Reading text and time from a python file and having it as a sensor in HA
Right I have done that thanks for that.
I have 2 things to overcome, one is to show the date like below:
How can I achieve this? as its not a string and the date updates every day I believe. So the code you gave above I cannot use like we did to find the times of certain teams playing.
Secondly, I have done the following to activate the automation according to the time of the state of the entity. However it doesn’t fire the automation for some reason.
- alias: United Time
  initial_state: 'on'
    platform: template
    value_template: '{{ now.time().strftime("%H:%M") == states.sensor.manutd.state }}'
   - service: notify.me
       message: 'Manutd Playing Now'
Any ideas?
Many thanks for your help buddy.
UPDATE:
Ignore the first part of the obstacle. I need the automation to work but I have a feeling that HA is not recording the time from the text file as time rather its taking it as a number.
Is there anyway I could resolve this? because my automation is testing the current time against the sensor value of ‘Manutd’ and it doesn’t trigger unfortunately.
I seached the forum and found this
so maybe this might work, try it in your dev templating to see its output quickly
{{ strptime(states.sensor.manutd.state , “%H:%M”) }}
if it does, just change this line or perhaps change the sensor so it reads as time.
    value_template: '{{ now.time().strftime("%H:%M") == strptime(states.sensor.manutd.state , “%H:%M”) }}'
The above returns the following:
1900-01-01 12:30:00
and when I use value_template: '{{ now.time().strftime("%H:%M") == strptime(states.sensor.manutd.state , “%H:%M”) }}’ it does not work because of the date in the state of sensor.manutd
I had the wrong quotes, they need to be ' not ’
'{{ now.time().strftime("%H:%M") == strptime(states.sensor.manutd.state) , "%H:%M") }}'
I thought you had ‘ and not ’ in your previous message. I dont see any change mate and I get the same result as above.
I should work, does states.sensor.manutd.state give you a text with only ##:## ? I highlighted were the quotes might be wrong as it appear wrong in your last post.
yeah I realised what you were saying but in my config I have got the correct quotes and the automation still does not fire. Did you try it in your dev template ?
I added a time sensor component and got my automation working. This is my automation:
  • alias: Test
    initial_state: ‘on’
    platform: template
    value_template: ‘{{ states.sensor.test.state == states.sensor.time.state }}’
    • service: notify.me
      message: ‘Test’
However, I noticed a lag of 4-5 seconds with the sensor time component before the automation triggers.
So does that maudt sensor work? I don’t have a time sensor in text to try but this work so it appears to be correct format.
value_template: '{{ states.sensor.manutd.state == states.sensor.time.state }}'
This works but like I mentioned there is a lag of 4-5 seconds before the action is triggered. I cannot work it out why.
But this : '{{ now.time().strftime("%H:%M") == strptime(states.sensor.manutd.state) , "%H:%M") }}' does not work I think its because of the date i.e. 1900-01-01 as the trigger does not match with the now time.
is there a way were I could trigger the automation 5 seconds earlier?
I have a dumb (and belated…) question: I thought you can’t import libraries into python scripts? How did you do this?
I run the script using cron independent from HA…the output of the script is then saved as a text file and integrated with HA using the file sensor component.
