Oh, that is really odd. The Blue Jays and Yankees seem to have the old order. The others have a new order.
Exactly, the issue you are having is that for teams that have Clinched (or are Eliminated) from the Playoffs, ESPN adds this:
- name: clincher
displayName: Clincher
shortDisplayName: CLINCH
description: Clinched Playoff Berth
abbreviation: CLINCH
type: clincher
value: 3
displayValue: z
So you could add a new column after the first hidden column like this:
- name: C
data: entries
modify: >-
if(typeof x.stats.find(y=>y.abbreviation == 'CLINCH') !==
'undefined' ){x.stats.find(y=>y.abbreviation ==
'CLINCH').displayValue}else{'-'}
NOTE: you must use the if here because if the CLICH field does not exists yet (as it doesn’t for teams who haven’t or are eliminated), it will be an error.
I follow NHL mostly and NFL, so I had not done all the updates on MLB or NBA including some form of Playoff. For your use, I will post here code for NHL which you can use to study.
Decluttering Template:
nhl_settings:
card:
type: custom:flex-table-card
title: '[[title]]'
css:
table+: 'padding: 0px; width: 1600px;'
tbody tr td:first-child: 'width: 2%;'
tbody tr td:nth-child(2): 'width: 20%;'
tbody tr td:nth-child(n+3): 'width: 5%;'
tbody tr:hover: 'background-color: green!important; color:white!important;'
tbody tr td:nth-child(7): 'background-color: green; color: white;'
card_mod:
style:
ha-card {
overflow: auto;
.card-header {
padding-top: 6px!important;
padding-bottom: 4px!important;
font-size: 14px!important;
line-height: 14px!important;
font-weight: bold!important;
entities:
include: '[[entity]]'
exclude: '[[excluded_entities]]'
sort_by: entries-
columns:
- hidden: true
data: '[[attribute]]'
modify: '[[sort]]'
- name: >-
<div title="Clinch Indicator: * : Presidents Trophy x :
Playoff Berth - : In The Hunt e : Eliminated">C</div>
modify: >-
- name: Team
modify: >-
'<div><a href="' + x.team.links[0].href + '" target="_blank"><img
src="' + x.team.logos[0].href + '" style="height:
20px;vertical-align:middle;"></a> ' + x.team.displayName +
'</div>'
- name: <div title="Games Played">GP</div>
modify: x.stats.find(y=>y.abbreviation == 'GP').displayValue
- name: <div title="Wins">W</div>
modify: x.stats.find(y=>y.abbreviation == 'W').displayValue
- name: <div title="Losses">L</div>
modify: x.stats.find(y=>y.abbreviation == 'L').displayValue
- name: <div title="Overtime/Shootout Losses">OTL</div>
modify: x.stats.find(y=>y.abbreviation == 'OTL').displayValue
- name: <div title="Points">PTS</div>
modify: x.stats.find(y=>y.abbreviation == 'PTS').displayValue
- name: <div title="Regulation Wins">RW</div>
modify: x.stats.find(y=>y.abbreviation == 'RW').displayValue
- name: <div title="Regulation and Overtime Wins">ROW</div>
modify: x.stats.find(y=>y.abbreviation == 'ROW').displayValue
- name: <div title="Shootout Wins">SOW</div>
modify: x.stats.find(y=>y.abbreviation == 'SOW').displayValue
- name: <div title="Shootout Losses">SOL</div>
modify: x.stats.find(y=>y.abbreviation == 'SOL').displayValue
- name: <div title="Home Record">HOME</div>
modify: x.stats.find(y=>y.abbreviation == 'HOME').displayValue
- name: <div title="Away Record">AWAY</div>
modify: x.stats.find(y=>y.abbreviation == 'AWAY').displayValue
- name: <div title="Goals For">GF</div>
modify: x.stats.find(y=>y.abbreviation == 'GF').displayValue
- name: <div title="Goals Against">GA</div>
modify: x.stats.find(y=>y.abbreviation == 'GA').displayValue
- name: <div title="Game Average Goal Differential">DIFF</div>
modify: x.stats.find(y=>y.abbreviation == 'DIFF').displayValue
- name: <div title="Last 10 Games">L10</div>
modify: x.stats.find(y=>y.abbreviation == 'L10').summary
- name: <div title="Current Streak">STRK</div>
modify: x.stats.find(y=>y.abbreviation == 'STRK').displayValue
Using that template:
- type: custom:decluttering-card
template: nhl_settings
variables:
- title: Eastern Atlantic
- entity: sensor.nhl_east_atlantic
- attribute: entries
- excluded_entities:
- sensor.nhl_starting_goalies
- sensor.nhl_wildcard
- sensor.nhl_wildcard_standings
- sort: >-
x.stats.find(y=>y.shortDisplayName ==
'PTS').value
You can see here a few things.
