Do you have SSD and Conbee II on RPI4 with no problems?
I have installed raspbian on raspi4.
I just tried to install this. I followed the guide, installed dependecies etcā¦ I installed docker from apt, with apt install docker.io
But I dont understand, where is the actual home assistand application?
I installed with this, and now I can see two new docker images running.
curl -sL "https://raw.githubusercontent.com/home-assistant/hassio-installer/master/hassio_install.sh" | bash -s -- -m raspberrypi4
root@raspi4:~# docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
370c9042a188 homeassistant/armv7-hassio-dns:1 "coredns -conf /confā¦" 6 minutes ago Up 6 minutes hassio_dns
e5bafe8489c2 homeassistant/armv7-hassio-supervisor "/bin/entry.sh pythoā¦" 7 minutes ago Up 6 minutes hassio_supervisor
root@raspi4:~# ss -tln
State Recv-Q Send-Q Local Address:Port Peer Address:Port
LISTEN 0 128 0.0.0.0:22 0.0.0.0:*
LISTEN 0 128 [::]:22 [::]:*
I ran the script a second time, and it started another container called homeassistant which listens on port 8123ā¦
Hello ,
can somebody recommend what I am doing wrong ?
I follow many guide and no of them work.
I follow official guide
does not work
then
this quide
I have stuck in last part docker attach --sig-proxy=false ada5bbfc74f0
does not work
trid also IOTstack what GACHAPO mention
does not work
those command what I have tried
sudo -i
apt-get update
apt-get install -y software-properties-common apparmor-utils apt-transport-https avahi-daemon ca-certificates curl dbus jq network-manager socat
systemctl disable ModemManager
curl -fsSL get.docker.com | sh
apt-get update
wget https://download.docker.com/linux/raspbian/gpg
root@raspberrypi:~# apt-key add gpg
OK
echo "deb https://download.docker.com/linux/raspbian stretch stable " | tee -a /etc/apt/sources.list.d/docker.list
apt-get update
apt-get -y install docker-ce
systemctl start docker && systemctl enable docker
curl -sL āhttps://raw.githubusercontent.com/home-assistant/hassio-installer/master/hassio_install.shā >> hassio_install.sh
sudo bash hassio_install.sh -m raspberrypi4
root@raspberrypi:~# sudo bash hassio_install.sh -m raspberrypi4
ModemManager.service enabled
[Warning] ModemManager service is enabled. This might cause issue when using serial devices.
[Info] Install supervisor Docker container
[Info] Install supervisor startup scripts
Created symlink /etc/systemd/system/multi-user.target.wants/hassio-supervisor.service ā /etc/systemd/system/hassio-supervisor.service.
[Info] Install AppArmor scripts
Created symlink /etc/systemd/system/multi-user.target.wants/hassio-apparmor.service ā /etc/systemd/system/hassio-apparmor.service.
[Info] Run Hass.io
root@raspberrypi:~# docker ps
2d1ee939c70c homeassistant/raspberrypi4-homeassistant:landingpage ā/run.shā 10 seconds ago Up 8 seconds homeassistant
92def09042fe homeassistant/armv7-hassio-dns:1 ācoredns -conf /confā¦ā 19 seconds ago Up 17 seconds hassio_dns
fc7d97c080a2 homeassistant/armv7-hassio-supervisor ā/bin/entry.sh pythoā¦ā 33 seconds ago Up 31 seconds hassio_supervisor
root@raspberrypi:~# docker attach --sig-proxy=false 2d1ee939c70c
^C
this part attach does not work docker image looks for me ok but still I dont see hassio menu on HA.
