I have added dtoverlay=pi3-disable-bt to the end of my /mnt/boot/config.txt file, and the zwave integration seems to install successfully in the UI by using the
USB path = /dev/ttyAMA0
per my hardware listing, however when I try to start the zwave network, I continue to get the following error in my OZW_Log.txt:
2020-04-14 20:48:24.890 Always, OpenZwave Version 1.4.3469 Starting Up
2020-04-14 20:49:09.311 Info, Setting Up Provided Network Key for Secure Communications
2020-04-14 20:49:09.312 Info, mgr, Added driver for controller /dev/ttyAMA0
2020-04-14 20:49:09.312 Info, Opening controller /dev/ttyAMA0
2020-04-14 20:49:09.315 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2020-04-14 20:49:09.315 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2020-04-14 20:49:09.316 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-04-14 20:49:09.316 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-04-14 20:49:09.316 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-04-14 20:49:09.316 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-04-14 20:49:09.318 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-04-14 20:49:09.318 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-04-14 20:49:09.318 Detail, contrlr, Notification: DriverFailed
I’ve tried dtoverlay=pi3-miniuart-bt as well as replacing pi3 with pi4. no change.
Any suggestions?
