@B5r1oJ0A9G
Hi Marc! Thanks for your great work with the integration of Raumfeld in HASS. I‘ve used it daily without any problems and it worked perfect. Unfortunately since the latest HASS update to 2022.4. this integration doesn’t work anymore. Could you try to fix this issue. This would be great…
Since the Teufel Raumfeld Integration doesn’t Work anymore, do you have any other solutions/workarounds to Control Teufel Raumfeld from Homeassistant?
Looking Forward for your solutions
@blackmore in my case, I sold all my Teufel gear and went with Musiccast devices. They integrate well with Home Assistant and are supported with an official integration.
For your information: The integration should work again. Thanks to the notes in the issue tracker, the problems were finally fixed quickly. I had to invest most of my time in restoring the development environment and refreshing my knowledge of the update procedure.
the Integration seems to do not work since latest update of homeassistant. Is there a Chance to get it to work again?
Dies anybody has another solution to control raumfeld devices from homeassistant? Thanks a lot!
@B5r1oJ0A9G
I run Homeassistant Version 2024.2.5 at the moment and Raumfeld integration v01.15-alpha3. The Raumfeld integration is working fine … with one issue though:
If I did run Spotify over Raumfeld (via native Spotify and Raumfeld apps) as the last Raumfeld stream before I use the media_player.play_media service to run e.g. a radio station on the Raumfeld device, I get “Error running action: unknown error”. Is this something that can get fixed?
Hi there, I tried to overcome the limitations of the existing Teufel Integrations and have developed a new one, following a different approach. Does anyone want to help beta-testing it?
I tried to focus on:
Simplicity and stability
Speed + low footprint on the Raumfeld devices.
Solid integration of Spotify Connect next to Raumfeld native playback. Tested well with Raumfeld mode in TuneIn, Spotify Connect, Chromecast Playback
Supports Multiroom
Tries to support Music Assistant as good as possible.
What I personally realized with it:
Ikea Styrbar as a fast reliable remote control for radio stations (left/right switches between radio stations, top/bottom controles voume. Long press swiches off.
Global off switch which switches off all Raumfeld Devices in every room.
Full Playback possibilities through Music Assisstant.