my logs
root@raspberrypi:~# docker logs fc7d97c080a2
20-03-01 01:01:51 INFO (MainThread) [main] Initialize Hass.io setup
20-03-01 01:01:51 INFO (MainThread) [hassio.docker.network] Canāt find Hass.io network, create new network
20-03-01 01:01:52 INFO (MainThread) [hassio.bootstrap] Create Home Assistant configuration folder /data/homeassistant
20-03-01 01:01:52 INFO (MainThread) [hassio.bootstrap] Create Hass.io SSL/TLS folder /data/ssl
20-03-01 01:01:52 INFO (MainThread) [hassio.bootstrap] Create Hass.io Add-on data folder /data/addons/data
20-03-01 01:01:52 INFO (MainThread) [hassio.bootstrap] Create Hass.io Add-on local repository folder /data/addons/local
20-03-01 01:01:52 INFO (MainThread) [hassio.bootstrap] Create Hass.io Add-on git repositories folder /data/addons/git
20-03-01 01:01:52 INFO (MainThread) [hassio.bootstrap] Create Hass.io temp folder /data/tmp
20-03-01 01:01:52 INFO (MainThread) [hassio.bootstrap] Create Hass.io backup folder /data/backup
20-03-01 01:01:52 INFO (MainThread) [hassio.bootstrap] Create Hass.io share folder /data/share
20-03-01 01:01:52 INFO (MainThread) [hassio.bootstrap] Create Hass.io DNS folder /data/dns
20-03-01 01:01:52 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armv7-hassio-supervisor with version 201
20-03-01 01:01:52 INFO (SyncWorker_0) [hassio.docker.supervisor] Connect Supervisor to Hass.io Network
20-03-01 01:01:53 INFO (MainThread) [main] Setup HassIO
20-03-01 01:01:53 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
20-03-01 01:01:53 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
20-03-01 01:01:53 WARNING (MainThread) [hassio.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
20-03-01 01:01:53 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.NetworkManager - /org/freedesktop/NetworkManager/DnsManager
20-03-01 01:01:53 INFO (MainThread) [hassio.host.info] Update local host information
20-03-01 01:01:53 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-01 01:01:53 INFO (MainThread) [hassio.host.services] Update service information
20-03-01 01:01:53 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-01 01:01:54 INFO (MainThread) [hassio.host.network] Update local network DNS information
20-03-01 01:01:54 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-03-01 01:01:54 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {āhassio-supervisorā}
20-03-01 01:01:54 INFO (MainThread) [hassio.host.services] Reload local service hassio-apparmor.service
20-03-01 01:01:54 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
20-03-01 01:01:54 INFO (MainThread) [hassio.dns] No CoreDNS plugin Docker image homeassistant/armv7-hassio-dns found.
20-03-01 01:01:54 INFO (MainThread) [hassio.dns] Setup CoreDNS plugin
20-03-01 01:01:54 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-01 01:01:54 INFO (SyncWorker_0) [hassio.docker.interface] Pull image homeassistant/armv7-hassio-dns tag 1.
20-03-01 01:02:02 INFO (MainThread) [hassio.dns] CoreDNS plugin now installed
20-03-01 01:02:02 INFO (MainThread) [hassio.misc.forwarder] Start DNS port forwarding to 172.30.32.3
20-03-01 01:02:02 INFO (MainThread) [hassio.dns] Start CoreDNS plugin
20-03-01 01:02:03 INFO (SyncWorker_5) [hassio.docker.dns] Start DNS homeassistant/armv7-hassio-dns with version 1 - 172.30.32.3
20-03-01 01:02:03 INFO (MainThread) [hassio.homeassistant] No Home Assistant Docker image homeassistant/raspbe
Your second link is rather old, probably out of date by now.
Iām guessing you are running latest Raspbian? I didnāt install the optional network-manager. With it my Pi 4 looses wifi after reboot.
On a fresh Raspbian install, try the following: (from here)
sudo -i
apt update
apt upgrade
apt install -y software-properties-common apparmor-utils apt-transport-https avahi-daemon ca-certificates curl dbus jq socat
problem solved I see menu does not call hassio but supervisor
Iāve recently moved to Docker + HassIO. For some reason, my HA update, when run from the GUI very rarely manages to do its job. The update doesnāt conclude, and the system seems to clog up somehow so I canāt even run any commands on it.
How can I troubleshoot this? What logs should I be looking at to find what the issue is?
Thanks,
Ville
I donāt use hassio o my knowledge is kind of limited on that.
But I think there are some supervisor logs that you can look at to tell you what is going on with the updates and the reasons why the update failedā¦I think.
