Do you think it is ok if I see 2 instances of the script scripts/rpi-rf_receive-mqtt running?
Hi! I’m trying to run the Python script to publish the RF codes to an MQTT topic, but I keep getting this error:
File "rfcodes.py", line 12, in <module>
import paho.mqtt.publish as mqtt
ImportError: No module named 'paho'
I installed paho-mqtt. Any ideas? Any help would be much appreciated. Thanks!
Found out the problem. Removing “sudo” while running the command worked. Thanks again for making this script! I’m going to put it to very good use
I want to turn an RF signal into a mqtt message,
I want every code transmitted from my remote control to have a different topic
I followed this guide to install the receiver / transmitter on the raspberry and to read the codes transmitted from my remote control.
( https://youtu.be/5UUazFbK-Hg ) -
Then I installed mosquitto by following this guide
( https://youtu.be/AsDHEDbyLfg ), before I used mqtt integrated in HA -
So I installed paho-mqtt with this command
sudo pip3 install paho-mqtt
I modified the code written by “gpbenton” to get a different topic for each key of my remote controls.
SSH command:
sudo nano /home/pi/rfrxtomqtt.py
Code:
https://pastebin.com/4ELr5GF1 -
I added to the raspberry cron the automatic start of the code with Python
SSH command:
sudo crontab -e
Code at the end of the text:
@reboot python3 /home/pi/rfrxtomqtt.py &
I added to the configuration.yaml file
Code:mqtt: broker: 192.168.1.201 port: 1883 protocol: 3.1.1 client_id: home-assistant-1 username: username_mqtt password: password_mqtt switch: - platform: mqtt name: "Light kitchen RF" state_topic: "rf/tonino/3366511" command_topic: "rf/tonino/3366511" payload_on: "ON" payload_off: "OFF" optimistic: false qos: 0 retain: true - platform: mqtt name: "Light bedroom RF" state_topic: "rf/tonino/3366512" command_topic: "rf/tonino/3366512" payload_on: "ON" payload_off: "OFF" optimistic: false qos: 0 retain: true
I modified automations.yaml to switch the lights on / off and to reset the On / Off states :
Code:- alias: 'turn on light kitchen RF' trigger: - platform: state entity_id: switch.light_kitchen_rf from: 'off' to: 'on' action: - service: switch.toggle entity_id: switch.light_kitchen - delay: '00:00:02' - service: switch.turn_off entity_id: switch.light_kitchen_rf - alias: 'turn on light bedroom RF' trigger: - platform: state entity_id: switch.light_bedroom_rf from: 'off' to: 'on' action: - service: switch.toggle entity_id: switch.light_bedroom - delay: '00:00:02' - service: switch.turn_off entity_id: switch.light_bedroom_rf
… Now I can control the house with a 433Mhz RF remote control, I assign a home function to every button on the remote control (for example, turn the light on in the kitchen).
The first pressure to turn on and the next to turn off.
I hope I have been helpful summarizing the post.
@Jiran is it possible to could explain or post the code you ended up using?
Hi, rpi-rf_receive-mqtt does the job. It receives codes from RF devices using hardware receiver connected to raspberry. Will try to find the script…
Right, however, i do have the script, but how do you make it run?
I did the exact same as you did. But paho-mqtt, how did you manage to install that?
I cant seem to do it with Putty in the new version of Hassio.
Is it possible you could do a quick walkthrough?
