I’m not seeing any reference to cover.set_cover_position in my HA. I have something called cover.ratgdov25i_47a31e_door. Only entity that contains cover.
Ahhh, I see that now in the services. Still struggling how I use this in like a card. if I try using any card with cover.ratgdov25i_47a31e_door it’s more of an up and down thing. Can’t control the percentage or scroll thru and select a percentage.
I add the cover entity in the UI as a button. Simple open/close that by default shows the current door state using image. Default action when Long press the button pops up an ui that allows slide up and down to specific percentage
+1 to the mushroom cover card. I use this one too, and it’s perfect. You can swap between the simple up/down to the percentage function on the card by clicking the button on the far right of it. And it looks nice.
Up/Down Look
Percentage Dimmer/Slider Look (currently at 0% open so it looks empty here)
@jeff6 I know it’s been awhile. I just purchased the latest board and uploaded the latest ESPHome firmware, All is working except the RatGDO controls:
I do have the doors bridged into homekit. These controls also continue to function. I’ve got the door obstruction sensors and wall control wired into the RatGDO board.
See this on RATGDO restart:
Failed to communicate with garage opener on startup.
UPDATE: Flashed wrong protocol. My Liftmaster W8500 is SEC+, not 2.0.
I don’t know if that’d work without building your own ratgdo with an ESP32 instead. I don’t think there’s enough GPIO pins available to add a PoE adapter to it (esp for network + power).