Donāt ask me where those logs are located because I honestly have no idea.
SSH to raspbian (not home assistant)
issue
sudo docker ps -a
to list te docker containers. Find the id of supervisor
sudo docker logs <id of supervisor>
to view the log of supervisor
docker logs hassio_supervisor
Should work. Sudo should be unnecessary if you correctly followed the instructions when you install docker and added the usual user to the docker group. You can also use a docker logs -f hassio_supervisor
to give real-time updates. Use homeassistant instead of hassio_supervisor for homeassistant logs as well.
Thanks for the swift replies. The updates have worked a couple of times for me since posting my question, but now Iām stuck with the same issue I had before, i.e. the homeassistant container fails to start properly.
It seems the logs donāt really capture what the issue is. Any ideas on how to dig up more info/fix the issue?
The hassio_supervisor log shows:
20-04-29 05:07:38 ERROR (MainThread) [supervisor.homeassistant] Error on call https://172.30.32.1:8123/api/: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
20-04-29 05:07:38 INFO (MainThread) [supervisor.auth] Home Assistant not running, check cache
20-04-29 05:07:54 INFO (SyncWorker_6) [supervisor.docker.interface] Start homeassistant/raspberrypi3-homeassistant
20-04-29 05:10:18 ERROR (MainThread) [supervisor.homeassistant] Home Assistant has crashed!
The docker log for the homeassistant container shows:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[07:08:07] INFO: Update udev information
[cont-init.d] udev.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
After Docker I installed Hassio-supervisor. New installation script is:
> sudo su
# curl -sL https://raw.githubusercontent.com/home-assistant/supervised-installer/master/installer.sh | bash -s -- -m raspberrypi4
But I have error:
root@raspberrypi:~# curl -sL https://raw.githubusercontent.com/home-assistant/supervised-installer/master/installer.sh | bash -s -- -m raspberrypi4
[Warning] This installer is no longer supported.
[Warning]
[Warning] Home Assistant might work today, tomorrow maybe not.
[Warning]
[Warning] If you want more control over your own system, run
[Warning] Home Assistant as a VM or run Home Assistant Core
[Warning] via a Docker container.
[Warning]
Please typ "not supported" to continue this installation
bash: line 17: syntax error near unexpected token `then'
(23) Failed writing body
The hassio_install.sh not actual now. What can I install HASSIO in Docker containers?
You need to copy the script and run it locally.
Not runing:
root@raspberrypi:/home# curl -sL installer.sh | bash -s -- -m raspberrypi4
bash: line 1: !DOCTYPE: No such file or directory
bash: line 2: html: No such file or directory
bash: line 3: syntax error near unexpected token `<'
'ash: line 3: `<head id="ctl00_ctl00_Head1"><title>
This GitHub branch now is archived, and README.md announced: āThis install method has been deprecatedā. I see the another installation algorithm.
You need to run it locally. I used it yesterday!
(Also you donāt need to ācurlā it if you downloaded it - donāt use curl -sL)
./installer.sh | bash -s ā -m raspberrypi4
Hello, due to this installation process not supported anymore (depricated), does someone know what are the new instruction/commands to type (for having hassio on raspberry desktop, indeed only way to keep the supervisor icon on HA session)? indeed I read in the message error that it could be possible, but I donāt know what to type
1st option: flash the Home Assistant OS image for your Pi - you keep the supervisor, you lose access to a full OS
2nd option: Install Raspbian as the OS and install Home Assistant Core in venv or docker. You gain access to a full OS, you lose the supervisor.
Hello jason I just realize that despite the installation is not supported anymore, the http://xxx.xxx.xx.xx:8123 seems to work and I see the supervisor. So I donāt really understand why it works do you think I will have a problem later on? (=I donāt understand "the installation is not supported )
If I can keep my installation, I had another question : when I will restart my Rpi later , does someone know what are the commands I will need to type on the terminal, please? Thank you in advance for your help
Try my forkā¦ curl -sL https://raw.githubusercontent.com/krdesigns-com/supervised-installer/master/installer.sh | bash -s -- -m raspberrypi4