- the variables include the attribute you wish to use (in most cases this is entries).
- You can also pass in a set of excluded entities because in divisional and overall, the code would try to get
sensor.nhl_*_*
and if you had a sensor likesensor.nhl_starting_goalies
it would grab that sensor and this would break the card. - It also allows you to pass in the sort so you can decide how you wish to sort and use the same template.
- It redoes how the name of the field is displayed (in a ) so you can add a title which results in a tooltip if you mouse over it.
@jeffcrum … if you track it through it is probably sorted as specified. The key is the x.stats[16].value is a is a different column for those with “x” or “e” than it is for those without. Who knows but it is likely two different columns, one could be “WON” and and the other “LOSSES”
Yeah. I am working and didn’t have time to do that. Just noting an observation that I saw.
Here is a simple decluttering template without all the bells and whistles in the NHL one.
mlb_settings:
card:
title: '[[title]]'
css:
tbody tr td:nth-child(6): 'background-color: green; color: white;'
card_mod:
style:
ha-card {
overflow: auto;
.card-header {
entities:
sort_by: entries-
columns:
- hidden: true
data: entries
modify: x.stats.find(y=>y.abbreviation == 'PCT').value
- name: C
data: entries
modify: >-
- name: Team
data: entries
modify: >-
'<div><img src="' + x.team.logos[0].href + '" style="height:
20px;vertical-align:middle;"> ' + x.team.displayName + '</div>'
- name: GP
data: entries
- name: W
data: entries
- name: L
data: entries
- name: PCT
data: entries
modify: x.stats.find(y=>y.abbreviation == 'PCT').value.toFixed(2)
- name: GB
data: entries
modify: x.stats.find(y=>y.abbreviation == 'GB').displayValue
- name: HOME
data: entries
modify: x.stats.find(y=>y.abbreviation == 'Home').displayValue
- name: AWAY
data: entries
- name: RS
data: entries
modify: x.stats.find(y=>y.abbreviation == 'RS').displayValue
- name: RA
data: entries
modify: x.stats.find(y=>y.abbreviation == 'RA').displayValue
- name: DIFF
data: entries
- name: L10
data: entries
modify: x.stats.find(y=>y.shortDisplayName == 'L10').displayValue
- name: STRK
data: entries
For those interested in seeing what is going on, you can paste this into Developer Tools Template.
{%- for team in states.sensor.mlb_american_west.attributes.entries %}
{{ team.team.displayName }}
{%- set ns = namespace(count=0) -%}
{%- for stat in team.stats %}
{{ ns.count }} : {{ stat.abbreviation }} : {{ stat.displayName }} : {{ stat.displayValue }}
x.stats.find(y=>y.abbreviation == '{{ stat.abbreviation }}').displayValue
{%- set ns.count = ns.count + 1 -%}
{%- endfor -%}
{%- endfor -%}
You can see that both the Angels and Athletics have a CLINCH field defined. But, the other three do not. So, everything after number 4 is shifted one.
This shows the number, abbreviation, display name, and display value for each stat. It also builds the line using the abbreviation that can go in the modify statements.
This clearly shows why it makes sense to use the abbreviation instead of numbers.
LOVE this integration - i have a new problem, too many active game cards concurrently.
Is there a way to use the size of the PRE or POST cards for an “active” game so it’s smaller with less information and shows just teams, inning, score, time, etc?
WHat way are you laying out the card in the view? You need to tell us.
If you are using my integration it is using masonry layout.
Apologies for my lack of specificity. I’m using the team tracker card and looking for a more compact version of the team tracker card when the game is in progress. A compact version that is the same size as pre or post would be great!
I would think everything should scale. Like putting it into a custom:layout-card with 4 columns or maybe even 5
Thanks for the thought, unfortunately the current “in game” card has too much data to scale into a “compact” form, see example below:
My preference is to have a “minimal in game” card based on the current “in game” card that cuts off everything after the inning. this would give me the minimum info on the event. same idea for basketball and football.
I tried to add a Pull Request but got denied as i’m not a contributor.
That is not displaying anything that you could not make in a separate card/set of cards. All the data is in the teamtracker sensor.
Like I use declutter and card_mod for color changes when in the red zone. Also have light scenes and TTS announcements on game start and TDs.
Totally understand I could do it myself. Putting the idea out there in case others could find value in the idea.
I do like it. Given that I built the other part without a “installed” sensor (Sports Standings and Scores) I could build out something.
Maybe something like this?
Not sure Hits, Errors are available as they are not in the regular card, score certainly, team certainly, logo certainly, inning yes.
