I give up now.
If OP insist on not formating the code here then I give up.
Formatting your code isn’t only to ensure syntactically valid YAML when you save it — it’s also a courtesy to people trying to help you that shouldn’t have to go sit and reformat your YAML and make assumptions about it. There are many reasons why YAML that saves perfectly fine can still be broken. If you want help, follow the advice already given to you.
