
dtoverlay=disable-bt