Here is everything that should be available (no game in process yet):
attribution: Data provided by ESPN
sport: baseball
league: MLB
league_logo: https://a.espncdn.com/i/teamlogos/leagues/500/mlb.png
team_abbr: DET
opponent_abbr: KC
event_name: KC @ DET
date: 2023-09-28T19:30Z
kickoff_in: in 2 hours
venue: Comerica Park
tv_network: null
odds: DET -110
overunder: 7.5
team_name: Tigers
team_id: 6
team_record: 74-83
team_rank: null
team_homeaway: home
team_logo: https://a.espncdn.com/i/teamlogos/mlb/500/scoreboard/det.png
team_colors: #002d5c, #ff6600
team_score: 0
team_win_probability: null
team_winner: null
team_timeouts: null
opponent_name: Royals
opponent_id: 7
opponent_record: 54-103
opponent_rank: null
opponent_homeaway: away
opponent_logo: https://a.espncdn.com/i/teamlogos/mlb/500/scoreboard/kc.png
opponent_colors: #004687, #7ab2dd
opponent_score: 0
opponent_win_probability: null
opponent_winner: null
opponent_timeouts: null
quarter: 1
clock: 9/28 - 3:30 PM EDT
possession: null
last_play: null
down_distance_text: null
outs: null
balls: null
strikes: null
on_first: null
on_second: null
on_third: null
team_shots_on_target: null
team_total_shots: null
opponent_shots_on_target: null
opponent_total_shots: null
team_sets_won: null
opponent_sets_won: null
last_update: 2023-09-28 09:49:13-07:00
api_message: Cached data
icon: mdi:baseball
friendly_name: Detroit Tigers
Or what about just some simple card_mod on the existing card?
type: custom:teamtracker-card
entity: sensor.detroit_tigers
card_mod:
style:
.logo
{max-width:30px!important;}
.card
{width:60%}
.name
{font-size:1.2em;height:1em;}
.gameday
{font-size:1em;height:1em;}
.gamedate
.gametime
.pre-row1, .pre-row2, .pre-row3
With and without image (needs edit on card widths but you get the idea)
Or this … hide components you do not want …
card_mod:
style: >-
.logo {max-width:30px!important;} .card {width:60%} .name
{font-size:1.2em;height:1em;} .gameday {font-size:1em;height:1em;} .gamedate
{font-size:1em;height:1em;} .gametime {font-size:1em;height:1em;} .pre-row1,
.pre-row2, .pre-row3 {font-size:1em;height:1em;} .score {font-size:1.5em;}
.play-clock {font-size: 1.2em;} .in-row1, .in-row2, .line1, .line2,
.last-play, .bar-wrapper {display:none;}
Pulling everything together in a panel/grid:
- title: Panel Playground
icon: mdi:toy-brick-marker
type: panel
badges: []
cards:
- square: true
type: grid
cards:
- type: custom:teamtracker-card
card_mod:
style: >-
.logo {max-width:30px!important;} .name
{font-size:1em;height:1em;} .pre-row1, .pre-row2, .pre-row3
.line2, .last-play, .bar-wrapper {display:none;}
card_mod:
style: >-
card_mod:
style: >-
card_mod:
style: >-
card_mod:
style: >-
columns: 5
Mixing it up a bit with some in-game …
It could easily be shrunk more and also needs set height on cards for grid view … or better custom:layout-card so that cards snap to fit from phone/pad/computer view.
type: custom:masonry-layout
layout:
max_cols: 5
badges: []
cards:
card_mod:
style: >-
.gamedate {font-size:1em;height:1em;} .gametime
{font-size:1em;height:1em;} .score {font-size:1.5em;} .play-clock
{font-size: 1.2em;} .in-row1, .in-row2, .line1, .line2, .last-play,
entity: sensor.minnesota_twins
card_mod:
style: >-
card_mod:
style: >-
entity: sensor.chicago_white_sox
card_mod:
style: >-
card_mod:
style: >-
Gives you this on computer:
This on phone:
This on iPad:
That is as far as I will go but you have all the blocks here to make what you want just using card-mod.
I will admit that this helped me a bit as I always wanted to scale down the card for my wallpanel displays
I tweaked the card a while ago specifically to increase it’s compatibility with card-mod. You should be able to mod whatever component or card-level setting you want.
If you can’t, let me know and I’ll make the changes to allow it. I decided it’s a lot easier to increase compatibility w/ card-mod than to add a ton of options trying to anticipate what someone might want.
I am just getting started on Home Assistant and I am having problems setting up this card. I downloaded the card from HACs but I don’t have a sensor.team_tracker in my entities. I am only seeing update.team_tracker_card_update.
When I go to set up this card it says this entity is missing. Is there something that I did wrong?
Have you installed the Card and the Integration from HACS (and then setup the Integration to track a team)? It’s the Integration that provides the sensor, the card then displays it…
Best have a good read through this to get you up and running properly…
kann mir einer helfen die deutsche 2 bundesliga rein zu bekommen ? danke schonmal ist ein echt top gemacht
- platform: teamtracker
league_id: XXX
team_id: KIE
sport_path: soccer
league_path: ger.2
